SimJet Turbine Direct Support Direct support for SimJet Turbines provided here.
Simjet 2300 start up issue
Reply
Old 09-03-2012, 12:24 PM
Philip Cooper
Philip Cooper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Simjet 2300 start up issue
Hi there,
I have a second hand simjet 2300 that has developed a start problem.
The engine always starts first time when its cold, but after one flight if you try to re-start when the engine changes from gas to fuel, the temp goes to 999c, no fuel goes in and the start up fails.
Let the engine cool for a while and it will start fine.
Does this sound like a fuel issue? Pump? Solenoid? Is there anyway to test this with the GSU? People at my club suggest that the temp going to 999c means there is no fuel going in, and its just running on the gas?
Or you think start up setup?
I assume you are suppose to be able to re-start these turbines straight away and fly repeatedly?
Thanks in advance.
Phil
Philip Cooper is offline
Old 09-04-2012, 04:38 AM
Uefly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Simjet 2300 start up issue
Hi!
To me it seems like a pump issue. I had something like your case on a PST 600, and the problem was made by the gear from the pump. The pump was worn out, and as soon I got a new one the problem was over. You can also adjust the amount of gas so you are not getting so high temp reading to see if the pump starts. You can choke the canistervalve to do so.
Uefly is offline
Old 09-15-2012, 12:40 PM
Philip Cooper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there,
Thanks for your reply. If it was the pump why do you think that the engine being hot or cold would affect it?
I had a PM:
Hi Phil
What type of ECU do you have, it sounds like a temp prope problem
Best
Kim
Former simjet worker
However I have PMd Kim a few times with no reply. Does anyone here know how to test the temp probe? And or change it?
My ecu has AU 303 FADEC in large on it....
Old 09-23-2012, 12:14 PM
Philip Cooper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Kim,
Are you still about? Does anyone else know how to test/change the temp probe on these? Anyone know of a place that can service these engines?
Phil
Old 09-23-2012, 05:03 PM
Edgar Perez
Edgar Perez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since you are using Gaspar ECU, you can buy new thermocouple at his store ([link=http://www.xicoy.com/catalog/index.php?cPath=22_25&osCsid=8gt9it1go2c8b6fhfposggknl7]Xicoy[/link])
I guess you can test it by confirming it measuring ambient temp correctly. Then use a flame to raise the temp and confirm it via the ECU display.
good luck,
Edgar Perez is offline
Old 09-24-2012, 01:39 AM
K Jorgensen
K Jorgensen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Phil
Yes still around, I have totally over looked your reply, sorry for that.
I think that your temperature probe has an internal fault, that shows up when heated once. The best is to just get a new one from Xicoy as Edgar suggest.
Hope it will help.
K Jorgensen is offline
Old 09-28-2012, 10:22 PM
Philip Cooper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
Thanks for the replies.
Is it hard to change the probe? Does the front of the engine have to come off?
Are there instructions anywhere? The probe works fine, apart from when on gas at start up. Ambeint seems correct, and when engine is running its showing consistently around 600-700c.
Phil
Old 09-28-2012, 11:26 PM
Philip Cooper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The engine has 40 hours on it now, do you know what the service interval is on these? Thanks
Old 09-29-2012, 03:25 AM
Edgar Perez
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Philip Cooper
Many manufacturers have used about 25 hours.
Old 11-03-2012, 01:09 PM
Philip Cooper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there guys,
He has 3 thermocouples listed there, do you know which one I should order?
Phil
Old 11-03-2012, 08:24 PM
Edgar Perez
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there guys,
Phil
I think its [link=http://www.xicoy.com/catalog/product_info.php?cPath=22_25&products_id=97&osCsid=8gt9it1go2c8b6fhfposggknl7]Thermocouple 150mm N/T[/link]:"K" type thermocouple. Inconel 600 sheated. 500mm cable lenght with JR type connector. Probe lenght 150mm (KJ) engines.
you should be ab le to measure the length of the one you have to confirm its about 150mm.
Reply
Display Modes
