RC Radios, Transmitters, Receivers, Servos, gyros Discussion all about rc radios, transmitters, receivers, servos, etc.
Spektrum powersafe rx
Old 03-24-2017, 06:47 AM
KevinSr
Default Spektrum powersafe rx
Hello all, I just recently purchased a 35% Extra 300 fully loaded and turn key ready to fly with spektrum powersafe rx, and 2500mah life batteries. As I fly a dx7, I was excited about the fact of no real set up needed. I now have learned that those receivers have been recalled because of issues that could cause a crash. Yet I can't find description of what is happening to cause the issue. I have been flying spektrum for close close to 8 years and have not had one issue. I am not looking to get into a debate about what radio system is better or worse. I am looking for information on what the problem is with these receivers, and what changes I may need to make. Any info would be greatly appreciated. Thanks all.
Old 03-24-2017, 07:04 AM
Xpress
Xpress's Avatar
Need to know which receiver, only certain ones were recalled.
Old 03-24-2017, 07:08 AM
KevinSr
I will have to look when I get home. So there may be some that are just fine then??
Old 03-24-2017, 07:12 AM
Xpress
Xpress's Avatar
These are the only ones recalled:
https://www.spektrumrc.com/ProdInfo/...all-Notice.pdf
Old 03-24-2017, 07:19 AM
KevinSr
Thank you, when I get home I will look and see what model mine is.
Old 03-24-2017, 08:42 AM
AndyKunz
And if you have one, there's not something you can do to fix it. Send it in.
Andy
Old 03-24-2017, 03:07 PM
KevinSr
Ok guys, I was able to check my receiver in my Extra. I have an AR9100 DSM2 Powersafe rx. Looking at the attachment that Xpress attached, this is not on the list of recalled receivers. Is this correct? So I should be good to use it?
Old 03-24-2017, 03:29 PM
AndyKunz
You are fine.
Andy
Old 03-24-2017, 03:34 PM
KevinSr
Thank you. With the money I spent for it I was really getting nervous to fly it. And I blew my load in one shot on the plane because it was turnkey, so I really don't have the extra money for a powerbox setup from duralite right now.
