TurboHeader Muffler for 4 Stroke Engines
THE TURBOHEADER MUFFLER(TM)
for Saito and Other Four Stroke Engines
The TurboHeader(TM) Muffler's patented design increases the peak performance of your engine by 200-300 RPM, and that's just the beginning. Its sound attenuation chamber brings out a fantastic tone that is sure to grab the attention of your fellow modelers. The TurboHeader(TM) is designed as a compact alternative to the stock muffler and will fit inside most cowlings. It can be adjusted to any angle when coupled with the 90 degree adapter. Custom machined to exact tolerances from high quality aluminum for strength and durability. The new design is welded, heat treated, and clear anodized. The muffler comes fully assembled and installs in minutes.
"Nothing sounds like a TurboHeader(TM)"
Model TH10X1A (Weighs 1 ounce)
Fits: Saito .50, .56, and .62, 100 Twin
Model TH10x75A (Weighs 1 Ounce)
Fits: OS 40-61 FS, Magnum FS 52 & 61, Enya 52 & 80
Model TH12X1A (Weighs 1.5 ounces)
Fits: Saito 91, 1.00, 1.15, FG 14 & 17, 182TFits: OS 90/91FS, FS95V, ASP FS91, Magnum FS91, TT F91s (Requires RCS11x12S Adapter)
Fits: OS110A (Requires RCS127x121S Adapter)
Model TH12x1B (Weighs 1.5 Ounces)
Fits: Saito 65, 72, 80/80a, FG-14, FG-17, 182T
Fits: OS FS70, 72a, 81a, ASP 80, Magnum FS70, 80, 160T, T.T. F75, & F91S (Requires RCS11x12S Adapter)
Model TH13X1A (Weighs 1.6 ounces)
Fits: Saito 1.25 & FG 20, FG 21 (No performance increase)
Model TH14X1A (Weighs 2 ounces)
Fits: Saito 1.80
Model TH14x1B (Weighs 2 Ounces
Fits: Saito 120, 150 & 300T
Fits: Magnum XL120, T.T. 130, ASP 120 & 130, OS 120FS (Requires RCS147x141S Adapter)
Model TH15X1A (Weighs 1.8 ounce)
Fits: Saito 2.20, FG-30, FG-36, FG-57T
Fits: OS 200FS (Requires RCS16x15S Adapter)
Fits: Saito 1.80
