First runs with Skymaster F5, rear fuse way to hot.........
My Feedback: (22)
So I finally got all the install done on my F5, set up is Skymaster F5, AMT Pegasus SP (35lbs thrust) with a Tam pipe.
Did the first run today and the engine was flawless. Unfortunately after a 2 minute run the fiberglass in the rear of the fuse was getting so hot it was getting soft.
Do bifurcated pipes generally run quite a bit hotter? I guess I'll have to pull the engine and pipe and line the back of the fuse with ceramic blanket. Sucks, putting that pipe in is a major pain in the arse. Oh well, beats the alternative of the back end falling off!
I have always lined my jets with this insulation. I just stick it in with red rtv and done. It has worked great for me. That is the hatch of my T-38. I just get it from lowes in the home insulation isle.
David
My Feedback: (22)
Im laying up some NACA ducts as I type this to put into the hatch on the bottom of the fuse and then I will also be lining the fuse with ceramic blanket. Hopefully that does it. What size engine are you using? This Pegasus is putting out 35lbs. I hope the tam pipe will be ok with that.
It is the skymaster T-38 powered by a super eagle 30lbs of thrust. It flys it good, a rhino would be that much better but by no means am i disappointed in the super eagle. Love the jet its my favorite now. And there is nothing between the fuse and insulation. I just rtv it to the the surface of the fuse or hatches. ITs cheap and light. If it gets to hot you will see the insulation will shrink and wrinkle up.
David
David
Greg
ALUMINIZED HEAT BARRIER - ADHESIVE BACKED from Aircraft Spruce
BC, CANADA
Hi Jeremy. I am a member of the Princeton club but we have not met yet. I have some heat shield materials if you need some.
https://duraliteflightsystems.com/in...ry&path=36_160
I live here in BC so let me know if I can help.
Jack
Jack
My Feedback: (22)
Hi Jack,
We haven't met but we have talked a few times. I have a friend that has some ceramic blanket so I'll use that.
As for the rest, I am moving the turbine ahead a bit further from the bellmouth to increase the gap, I've added some NACA ducts on the bottom of the fuse. I'll be adding the blanket all through the back of the fuselage, I've also added a structural brace to the rear wing former. Hope to have it ready for next weekend!
