Installation Kolm Engines IL100 in Messerschmitt BF109F2
Hello!
If anyone is interrested, i can post a little description of installing a Kolm IL100 in a scratch build Bf109!
Ok
so, the top of the Zylinders will be Outside, so i cant do a normal inline-cooling.
First i have to fit the Engine in Right Position. I will do a Installation on Rubbers. Like D-Loks. In Front and back!
this will be the First part.
Tom
Tom
so, itīs a Bf109. build in wood out of an old plan. i got the ready build wooden parts one year ago. so i decided to do something with it :-)
Its a about 100inch. (2.6m)..so about 1.3:8. Only for the cowling i made moulds because the wooden one was useless
So... i show you the way how we install in austria a heavy engine in a big bird.
you cant hold it longer then 1 minute in correct position. so we do it like this , to check where to drill the holes :-)
Next : because of installation on D-Locks i need a mounting plate in the front of the engine. i did this in carbon.
the parts i used you can buy for the carf Spitfire. so you need not to cut out yourselfe. also the alu-plates front and back for the engine. When the pipes are pre-fixed i cant do the engine out and fix it with epoxy.
Yes it'S with Electric Start
@nickelup : think i Can Start in about 3 Weeks. Then Should the bf109 be ready
@kim: yes the are Long, but we think its no Problem. The Pipes at the Boxer are also very Long. We havent tested it yet.
all wood around the firewall is pianted in RLM02 now. the servos for throttle and choke are installed. from this moment i have to install everything behind the cg.
i donīt want have extra wheigt in the tail :-)
