Spark plug question: One Elec Ignition gives one spark ... another EI gives a burst
My Feedback: (14)
AL
I have a problem with what may be a weak spark when starting my gas engine which has Electric Ignition.. It gives one spark per revolution of the prop... The other EI gives a 5 to 6 burst of small sparks in the same one revolution... This EI came with a DLE 30 about 4 years ago so an older one...
Has anyone experienced this different sparking? If normal... which would be best to use.... ? It seems to me that the multi burst would be better but a friend of mine does not agree and he says he has never seen or heard of a multi burst...
Thanks for your help... Richard
My Feedback: (14)
AL
That is a good suggestion except I am having problems with this engine and the carb.. also.... I am not certain if I am getting fuel to the engine or if the EI is faulty... both spark but differently... I will go with the EI from DLE first and work on the carb... The fuel may not being pumped as I have been unable to see fuel in the engine or on the spark plug.... have worked on it last night and will try again today....my concern is with the appearance of the spark as one seems weak to me.....and working on two problems at the same time is difficult...
thanks....
thanks....
That is a good suggestion except I am having problems with this engine and the carb.. also.... I am not certain if I am getting fuel to the engine or if the EI is faulty... both spark but differently... I will go with the EI from DLE first and work on the carb... The fuel may not being pumped as I have been unable to see fuel in the engine or on the spark plug.... have worked on it last night and will try again today....my concern is with the appearance of the spark as one seems weak to me.....and working on two problems at the same time is difficult. thanks....
My Feedback: (14)
AL
I am going with pump diaphram failure and needing a rebuild... no the engine is not the DLE... I have three DLE's and they have been very dependable.... so I have the DLE EI that I will try on the engine and I will get a rebuild kit next week... will get back to everyone and let them know the progress....
Thanks to all....
Thanks to all....
I think, to draw some better answers to your questions, it would help to know what ignitions we're talking about, and what engine we're working on.
Second, assuming you're working on a "won't start" scenario, and you're trying to figure out if it's ignition or fuel related, a shot of fuel (or even ether if you're in a well ventilated area) and a couple of flips should point you in the right direction. If you get a short burst of power, it's safe to assume the ignition is working fine. If you don't, maybe repeat the exercise and try again. If quiet still rules at that point, it's probably time to have a close look at the ignition.
Hang in there. You'll figure it out.
My Feedback: (14)
AL
It is 5 - 6 small sparks... flash, flash, flash, flash, etc... will not use it at all..... it was in a box of parts from a friend... and I agree... would not use.... it is a throw away for the trash can.... thanks to all for the replies.... I am ordering a new ignition tomorrow... any suggestions?
Just a thought, are both of these ignitions RCXcell? if they are different brands, the Hall effect sensor may not be compatible with the ignition that is giving multiple sparks.
Pete
Pete
And still waiting for an answer. We know one is for the DLE 30, but what is the other ignition from? The multiple firings kinda sound to me like a possible issue with the timing sensor.
Pete
Pete
Hi again Richard , I do believe these two gents are 100% correct that if the ignition box is not a matched pair with the sensor that's mounted to the engine , It's very possible that the box is actually OK , and being falsely triggered the 5 or 6 times by being used with the wrong sensor .
I am not sure but I believe the RC Came Ignition fires more then one spark at low RPM or hand crank speed. Have ask Ralph or Milton.
BCCHI Tired old CH guy.
Yes the RCAME ignitions will fire two times, they do it so fast you can not see it but you can hear it.
The only other time I have seen ignitions fire more than once is a while back when RCexl had some sensors that would fire as the magnet went under the sensor and then again as it passed the sensor.
Milton
Milton
My Feedback: (14)
AL
The engine is a SV 50 CC and has been working great for two years.. no problems.... The E.I.'s are as follows: Peagus, DLE, and S.V., and I would consider only the DLE as a good E.I., normally... It is the DLE that is not firing at all... I am going to order some good E.I.'s soon for this Engine and another engine that I have that needs an E.I....... and stop wasting time on the these off brand E.I.'s that came with two of my engines.... I have 3 DLE's and 3 Fuji's and they all are running great at this time....
The replies have been great and very helpful... I really appreciate your comments, etc... Thanks...
