New Balsa USA Smoothie XL Build
Old 10-29-2016, 10:43 AM
Check6
My Feedback: (427)
Default New Balsa USA Smoothie XL Build
Hello all,
I have been building Warbirds for over 50 years. I decide I needed a break from Heavy Metal with retracts. The new rendition of Balsa USA's Smoothie caught my eye and I was hooked. Bought the kit from a fellow RCU member and then bought all the accessories. It will be powered by a Syssa 30 cc gas engine. has 5 in Dave Brown P 51 spinner. This plane is large and should be a nice flyer. 88 3/4 in. span , two piece wing.
Stay tuned and feel free to add suggestions and comments.
Fred Menna Check6
ID:	2188092   Click image for larger version
ID:	2188093   Click image for larger version
ID:	2188094   Click image for larger version
Old 10-29-2016, 04:19 PM
RICKSTUBBZ
RICKSTUBBZ's Avatar
There seems to be quite a bit of "BUZZ" on this plane.
Looking forward to seeing your build.
Will you be using cloth to cover it?
Old 10-29-2016, 04:32 PM
Check6
My Feedback: (427)
Yes, I will be covering it with solartex fabric. I'm pretty much doing a stock build.
Fred
Old 10-30-2016, 07:45 PM
pappy35
With a 32oz tank you'll be able to fuel it at home, take it to the field, and fly all day. Haha...
Old 10-31-2016, 06:52 AM
Check6
My Feedback: (427)
There are a lot of sub assemblies that have to be laminated before construction begins. Wing joiner is made of 4 separate pieces of plywood. all the main spars are made of two pieces of hardwood laminated together. Some structural ribs are laminated. It makes for some strong light pieces
Old 10-31-2016, 07:03 AM
Check6
My Feedback: (427)
Spars are pinned to the plans and ribs are being installed
Old 10-31-2016, 07:07 AM
Check6
My Feedback: (427)
Install all the ribs, they are all identical and have allignment tabs on the bottom. You then install top spar, leading and trailing edge sheeting shear webbing, wing tip, and cap strips for the wing. You are then able to remove the wing and finish the bottom. Wing is very light and strong.
ID:	2188372   Click image for larger version
ID:	2188373   Click image for larger version
ID:	2188374   Click image for larger version
Old 10-31-2016, 09:42 AM
Check6
My Feedback: (427)
Hang in there guys. I'm taking a slight break from the Smoothie build to finish fiberglassing my 1/5 th scale Corsair. 86 in. span. I need the workbench to lay out the cloth. Will be back soon.
Fred
ID:	2188382   Click image for larger version
ID:	2188383   Click image for larger version
Old 11-02-2016, 02:20 PM
Check6
My Feedback: (427)
OK guys, I have the Corsair all glassed, just need a second fill coat and prime and paint. This will be done in the spring when the weather is better.
Back to the Smoothie!!
ID:	2188645   Click image for larger version
ID:	2188646   Click image for larger version
Old 11-03-2016, 01:08 PM
Check6
My Feedback: (427)
Right panel has been framed up exactly like the left one. The leading and trailing edge sheeting as well as the cap strips need to be installed on the bottom of the wing
Old 11-03-2016, 01:14 PM
Check6
My Feedback: (427)
The left wing is complete except for servo trays and hinging of the flaps and ailerons. It's a good size wing and fits together nicely with the wing joiner.
ID:	2188786   Click image for larger version
ID:	2188787   Click image for larger version
ID:	2188788   Click image for larger version
ID:	2188789   Click image for larger version
Old 11-03-2016, 03:53 PM
RICKSTUBBZ
RICKSTUBBZ's Avatar
Got any pictures of the wing joiner set up?
I had heard it builds as a two piece wing.
But from what I have seen in your pictures it looks as if it finishes out as a one piece wing?
Old 11-03-2016, 05:40 PM
Check6
My Feedback: (427)
Here you go. Two piece wing. I suppose if you wanted to you could glue it together.
ID:	2188813   Click image for larger version
ID:	2188814   Click image for larger version
ID:	2188815   Click image for larger version
ID:	2188816   Click image for larger version
ID:	2188817   Click image for larger version
Old 11-04-2016, 05:16 AM
VincentJ
VincentJ's Avatar
Nice work! I'm a little confused though, what holds the two wing halves together and stops them from separating in flight?
Old 11-04-2016, 05:52 AM
pappy35
Each wing half has a 1/4" tab. Once the two halves are joined together with a 1/4" ply joiner (temporarily or permanently) they key into a 1/2" wide slot in a fuselage bulkhead, you can see all this in the images above but it's a different way to do things and I was initially confused until I got the kit (I'm at the same point in the build). Two conventional wing bolts at the trailing edge then hold the assembly together for flight. This isn't a 3D plane so this seems to be a perfectly reasonable and innovative wing attachment scheme.
Old 11-04-2016, 05:54 AM
Check6
My Feedback: (427)
Thanks, The tabs at the leading edge fit into a slot on the fuse bulkhead at the leading edge and then two wing bolts in the back lock everything in. Exactly like having a one piece wing with dowels in the front and hold down bolts in the back. Hope this helps.
Old 11-04-2016, 05:55 AM
Check6
My Feedback: (427)
Hi Pappy 35. I didn't see your reply, before I answered. I guess great minds think alike. LOL.
Fred
Old 11-04-2016, 06:02 AM
VincentJ
VincentJ's Avatar
Thanks for the explanation Pappy and Check6, yes it makes sense to me now. Not having seen the plans before I was wondering how this was accomplished.
Old 11-04-2016, 06:37 AM
jwrich
My Feedback: (17)
jwrich's Avatar
Thanks for doing the construction thread. Years ago I build at least 3 Smoothies with K&B 40 engines, they were great flying planes. I built one the look like a P-51 and another a P-40. I'll be following your build. Maybe you should join the Balsa USA Brotherhood on this site.
Fair Winds & Happy Happy Flyin'
Rich
Old 11-04-2016, 08:09 AM
Check6
My Feedback: (427)
Rich
Hi Rich, sounds good sign me up.
Fred
Old 11-04-2016, 08:38 AM
jwrich
My Feedback: (17)
jwrich's Avatar
I'll sign you up Fred, just go over to the Balsa USA Brotherhood thread and check it out.
Fair Winds & Happy Flyin'
Rich
Old 11-04-2016, 10:49 AM
Check6
My Feedback: (427)
OK guys, I have the left wing panel construction complete. Servo rails are installed and servos temp mounted. flaps and ailerons are dry hinged. Starting on the right panel Servos are mounted on the bottom of the wing out in the open
ID:	2188901   Click image for larger version
ID:	2188902   Click image for larger version
ID:	2188903   Click image for larger version
Old 11-04-2016, 01:14 PM
R/C Art
My Feedback: (38)
R/C Art's Avatar
Hi, I'm signed in and watching. Have been interested in this plane but haven't pulled the trigger yet.
Thanks for presenting the build.
Art
Old 11-04-2016, 01:28 PM
Check6
My Feedback: (427)
Hi Art,
Go for it. This is a great kit you will enjoy it. I just finished both wing panels. Servos installed and ail and flaps hinged. Starting on the stab,elevators and fin and rudder. I have to laminate the leading and trailing edges of all the tail surfaces. Stay tuned.
Fred
ID:	2188912   Click image for larger version
ID:	2188913   Click image for larger version
Old 11-04-2016, 02:37 PM
smkrcflyer
smkrcflyer's Avatar
Fred,
She is looking good. Are the flaps optional so that you could have a long aileron? I don't need the flaps.
