Drive Shaft Flange Bearing Support
Does anyone know which bearing would fit in the hull opening of an Abrams to support the driveshaft?
i know the bearing Id is 8mm, but what about the outside size?
looking to support the sprocket shaft as it seems to deflect a lot under normal use and may cause excessive wear
I think throwing a bearing around that shaft so it doesn't move fore and aft will help everything work better, not to mention limit wear on gearbox.
the one from Germany for 17€ is well and good but I think a much cheaper yet as effective solution can be had.
get a flanged bearing and just epoxy it in place and you're all set.
im going to hit Home Depot this week and see what they have. Will report back.
to run at a higher temperature( where the materials expand and clearances become less) than will be achieved in a model tank.
Bronze ( or even brass) bushings may be longer and support the output shaft effectively; very likely cheaper.
Jerry
