View Full Version : RC Pattern Flying
- 14 MZ or 12 MZ for F3A
- Am I the only one???
- Vacuum or Press?
- f3a flying sites Italy
- Futaba wishlist
- Where to buy???
- E Flite 160, X mount will it fit a Axi 5330/FAI motor?
- Outrunner mounting
- BASS-O-MATIC failures with F3A outrunners ??
- Starter Battery ??'s
- New plane!! "the Good Bite"
- turbines in pattern flying
- Carbon Fiber Suppliers
- COG ZNLine Synergy?
- Futaba S9154 for Sale
- Plz Delete...
- Trimming (Rudd mix Vs Side thrust)
- Dexterous 170 THHobby
- 4 blade prop balancing??
- CA Models Eclipse
- Anyone know where to get foam cut
- Painter recommendation
- What Needs Higher Power/Weight, 3D or Pattern?
- Phoenix in February?
- Outside Loops
- Summit III for Pattern?
- How do you fix your canopy
- Pull pull setup for elevators
- Batteries Question - Balancer.
- Global Freestyle ARF suitable for beginning pattern?
- New CAMODEL Plane
- OS-200 Sport
- Servo tray pix please, inspiration needed
- Composite ARF Integral vs BVM Props Shinden
- Stability and CG location
- U/C line as pull-pull on 2meter
- '09 Pattern Rules Proposals
- Hanno 61 replacement
- Comprehensive Precision Aerobatics Equipment List
- K-Factor
- F3A South American, Latin American or Continental (Americas)?
- 2007 NATS Fun and Finals in High Definition Video!
- OS120 AX piped?
- Power plant recommendation for Focus II
- Seeking input for DZ160 and Magnum fuel
- Sanding Blocks and Weights
- World Championship, equipment used
- Fishing antenna through antenna tube in fus
- Have you ever seen this ? Webra 160 cracked!
- new futaba servoes?? BLS 451
- Question for Mike H and Flyintexan
- zeque 70 build
- Help me choose Pattern Plane
- Quantum L
- F3A Electric Spinners
- Nishioka header brace for Hatori 822 manifold
- Model Shops with Pattern Stuff in Geneva
- Antenna Position
- Rudder pull-pull two center points
- F3A 2X2 pattern
- Servo Choice for Oxalys 50
- GP Raster Glow
- Coaxial drives/contra-rotating props for F3A `E`models
- Help me choose my first pattern plane
- DA50 in a pattern plane?
- After 2007 WC, electric f3a or nitro f3a??
- F3A construction
- F3A Leo
- Gator R/C Wing adjusters
- Vinter time!
- Flat and level workstation build thread
- "Faux-Que" New F3A Design Build Thread
- Can someone identify this for me?
- Ron Chidgey's Tiger Tail
- Positive incidence trimming question
- Genesis kit differences?
- New Dave Guerin World Class F3A Design
- pattern plane for 0s 61 engine
- Computing Scores of F3a comp
- Oxai F3A Airplanes
- Painting-Where did I go wrong?
- CofG ??'s
- NMP Long vs Extra Long Axles?
- Jayson Fuel Filter??
- Piedmont Models
- Santa Fe, Argentina Team Hong Kong
- Tank set-up??
- 40% with a little pattern influence
- Shape of TE of elevator
- Angel S Sebart 50 pattern
- Tuning a piped 2 stroke!
- Lunacy of the Week...
- What is the rules
- Which soft mount?
- zen 50
- ULTRA SPORT .60 FOR
- 2007 F3A World Championships
- Nylon coated steel fishing line??
- Electric Genesis for sell RTF
- jaccio regulator
- What simulator to practice pattern flying?
- Buenos Aires to Santa Fe
- crisper snaps?
- Judges Requested for Helicopter Contest
- origin
- Re: Remote Mixture Control
- Webra 160 supplier
- Re: Powerbox & DSC?
- Cajun Nationals Standings!!
- Throttle curve
- If you had to choose between glow or electric Oxalys
- Disstressed Integral owner
- A123 Cells for Receiver Battery Pack
- Last excelleron 50
- webra 160 MC carb with futaba 9c help !
- Typhoon?
- Electric Osmose Building
- Cajun Nat's Friday night "Gumbo"
- Trim Problem
- Venus 40 Powerplant
- FLA VINTAGE PATTERN ASSOC-SPA/BPA CONTEST
- good pattern ship reccomendations
- SLOPE FREE SERVOS ?
- Perry Pump and 2 stroke engine
- Seduction WCR
- cuban 8
- Vehicles for W/C in Argentina
- 14 MZ Spektrum Module
- HACKER A60 or Plattenberg?
- Simple Exercises -- what do you recommend?
- New OS 200 variant?
- This months Kfactor
- YS 160 / 170DZ
- Building Question
- Plane for OS 61RF Hanno Special
- Tojeiro 140 broken wing at snap roll
- Lanier Ultimate Biplane 60"
- ZN Line Integral from Japan
- OS 91 FS for Pattern?
- Still having trouble keeping a slow roll axial.......
- TS Composite
- Sound-level with new engines
- OS 160 pipe?
- World Air Games 2009
- Osmose
- Ferrite Filters
- Model Trimming Chart
- Intruder 90
- Cajun Nationals Preregistration
- New Oxai Aries
- Smarter Starter video
- Webra/Bully 120 RE Parts?
- CA Hinge Off Centerline
- Carf Integral trimming thread
- Tangerine 2007
- OS 140 Power
- BEGINNER PATTERN PLANE FOR A YS 140 SPORT
- Use of KS Pipes - Pattern Setups
- MIDAIRS!!!!
- ProLine V`s Zeque ???
- 2007 F3A Team Raffle
- Epsilon 90 best engine? —Please help!
- Pattern Prop Recommendation
- 3M Monitor 140 / 170
- DR Jekyll 2 RTF
- Futaba 14MZ
- Folks going to the Ft Scott contest
- NSRCA District 3 Champs!
- True 60 sized pattern plane
- Pipe for Leo 110?
- Biplane Advanture
- Post your best F3A pictures from 2007!
- Venus II Engine Poll
- Anhedral stab setup
- venus II or the showtime 90
- YS 63/110 Short Hatori set-up dims?
- os 1.6 & noise level
- Ultrasport 1000
- reducing torque tranmissions into fuselage.
- Li-PO receiver batterys & regulators
- goldberg skylark 56 mk2 help
- Throttle Ratchet vs No Throttle Ratchet
- Nishioka parts
- NEW JR 12X
- Venture 60
- Clogged pipe
- Shinden on sale
- How would performance of ys 110 compare to the typical 61 RE 2 stroke?
- VA State Championship - 22/23 Sept 2007
- knife edge capability
- Do I have a faulty servo?
- Piorun Python and OS 160 ?
- precisionaerocomposites still in buisiness???
- fashion F3A"
- Oxai Infinity pipe tunnel
- JAX, FL - Hotel Rooms
- O.S. 160 RX FI
- Futaba 9Z with Spektrum SPMMSFUT7 installed (pictures of installation)
- Old Rossi FIRE pattern engine
- Focus Sport 110 YS Powered
- *Spot On 120*
- 2008 F3A Aresti Changed !
- intro + Looking for pictures of the original ZNLine Alliance color scheme
- 1.20 for a Venus 2?
- OS-160 Hatori header
- How tight is too tight on an OXAI nose ring?
- Integral Modifications: Beryl wing test
- Modeling has lost a great friend
- Recommendation for two elevator servos
- Pentathlon Kit Build
- Prop Balance
- *Focus Sport*
- YS SS 170 DZ Fi.
- OXAI announced electric F3A motor DYMAXION
- OS 1.60 and Tuned Pipe
- Goldberg Obsession-"Sport Precision"
- P09 videos?
- My how things have changed
- Selecting the right servo's??
- LARKS contest
- OS 160 needs a new home!
- Extreme composite Pro-Line
- FAI f3A Fuel system setup
- Rudder closed loop system
- Scoring Program
- ZDZ 40 RE F3A Soft Mount
- 2007 Team T-Shirts For sale(Signed by 2007 Team)
- videos of you pros out there flying your birds....
- Super tigre 91 in an Avante 2
- Cane Ridge Nash. Tn. cancelled
- Iowa Contest
- Explain "With Options"
- First 2Meter suggestions
- The Dr. Jeckyll Resurrection??
- JAX, Fl Contest - Sept 29 -30, 07
- Entry Level Pattern Plane???
- YS 170
- DIY CF pipe info
- Own design Fromsa 160
- Cajun NATS ...D3 guys have a chance?
- YS-110??
- What motor mount is this??
- The new Focus Sport is finally here!
- ES standard gear f3a
- Anyone Flying Angles Shadow - EVO?
- OXAI Naruke Aries O7
- Extreme Flight Vanquish P07 video
- Excelleron 90 need info
- 40 60 or 90 Size for First Pattern plane.
