Composite ARF Tucano Build
Old 04-01-2008, 11:51 PM
P38J
My Feedback: (14)
P38J's Avatar
Default Composite ARF Tucano Build
I started working on a comp ARF Tucano that was put on hold for other projects, so I'll be starting this build tread from the point in the construction were I stopped.
ID:	919752   Click image for larger version
ID:	919753   Click image for larger version
ID:	919754   Click image for larger version
ID:	919755   Click image for larger version
Old 04-01-2008, 11:57 PM
uncljoe
My Feedback: (8)
uncljoe's Avatar
Default RE: Composite ARF Tucano Build
Wayne
You don't get a Break...Work,Work,Work............ Why not go flying Wednesday afternoon . BTW , Ron will give you some Stick Time just remember that Ron wants the Tucano done yesterday, Ha ! That the first one I've seen in Red....
Semper Fi
Joe
P38J
My Feedback: (14)
P38J's Avatar
more photos of the gear and door installation.
ID:	919759   Click image for larger version
ID:	919760   Click image for larger version
ID:	919761   Click image for larger version
ID:	919762   Click image for larger version
Old 04-02-2008, 12:04 AM
P38J
My Feedback: (14)
P38J's Avatar
Hi Joe, we're going to wait till Friday to do some flying, the weather Wednesday is suppose to be windy plus Vin and Ron are going to be tied up for most of the day. I can't wait to get this thing done so I can see how it flies; I think it's going to be a blast.
Old 04-02-2008, 12:12 AM
P38J
My Feedback: (14)
P38J's Avatar
more pics
ID:	919769   Click image for larger version
ID:	919770   Click image for larger version
ID:	919771   Click image for larger version
ID:	919772   Click image for larger version
ID:	919773   Click image for larger version
ID:	919774   Click image for larger version
Old 04-02-2008, 12:17 AM
P38J
My Feedback: (14)
P38J's Avatar
Lighting kit install
ID:	919782   Click image for larger version
ID:	919783   Click image for larger version
ID:	919784   Click image for larger version
Old 04-02-2008, 12:27 AM
P38J
My Feedback: (14)
P38J's Avatar
Stab leading edge extensions installed. some filling was required to get a good fit.
ID:	919788   Click image for larger version
Old 04-02-2008, 01:04 AM
RonLongAZ
My Feedback: (29)
Wayne,
That bird is looking good I think it might just be big enough to fit Joe in it for the maiden
The light install looks great and the plane in general looks impressive.
Ronald R Long
Old 04-02-2008, 08:14 PM
P38J
My Feedback: (14)
P38J's Avatar
I decided not to use the stock rudder servo mount. I used the SWB mount
ID:	920263   Click image for larger version
ID:	920264   Click image for larger version
Old 04-02-2008, 08:33 PM
RonLongAZ
My Feedback: (29)
Wayne,
That looks sweeeeeeeeeeeeet keep up the good work.
Ron
Old 04-03-2008, 09:40 AM
Wren Turbines USA
My Feedback: (39)
HI guys......after two seasons of flying my Tucano and 80-90 flights...it was time for a new paint job.
You are gonna absolutely love the way it flies.........
If you have any questions on the setup....give me a call.
all the best,
ID:	920557   Click image for larger version
ID:	920558   Click image for larger version
ID:	920559   Click image for larger version
ID:	920560   Click image for larger version
ID:	920561   Click image for larger version
Old 04-07-2008, 01:00 PM
kkn
Hi Ron,
who did you buy the decals for the Brazilian grey version from?
Thanks and best regards
J Attard
Old 04-07-2008, 01:59 PM
Wren Turbines USA
My Feedback: (39)
The decals were made on the computer and printed on sticky paper........
For the new paint job I had Ralph Schneider at Tailor Made Decals in Germany design and produce.
[email protected]
Also....here is the new air inlet system........I extended the turbine intake thru the firewall. This is the best possible way to ensure that the motor gets cool air.
Fuse will get the white base coat tonite.
cheers,
Old 04-07-2008, 04:05 PM
2001az
NO1
Why to do that if the real plane (and the kit) has the space areas for the oil radiators?? that can work as cooling exit for the engine?
Arturo
Please see the pictures in the fuse at the center you can see two black squares, those are kind of grids
ID:	924489   Click image for larger version
Old 04-08-2008, 04:14 AM
P38J
My Feedback: (14)
P38J's Avatar
Installing the engine was a long slow process a lot of fitting and fiddling; here are some shots of the engine being fitted and the nose landing gear going in.
ID:	924985   Click image for larger version
ID:	924986   Click image for larger version
ID:	924987   Click image for larger version
ID:	924988   Click image for larger version
Old 04-08-2008, 04:20 AM
P38J
My Feedback: (14)
P38J's Avatar
fitting cowling.
ID:	924990   Click image for larger version
ID:	924991   Click image for larger version
ID:	924992   Click image for larger version
ID:	924993   Click image for larger version
Old 04-08-2008, 08:15 AM
RonLongAZ
My Feedback: (29)
Wow,
That plane is looking really good Wayne.
Ron
Old 04-08-2008, 08:54 AM
uncljoe
My Feedback: (8)
uncljoe's Avatar
Wayne
lookin Good..........BTW how the F86 maiden go ?
Semper Fi
Old 04-08-2008, 09:05 AM
rcjets_63
rcjets_63's Avatar
Ron & Wayne,
Thanks so much for the hospitality this weekend at the Sun Valley field. I enjoyed watching the Eurosport and Lightning fly. Disassembling/reassembling the Lightning was a hoot; too bad we didn't notice that wing mounting bolt as we could have saved some time. Wayne did a great job bringing the Lightning in after the flame out. Did you find the source of the air leak in the retracts?
Jim
Old 04-08-2008, 09:35 AM
RonLongAZ
My Feedback: (29)
Jim,
Yes it was a air line by a main retract. Tire had rubbed. Nice meeting you this last weekend and thanks for the help
Ron
Old 04-08-2008, 12:32 PM
P38J
My Feedback: (14)
P38J's Avatar
Joe the F-86 was underpowered and were're refitting it with a P-80.
Old 04-08-2008, 12:35 PM
uncljoe
My Feedback: (8)
uncljoe's Avatar
Shoot !
Go with a 120 , same mileage ,and most likely Vin has one laying around.
Semper Fi
Joe
Old 04-08-2008, 01:30 PM
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
im sure he has on laying around, he went all Titans is what i think he told me!!
Hey you Valley boys, stop causing havok out there around the old timers, i dont wanna have to bail you outta jail when you stop a pace maker with your low, fast flybys. HAHA
This message was only a joke, if the pun intended effects you personally, i am sorry....it is just an inside joke Nick
Old 04-08-2008, 09:01 PM
RonLongAZ
My Feedback: (29)
Nick,
Always bring your bail money when you go out to fly
Ron
Old 04-08-2008, 09:43 PM
quist
My Feedback: (198)
quist's Avatar
That looks great. When is the maiden?
