View Full Version : RC Pattern Flying
- my pattern plane feels to flexible
- Gator Wing Adjusters
- Difference between pattern and 3D planes?
- Anyone flying a Contender? Couple Q's
- Dick Hanson Planes
- Improve (inverted) flight performance by 'trimming' both ailerons up?
- If You are Looking for an Entry Level Pattern Plane...
- A little change on my 2ยบ Epsilon
- EZ Pilot Manta 50 class trimming questions?
- Eclipse CF wing tube and landing gear
- BEST & NEW ARC F3A 2m IMPULSE
- Orbit M-SAver Ultra Instructions
- Getting started - .75 Pattern plane suggestions?
- Lateral balance fine points (Trimming(
- Onyx with Vebra 160 xp
- Help with Hacker C50 mounting
- Phillips Mistress
- C.Goldberg Ultimate as pattern flyer is it possible
- Setting wing and stab tubes accurately
- Perry Oscillating Pump
- Explorer or Excelleron 90 with 120 4C anyone?
- Funtana 40/ . 50 sx
- Own design - couple of questions
- Confusion on Spins and Snap rolls
- CA Widebody ARC
- MK Alliance CP (50 class)
- new.. fliton infinity 90
- Sulphur Louisiana Contest (LARKS)
- Fucus 2 Wings needed
- New!OTOP Xtreme Composite Pattern Plane
- CaModel Eclipse or MK Topstar II
- WOT 4 Aerobatics?
- 3D Quest
- Header Question
- 4 aileron setup??????
- CA models ZAFIRO impresions?
- Is there any info for the Zen iii ARF kit
- Widebody 60 & y.s. 110FZ
- G2300 wrap around header(where to get?)
- Pics of my Widebody 40, I think?
- What are the consequenses of increasing tail moment in a Plane?
- Need help posting pic of plane
- Widebody 40 and saito problems, need suggestion for another motor
- MK Wild Beat 777
- Equipment Choices in Pattern
- Epsilon fuel line question
- Value of Kwik Fli III
- YS 160 Dingo
- George Hicks Joins Team RCU!
- 10s2p or 10s3p li-po better????
- Tuned pipe for a Saito 150?
- MK engine mount ???
- Pattern Prop -4- Saito .82????
- Is this it? The new Futaba 14 channels?
- Another Retract Question - Use on Grass
- Dirty Birdy 60
- malibu 1.20 info needed
- Matt Fritz.. Suxess Foamy Biplane pictures
- Webra 1.45 Aerox Redhead won't idle?
- *Tuned Pipe For Super Tigre G-75*
- typhoon 2000
- OS 61 rear ex. w/pump long stroke vs YS 1.10
- Icepoint build up.
- HELP
- OS140RX Versus OS140RX-FI
- Onyx 140 ARF
- CA Models
- Coments on Hirobo Stream 90
- International Junior F3A Championships in Moscow 18.-19.9.2004
- Two Stroke Couplers
- Landing Gear...but More!
- Aeroslave Symphony Flies
- JR Datasafe for 10x vs. XP
- 160 FI Props
- Retracts
- Freon 134 for retract systems
- MVVS for pattern
- first time flying a pattern plane.... sort of
- Elation?
- arresti III
- Suggestion on Engine for MK Skystar 90
- Zen 50 Servos
- FOCUS II Stab fullering just like when a Bird wing when flying.
- Dan from HCRC
- Saito 100 for Pattern?
- NSRCA District 3 Champs rescheduled...
- Eye Laser TReatment
- Hollister contest
- I need the pattern Force???????
- Saito 150??
- Gator wing adjusters question
- wing tube on 70'' plane
- Costs of Operation - YS v.s. OS
- SPA Pattern Contest- Oct 1-3- Auburn, Alabama
- Hobby Shops
- Anyone using Central Hobbies electric starter?
- Desafio's dimension?
- Hirobo Astral X 100
- What Tach are you guys using?
- Springfield MO Pattern Event
- Ultra-RC 3D Quest
- Any pattern flyers near Indy?
- Has anyone flown a Ursa Major 25 ?
- Excelleron 90 / AeroSlave Symphony
- New Solid State RX Switch
- Building techniques of pattern flyers
- Calling all YS people! HELP!
- Question about Troy Newman's Elevator setup...
- Cermark Javelin II and Saito 72 good combo?
- Oxalys trailing edge - why?
- Corvette Pattern Plane ???
- Pattern petrol questions
- Engine mount question
- TigerTail(IV) kit or plans
- 2M ruling
- Epsilon, Widebody or Excelleron?
- best prop for WB 60 & .91FX?
- Model Builder plans - Tiporare????
- Huntsville Pattern Meet
- Aurora pricing?
- Prop/suggestions for H9 Aresti and tt.46
- Prop for a Super tigre 90?
- Picco 61 rear exhaust
- Petrol for F-3A
- Hangar 9 Aresti as beginner pattern plane?
- YS FZ-110 FUEL?
- OS RX 140 RX Bearings??
- PATTERN PLANE
- What's your solution? A funny problem about weather.
- flight sim recommendations
- gitano .60 and loaded dice??????
- Dingo Plumbing
- Newbie Prop Question
- What is the theory behind
- Pattern Plane
- Advice
- Arresti III Stock Update
- VEKO F3A PATTERN
- Gas engine for 2 meter?
- Sealing hinge gaps
- Hurricane insurance for pattern planes?
- SYNERGY WING/STAB
- Header for YS engines
- New Revolution Pro broke in half while flying!
- Nederland Pattern Contest.. Thanks
- Where to get
- Axi Set up used in F3A models?
- Carrera ?
- fuel position in tank
- Coming to Nederland? Bring your foamy!!..
- Great Planes Venus Center of Gravity?
- .60 Rear Exhaust Engines
- OS 160FX tuned pipe
- TT 1.20 RP
- NEED HELP can you name my patternship ?
- CA Epsilon details required
- MOTORI MINTOR 140 V/S OS 140 RX
- A Big Thank You
- Finding right pump pressure on Webra 1.45? AGAIN!
- Website link to F3A Euro Champs - Just in case you don't know
- Kaos 40
- Tuning Perry carb and pump ST 2300
- GWS formosa
- Foam source for cores?
- f3a artf
- Am I dreaming? New design...
- Elevator Servos
- Nederland, Tx Pattern Contest... Aug 28-29
- ZN line OXALYS: anyone?
- Black Horse Models Bravo
- Supreme/Enigma wing patterns
- webra speed 91 aero
- widebody 60 pics and info wanted
- Why use an 11x9-10 on my OS 70?
- ES Composites CF landing gear
- Piedmont Brio
- F3A European Championship - 2004 - Portugal
- Rx batteries
- Futaba S3151 Digital Servo
- The Saphir 120
- Wing Incidence
- Problem with YS 140L
- Starting F3a in the UK
- Widebody 60 fly 3D?
- NVRC pattern Contest 21/22 Aug 2004
- Violant snap rolls
- Interesting discovery on ST2300
- Canadian F3A team website
- Aquarious
- Hacker Master 77 3P OPTO ESC
- Sportsman?
- MK Topstar 2
- Pattern model trimming
- Need help tuning my OS 61RF-P
- CA Electric Fantasy
- Avance good winter model?
- Website for CA Models
- YS 110 information
- Cermark Javelin II C.G?
- US Pattern Manufaturers
- what prop for a 40la on a xtrem lite?
- Futaba 9550 gears
- Fascination? the $100 pattern plane?
- Fliers in Kalamzoo, MI area
- Tuned Pipe or Silencer for YS 140L
- MOVED: The Seventh Hotlanta Senior Pattern Championship
- CA Models Eclipse: wing incidence adjusters
- Titanium bolts to reduce weight.
- Prop size for AX .46 on Javelin
- Throttle servo position
- YS140 sport - props
- What prop to use???
- Value of Digital Servos
- Swallow on ebay
- Crow's landing field....
- PL Products airplanes in October - Patternproz
- OS-MAX 140 RX-FI
- WM Zen 30 power question
- Patriot plans?
- OS 1.60 Pattern Setup
- WEBRA 61F LS (1033) TUNNING HELP
- Whats A Good price for used Cap 9 ?
- Swallow and OS90 pump
- Servo Reliability - 2 Metre F3A Models
- bob smith models
- Hitec 5245 MGs
- Performing the Advanced 403 45 degrees inverted dive w/ one neg. snap, exit inverted
- Can't decide, HELP! Javelin ll, ZEN 50, Tai-Ji 40
- Another eclipse ready to fly!
- Looking for a 60 sized pattern
- Pics from the Nats
- Webra 1.20 header
- Do I need to pump a Saito FA100 ? ? ?
- Great foam cores, great service ...
- My Nats trip
- Lubbock, 29th High Plains Champ
- Making a Nose Ring Mount???
- Piedmont motor mount question?
- Your Pattern Plane
- OS46AX in Funtana S 40 for pattern flying?
- Tank dimensions needed
- What size wheels for the big synergy wheel pants?
- Anyone use the new Futaba 7C for pattern?
- YS 140 WON'T REV UP,WHY?
- JR PCM-9X - HELP ME !!!
- Tai Ji 40 vs. Zen 50
- CMPro Swallow engine/prop advice
- Focus II F3A Setup
- First Pattern Plane
