SimJet 1200-18 AES GE help
Hello!
I need to check the parameters in the ecu, anyone have the numbers? i Have a SimJet 1200-18 AES GE (18 Lbs) 80 N.
version is 3.9
This is what i have:
Full power rpm 163.000
Idle speed 50.000
stop speed 20.000
Start min temp 100 degrees celcius
Max temperature 900 degrees celcius
acceleration delay 032
deceleration delay 005
stability delay 050
pump start point AUTO+1
pump start ramp 005
Glow plug power 035
Best regards
Thomas
version is 3.9
Idle speed 50.000
stop speed 20.000
stability delay 050
pump start ramp 005
Glow plug power 035
Best regards
Thomas
RE: SimJet 1200-18 AES GE help
Idle speed 50.000
stop speed 20.000
acceleration delay 015
deceleration delay 015
stability delay 060
pump start point AUTO+2
pump start ramp 010
Glow plug power 040
Thats my reading
Idle speed 50.000
stop speed 20.000
stability delay 060
pump start ramp 010
Glow plug power 040
Thats my reading
Both sets of values presented are accurate as the diff is likely in the Pump performance (Hausel verses Flight Works pumps) thus the differences in the Pump Start Ramp and Accel delay values. Of course atmospheric conditions at the time of adjustments will come into play as well.
Best Regards,
Best Regards,
