Simjet2300
Simjet2300
Kerry
Should there be a restrictor in the lube line or is it not required in this engine. I've taken the festo off to replace and from the t piece festo to the lube festo there is obviously a very short piece of festo with no restrictor as found in other engines. I hope this makes sense as don't want too much fuel oil mix going to the bearings.
Regards
Mark
Regards
Mark
RE: Simjet2300
Hi Edgar
Thanks for the reply just to get my head round it...under the front cover the fuel line goes into a T piece and then a 90 elbow which is the lube line....is your restrictor inbetween the T piece and the 90 elbow in the 1" run of 4mm festo tube?
Many thanks
Mark
Many thanks
Mark
RE: Simjet2300
You must have a restrictor. The way to do it is to put a new 4 mm tube into the t-festo and then wrap it around the compressorintake one round and then somewhere in between put in the restrictor before connecting to the festoelbow again to the lubeintake :-).
