Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
AMPS hulls & outboards pics & tips {Agnew Model Propulsion Systems}
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 02-12-2008, 06:53 PM
specialk1
specialk1's Avatar
Default AMPS hulls & outboards pics & tips {Agnew Model Propulsion Systems}
[X(] I started this thread for thous who are trying to restore their AMPS outboards & hulls and to try help with some tips... if anyone has some old catalogs post them up...and diagrams of the lower ends...maby some knows a shop that can repo some parts ..lets help each other out with these great looking scale out drives and hulls..I know some of us would like to run them instead of them becoming museum pieces like the
K&b sea fury so post up all pics you can ..ken KEEP AMPS GOING hehehehe[X(]
ID:	877097   Click image for larger version
ID:	877100   Click image for larger version
ID:	877101   Click image for larger version
ID:	877102   Click image for larger version
ID:	877103   Click image for larger version
ID:	877104   Click image for larger version
ID:	877105   Click image for larger version
ID:	877107   Click image for larger version
Old 02-12-2008, 11:44 PM
ob nut
ob nut's Avatar
Default RE: AMPS hulls & outboards pics
Very rare T4 with a Fox .40 as a power head. Doubt this motor has ever been fired up.
Rare AMPS tunnel with another rare motor with a Fox 60 Hawk as powerhead.
IH Seebold Racing tunnel with a K&B 7.5 for powerhead.
Out of all of these, hope to get the Seebold tunnel running at some point. The others are collector items and will kept as such.
Nice thread!
Old 02-13-2008, 07:29 PM
specialk1
specialk1's Avatar
Default RE: AMPS hulls & outboards pics& tips
some more stuff...[X(][8D]
Old 02-13-2008, 07:36 PM
specialk1
specialk1's Avatar
ORIGINAL: ob nut
Nice thread!
thanks ..on your Seebold Racing tunnel was this standerd for the power trim??? made by amps ?like mine??1/4 with a os 65[:-]
Old 02-17-2008, 02:47 AM
ob nut
ob nut's Avatar
Only difference to what to the tilt is that the level is vertical instead of horizontal. But yea, thats is the unit on the AMPS tunnel also. You can see the unit in the pic with the driver / cowl laying on the boat.
Old 02-18-2008, 07:39 PM
gas pump bill
here is the amps powered baja . ups just delivered it . boy what a whopper and a verry heavy boat . the engine has internal probs and so does the drive foot. body is in pretty good shape for its age.
ID:	882650   Click image for larger version
ID:	882651   Click image for larger version
ID:	882652   Click image for larger version
ID:	882653   Click image for larger version
ID:	882654   Click image for larger version
ID:	882655   Click image for larger version
ID:	882656   Click image for larger version
ID:	882658   Click image for larger version
ID:	882659   Click image for larger version
ID:	882660   Click image for larger version
Old 02-20-2008, 08:33 PM
gas pump bill
i started takeing the engine apart last knight .the front berring under the starter cone was frosen . its turning now feels like a rock crusher. the piston and con rod is missing and the conection drive shaft from the back of the engine to the drive gear in the foot is missing the prop is missing the cowling is missing but its a nice boat. but i dont understand this thing ways a ton even with the engine removed . oh well its on the way. bill payne
ID:	884289   Click image for larger version
ID:	884290   Click image for larger version
ID:	884291   Click image for larger version
ID:	884292   Click image for larger version
ID:	884293   Click image for larger version
ID:	884294   Click image for larger version
ID:	884295   Click image for larger version
Old 02-20-2008, 08:43 PM
specialk1
specialk1's Avatar
ORIGINAL: gas pump bill
look on eBay for a os 46 duct fan engen all you have to do is take the water cool head off of your's and put it on the new one..how is the pto on it? hope good because amps is the only on who made it[&o]
Old 02-20-2008, 09:20 PM
Oh Yeah!!
Hey Guys,
That is super cool!!..... I didn't know they made anything like that.
Do they still make them?
How do they perform??
Do you have any video of yours running???
Phil
Old 02-20-2008, 11:44 PM
rcollector
ID:	884446   Click image for larger version
ID:	884447   Click image for larger version
ID:	884448   Click image for larger version
ID:	884449   Click image for larger version
ID:	884450   Click image for larger version
ID:	884451   Click image for larger version
ID:	884452   Click image for larger version
coriolan (09-16-2020)
Old 02-21-2008, 07:45 AM
f16man
Ducted fan engines have the carb on the rear of the case and are timed by a disc or drum just like all performance marine engines so I don't know how you would use one for an amps setup......
Old 02-21-2008, 08:49 AM
rcollector
The ducted fan engines are differant but I think he might find the piston , sleeve and rod he is looking for inside of one. I think the o.s powerheads were just regular rear exhaust marine engine cases with airplane engine front bearing housings and a special airplane type crankshaft with a longer crank pin to drive the pto.
Now, if anyone that reads this knows more exactly what parts fit these OS made amps powerhead please correct me and post the information . I am only guessing on this based on the few engines of mine I have had apart over the years. I am really not sure. I am only trying to help by suggesting where I would look if I were trying to find parts myself.
Old 02-21-2008, 09:29 AM
rcollector
If I was going to try to run one of these amps outboards today I would use one with a K&B powerhead because they just have standard K&B outboard powerheads with a AMPS hex drive PTO.
The last one of mine I was running was a Bud Light Seebold tunnel that had a .67 K&B powerhead.
Sure, the o.s. powerheads run smoother but when you break parts you have these problem of trying to figure out what the heck parts are in there and then finding them .
If you run an amps be sure you don't break a gear in the lower unit, you will really have problems finding that.
These are great old ouboard motors with a scale look that just can't be beat in appearance but they are a little bit heavy. Really , today, they are best just to keep on the shelf and look at.
These motors will break gears quite easily if you strike something with the prop and there are no spares to be had, it is not real easy to replace them either. The only way it would be practical to run these again is if someone started making replacement gears .
Old 02-21-2008, 05:35 PM
specialk1
specialk1's Avatar
ORIGINAL: rcollector
true on the gear's ..I gave a set from my 67cc & 3,5cc to a gear shop that fabricates small parts like that .hope to hear from them next week and let me know how much .I also will get the cast mold from them to make more...next is the cowling's I want to fabricate some mold's ..because lots of us have a hard time with them going bad cracking ext ext...and you right i forgot on the OS the crank is different but the piston & sleeve will work.. also have you ever see one with an electric start ..I found this one ..[X(]
Old 02-24-2008, 02:43 PM
specialk1
specialk1's Avatar
some more cool pics i found[&:] I like the gas AMPS outboard & the inboard baja hull[>:]
ID:	887486   Click image for larger version
ID:	887487   Click image for larger version
Old 02-24-2008, 03:09 PM
specialk1
specialk1's Avatar
ORIGINAL: Oh Yeah!!
Hey Guys,
Phil
sadly no .most people just collect them .I wish they where still in business
ID:	887504   Click image for larger version
ID:	887505   Click image for larger version
Old 03-08-2008, 10:01 AM
specialk1
specialk1's Avatar
how is your resort going? wow this one sold on ebay for over $1000. bucks..ouch...0s 65 with racing lower end....did you try to get the other one i sent you the link...
ID:	897669   Click image for larger version
ID:	897670   Click image for larger version
ID:	897671   Click image for larger version
Old 03-08-2008, 11:17 AM
specialk1
specialk1's Avatar
Default RE: AMPS hulls & outboards pics & tips international hobbies
we need to start making molds of these two parts...
Old 03-08-2008, 12:54 PM
gas pump bill
is this a zenoah gas engine on an amps foot? i would love a 1/4 scale gas outboard. thanks bill payne
Old 03-09-2008, 12:08 AM
specialk1
specialk1's Avatar
that one no ..this one is...
Old 03-09-2008, 12:17 PM
WakeBoardnBash
Some awesome pictures!
those engines are looking pretty old yet in excellent looking shape.
Diggin the pics!
Old 03-13-2008, 11:30 PM
specialk1
specialk1's Avatar
ORIGINAL: WakeBoardnBash
Diggin the pics!
thanks ...we will try I like the twin outdrive .that boat belongs to a rcu member
ID:	902916   Click image for larger version
ID:	902917   Click image for larger version
ID:	902918   Click image for larger version
Old 03-14-2008, 12:04 AM
specialk1
specialk1's Avatar
this is what your looking for [&:]Blackhawk Hobbies...dont know if there are still makin this...[] but i think the AMPS one looks better
ID:	902952   Click image for larger version
Old 03-14-2008, 07:01 PM
specialk1
specialk1's Avatar
well more pics for you all .....International Hobbie Formula 402 & Twin Outdrives........[X(]$2,100.00 ...OUCH..[X(] thats a lot...cool hull though[8D]
ID:	903493   Click image for larger version
ID:	903494   Click image for larger version
ID:	903495   Click image for larger version
Old 03-15-2008, 05:45 PM
STEVE MARSHALL
Here is a link to the zenoah outboard bottom end.
http://ovalexpressracing.com/hardware.html
