1700SP Upgraded to Gaspar ECU
RE: 1700SP Upgraded to Gaspar ECU
The "SIMJET" values are as follows:
Full Power Speed: 120,000
Idle Speed: 30,000
Start Min. Temp 100C
Max Temp : 900C
Accel delay: 40
Decel Dealy: 15
Stability Delay 050
Pump Limit: 1000
Pump start point: Auto+2
Pump Start Ramp: 006
Glow Plug Power: 35
Satrt Gas: 100%
Low Batt. Volts: 6.2vdc
Throttle Curve: FULL Expo
For all other values: us GASPAR defaults.
Idle Speed: 30,000
Max Temp : 900C
Accel delay: 40
Decel Dealy: 15
Stability Delay 050
Pump Limit: 1000
Glow Plug Power: 35
Satrt Gas: 100%
Hi Vampire,
I am thinking about using the Gasper ecu with my simjet 2300.
Do you see any problems with this? is it possible to use the existing RPM sensor? if not can the Gasper sensor be used to pick up the existing magnets?
Best regards
Arthur
Best regards
Arthur
