Dle 20 ra
Old 02-20-2017, 07:17 PM
rcrmel
Default Dle 20 ra
Any one have experience with the DLE 20 RA ? What weight plane will it fly at least somewhat aerobatic?
The plane I have is the ME 109 It weighs 11 to 12 lbs complete with the engine. Thanks in advance.
Old 02-21-2017, 08:25 AM
egldriver
I have one on a 75 inch span P51 that weighs 15 lbs. Flys it good enough. 16 8 or 16 10 prop about 7500 rpm. 3 blade master airscrew 16 8 turned 6500. 3 blade 15 7 @7800+. Also flew this plane with glow Moki 1.5 answer os 160.
Old 02-21-2017, 08:38 AM
egldriver
Also make sure there's adaquate cooling. Gas engines run hotter than glow. Here's a picture without the cowl on. Use a tach. I put one in the cockpit that plugs directly into the ignition.
Old 02-21-2017, 08:40 AM
egldriver
Old 02-21-2017, 08:42 AM
ahicks
Target for unlimited vertical will be about 10 to maybe 10.5 lbs tops. Good sport performance beyond that will depend on your expectations.
Old 02-21-2017, 03:46 PM
TexasFlash
3D would top around 8 pounds. Good verticle sport flying would be around 10 maybe 11 pounds. Above that consider warbirds.
