Robart air line type quick disconnect issue
1[SUP]st[/SUP] let me state that I have no reason to believe this issue is related to Robart in any way. Robart products and service have always met or exceeded my expectations.
I have an aircraft that uses air line quick disconnects between the wing and fuse. The quick connects are commonly known as Robart part #190.
I have used these on many planes and never had a problem before. The failure was between the two connectors not between the air line and the connector.
On my newest plane I’ve experienced 3 failures where the coupling disconnects unexpectedly. The 1[SUP]st[/SUP] time I just assumed I failed to properly connect the parts, they make a distinct click when assembled correctly. The second time was a year later and again I assumed it was my fault. But the third time it occurred the very next day and I was very careful and double checked each connection during assembly.
Since I’ve acquired parts for this plane a long time ago I’m not even sure if I bought genuine Robart parts.
I’ve just ordered new Robart connectors and will install them before I fly this plane again.
My question is has anyone else seen this type of issue? Does anyone know if inferior clones exist? If so has anyone figured out how to detect them?
My Feedback: (23)
"Robarts" disconnects are just repackaged products. Ive seen the same style disconnect from at least 2 different manufacturers, so its very possible the QC could be worse with one than the other.
Your problem is exactly why i dont use those style disconnects any longer. A small click isnt't enough assurance for me, so i use ones that take multiple turns to thread together. A little more time to hook up, but its better than a small click
My Feedback: (360)
I must say I always used the Robarts on all my jets and warbirds for the last 20 years, and so far so good. I have never had one leak yet, and the only one that ever came loose is when I did not not properly twist it locked. Of course, it came loose on the ground as soon as I applied air pressure. But like anything else, you can get a bad one. My experience with them has been good over the years.
Well I installed new Robart connectors on my Corsair this morning and carefully tested to make sure they were secure. I then tucked them next to the fuel tank( I have a lot of room, it's not tight). Nothing to get snagged on, no servos in the area. One of the four air lines again came apart. I pulled the wing up and reattached the connector lowered the wing again and again one of the connections came apart. I carefully reconnected the connector and taped all of them with electrical tape. I tested the retracts before each flight and had no issues. I purchased several extra sets of air connectors and sat and played with the extra sets all morning, I still have no idea how they are coming undone. I assume when I tuck them next to the tank they must be unlatching. I see no way they could come apart once snapped together. No way air pressure alone could open them if they are snapped together.
I have several other planes with Robart air retracts and have never had an issue till now. One of the planes has more than 500 fights and I never had an air related retract issue.
Hi
I've used those for years without issue. I tried a set that came with a plane and they were cheap clones that didn't lock up very well. The genuine Robart ones need to have the line pushed on really well and the twist nice and tight... but when that's done, they've been ultra-reliable. I even use them to connect a wing-mounted main air tank to the fuse-mounted valve. No issues.
I also have had similar issues with Robart connectors. Never could figure out if it was me or the connector. Now use a locking connector from Colder Products. I believe it is part: PTC16010. A friend of mine works at a hospital and gets them for me. These lock and will never come apart. Have used them for a few years with no problems.
john
john
FYI while looking into this issue I came to the conclusion once the connector is latched 2 groves are present on the sides of the connector. If you were to place something in the groves then the connector cannot come unlatched. I purchase a few C type clips at the Hardware store, I plan to use them as a pacifier for yours truly. I'll have to upload some pictures when I get home.
Thanks for all your inputs.
Matt
Matt
I've used these many years with no issues. Recently one of the guys at the field had one come apart. Upon inspection, we realized they did not "snap" together as well as most we have seen. They were Robart parts, not any type of clone. It seems that there is inconsistency in the quality of the Robart connectors, especially recently. Make sure you have a pair that snaps together firmly. If they don't, it's much more likely that they could come apart in flight.
Dreamworks sells 1/8" OD Festo connectors that work with the Robart line. They work very nice and would be reliable. I use them when I need a quick disconnect for problem landing gear.
http://www.dreamworksrc.com/catalog/...ight-Connector
So as promised here is a picture of the clips I plan to test on my air line connections. These clips are intended to keep the connectors from un-locking. by sitting in the grove which is present once the connectors a clicked (Latched).
The left clip is the least expensive at $ 0.23 each it appears to work very well and is easy to put on and take off, on the downside it's easy to bend(this is my first choice). The Clip on the right is made of spring steel and is easy to get on but more difficult to remove, I have a tool I can use for the removal if needed. I don't remember the cost. The picture of the connector by itself shows the slot that the clip is intended to fit in.
Obviously you have to have room in the plane where the clips won't snag on anything important.
