Starter Motor O-Ring
ON, CANADA
Starter O-ring
Hi Tommy
We have the o-rings in stock and can send you some. Changing the o-ring is quite simple:
1) Unscrew the front cover of the starter housing and slide it a little ways down the starter cable.
2) Take a black marker and put a mark on the motor, at the edge of one of the starter housing tangs. This is an easy way to ensure that after you change the o-ring, you can easily set the starter back to the same depth.
3) Remove the starter motor from the housing.
4) Using a small pick or flat screw driver, gently roll the o-ring out of the end of the bendix housing. If you don't have a spare oring handy, you can flip the o-ring over and get a few more starts out of it before needing to replace it.
5) Re-insert the motor into the housing, being careful to line up the marks you made in step 2).
6) Screw the front cover back on the housing.
That's it.
Ed
That's it.
Ed
