What charger???
What charger???
II have the following batteries that I would like to find one charger that will charge all of them. I really don't like the cheap ones that come with them from the HL and Taigen tanks.
7.4/1800 mAH Li-ion 2s
7.2/1700 mAH NI-CD
7.2 SC2000 mAH NI-MH
7.2 3800 mAH NI-MH
Would welcome any help, thanks
7.2/1700 mAH NI-CD
7.2 3800 mAH NI-MH
This currently is the one Im looking at,Venom Pro 2 AC/DC Battery Charger for LiPo LiON LiFE NiCD NiMH , model VEN 0677 also the venom pro charger
Here is a easy charger to use if your not good at chargers
http://www.ebay.com/itm/NEW-Dynamite...kAAOSwwbdWPR3H
this ones nice also more advanced like the venom one you looked at.
http://www.ebay.com/itm/Dynamite-DYN...YAAOSw3mpXLczA
I went with this venom pro charger, looks like it has everything I need , plus I have always liked there products.
And thanks everybody for your input, makes things alot easier to decide on.
When you said you wanted the venom pro I was assuming it was a new charger not a very old outdated one,
thought you meant this one?
https://www.venompower.com/collectio...tery-charger-1
Thanks for your opinion, I appreciate it, but anything is better then the stock charger that comes with these tanks that don't give you any idea when they are charged. having to guess is not good for the battery. as for the charger, i like the ones that come with a external balance board. Thats just my preference.
I bit the bullet and picked up a Venom Quad Pro shortly after buying my first tanks. The instruction manual is wanting but I was able to figure it out after a day or so watching the youtube videos folks posted.
For me it has been well worth the money spent and it can keep a steady supply of batteries charged and maintained. I am very pleased with the charger although I did have to pick up two additional Deans Adapter Plugs and three additional Deans to Tamiya Adapters to use all four channels to charge. It came with a good variety of connectors, just not enough if you are only using one style of battery. Minor but potentially irritating detail.
Good to hear your experiences with that one. I've been considering that one to replace my old SuperBrain 977s, whose power bricks seem to be failing. Wonder if I could just use my banana-plug-to-Tamiya cables that I already have on the Venom Pro Quad (or Duo) rather than getting Deans with adapters.
Hi yes you should be able to use your connectors. take a look at the chargers I linked very good for the $ also a good charger is the duratrax onyx 245 2 port charger I been using one since it came out and it works great.
I still using a 989 super brain. Ya I only do one at a time but it's a great charge still. I use a blinky balancer card with it. Never had any problems.
The Venom accepts 4mm Banana plugs and I see no reason you couldn't use your existing cables.
Cool...that's what I was thinking. Wanted to double-check. Thanks.
they got chargers that do 4 packs of any type at once, they have ones ware you use a power supply to power them or ones with built in power supply but they are a pretty penny.
Good info. Thanks. Your link looks like a good charger. I want to stay with doing at least 2, preferably more, batteries at a time. Got more than one tank...for family outings...need to charge multiple batteries at a time.
I like my SuperBrain and it still works in DC mode, just not on AC current (redundant, I know). But, if I'm going to have to spend money on charging, I'm leaning towards getting more capacity with built-in lithium and nickel battery capabilities.
The new Venom has its own power supply. Any idea how it compares to the Dynamite or Hitec x4 chargers?
I like the dynamite X4 versions better they have 100watt X4 and 50watt X4 I like them better because they use 4 screens so you can see charging info for each pack much better all the time without selecting through one screen to see pack info, and they have a better discharge option the 100 watt is 5 amps and the 50 watt is 3 amps venom 100 watt one is only 1 amp discharge.
