PDA
View Full Version : RC Pattern Flying
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Prop size for YS 170DZ on a black Magic
  2. Houston Pattern Contest May, 4th-5th
  3. Power Box Core RC system
  4. Ys dz 180 cdi zero
  5. Japanese pattern class
  6. Vehicle for hauling Pattern Planes
  7. Servo Gear replacement BLS173SV
  8. elevator servo
  9. Cajun NATS 2018
  10. Cajun NATS 2010
  11. 3 blade spiner for ys
  12. Great Planes Factor 30cc
  13. 2019 Pattern Nationals
  14. Osiris is canopy needed
  15. Aircraft storage
  16. 3 blade prop YS 185
  17. Can OS 1.40RX replace YS 1.40?
  18. Fort Bend Contest, Rosenburg TX
  19. Home for OS 1.60
  20. Supra skybolt
  21. Future Nationals
  22. Electric conversion
  23. 2018 u.s. Nats
  24. Thunderbolt
  25. Napa pattern contest
  26. DZ regulator adjustment
  27. Plettenberg xta 30-10 evo/Schulze fut 32.55kA
  28. 2018 Jetero Pattern Classic
  29. Henry Piorun Olympian
  30. 2 cycle engine for F3A
  31. A Good Snap Roll
  32. New to 2x2 F3-A
  33. Double Key
  34. "Aerobatic" primer
  35. Pattern Classifieds Change
  36. FUTABA Telemetry GPS sensor SBS-01G
  37. 2018 Begginer's Pattern Clinic
  38. Identify this part in my kit
  39. Zeus
  40. Allure Bipe/YS-185 DZ
  41. Ys dz185 zero
  42. Gyros in Pattern
  43. SENSATION +, Build Thread by ISAAC NAJARY
  44. Thinking out loud about reusing a wing set...
  45. Biplane vs monoplane
  46. F3A Zone Pro is now iPhone and Android!
  47. YS DZ200cdi
  48. 2017 Cajun Nats
  49. ACP E-Z Vac Vacuum Pump
  50. Newbe to pattern flying could use some propeller sizing advice
  51. Geared motors - super efficient, when they work...
  52. World cup
  53. What is my 2M worth?
  54. Looking for a crashed soft mount
  55. Axiome+ T-Can anyone?
  56. White Sands Pattern Contest 30 Sep-1 Oct
  57. Marking out a F3A box - F3A Zone
  58. Unexplained Crash of Shinden pattern p
  59. Culpeper va Contest
  60. 2017 NATS - Question about photo coverge
  61. Pattern Biplane
  62. Auction to support 2017 US Team
  63. Here we go......
  64. 2017 Nationals
  65. Flaperon use for F3A ??
  66. Encore
  67. Fuel proof clearcoat
  68. Need engine mount for Oxai Astrall XX
  69. shenandoah Pattern classic
  70. Piedmont Focus Sports
  71. FARM Pattern 20-21 May Bealton, VA
  72. VENUS II Replacement
  73. Sacramento Area Modelers 2017 Spring 1 Day Pattern Contest May 13
  74. YS check valve
  75. 3rd annual Bear Mountain Flyers Pattern Showdown Arvin, CA
  76. SPA Top Novice Event Prattville Alabama
  77. Oil for YS 185 CDI
  78. Hacker Ditex Servo Review
  79. 2017 Orange County Pattern Challenge at OCMA
  80. Spektrum AR6600T or AR6270T for 2M F3A?
  81. YS user seeking sympathetic ears :(
  82. Oxai Galactik
  83. BJ Craft Element
  84. Looking for an Air frame
  85. modern equivalent for a futaba 9c transmitter?
  86. Pattern Clinic in Georgetown, Tx
  87. Looking for a tuned pipe for a YS61 long stroke.
  88. More DZ170 questions
  89. Ys 185 cdi red
  90. Allure Build for YS185 Cdi
  91. "Pattern Camp" Feb 11th & 12th Arvin, CA
  92. Ys 185cdi
  93. 170DZ prop size
  94. YS drive washer issue
  95. Flight Simulator on the Big Screen
  96. Stick Plane
  97. Great Planes Sequence Pattern Plan
  98. 18sz
  99. Spiraling Slipstream OR Coriolis Force? You decide. . .
  100. Motor mount question
  101. Using a vinyl cutter to cut covering
  102. EDF 90MM F3A style. Design, Build and Fly
  103. 2017 Cajun Nationals
  104. 2017 wc - argentina - go to website
  105. .90 Size ARF Pattern Plane
  106. 2017 - world championships - argentina
  107. Lower classes incentive for less expensive planes .Pattern
  108. District 3 finals Jacksonville Fl. Nov. 5th &6th
  109. Help needed
  110. Soft mount and engine movement
  111. October 1-2 College Station Texas Contest
  112. District 6 White Sands Pattern Contest Oct 8-9
  113. "Props & Brats"....Getting Pattern started at your club
  114. Qualifying to attend the Nats . . . .
  115. D-6 contest
  116. New to me 2 M plane
  117. spektrum AR610 Receiver
  118. '87 F3A Worlds/G. Naruke/Aurora 60
  119. Pictures from the Culpepper
  120. Arvin TOO ! Contest. Sept 10th & 11th
  121. Trying to get a feeling for the price of used YS engines...
  122. Bryan Hebert / CK Aero and the LA floods
  123. Tenth Anniversary St Clairsville Pattern Classic
  124. Omahawks Pattern Contest - August 13th - 14th
  125. We've lost another gem
  126. LVRCs Pattern Contest a.k.a. Budweiser classic revisted
  127. Mejzlik carbon prop for YS 185 CDI
  128. 2016 Cajun Nats
  129. 2016 Weak Signals Pattern Contest !!!
  130. Funny how the flight characteristics change...
  131. Osiris 62 inch hatch needed
  132. Fai/f3a 2016 ec in untermunkheim
  133. Summit 120
  134. European championship F3A 2016
  135. September D7 Fresno Pattern Contest CANCELLED
  136. aeroslave symphony
  137. Nats 2016
  138. Geometry of Cuban 8
  139. MK TOPSTAR 2 info required.
  140. Pattern out runners in the 300.00 range
  141. My new F3A model Sagittalis
  142. Allure Bipe by Bryan Hebert of CK Aero
  143. Great Planes Sequence 120
  144. Black Magic 90 size
  145. P-Effect
  146. Piedmont Temptation-CG
  147. Composite pattern plane. Where to buy??
  148. Radio Recommendation
  149. Becoming a Good at F3A - What does it take?
  150. Black Magic VF3
  151. Ys 185 cdi throttle curve
  152. Datum line on Black Magic
  153. Setting Up servos
  154. Os max 46 la silvair 13393
  155. 61th Kansas City Area Pattern Contest on Memorial Day Weekend
  156. Lighter Flange mounted Nose Ring for YS engines
  157. Pattern in houston area
  158. Shenandoah Pattern Classic
  159. YS 185 Header leaking
  160. 2016 Panamerican Open Championship - Medellin COLOMBIA.
  161. s3270sv for throttle
  162. SCRC, Katy (Houston) TX Spring Classic Pattern Contest 4/30-5/1
  163. Building a Pattern Aircraft
  164. Sacramento Area Modelers Spring 1 Day Contest May 14
  165. F-17 Barrel Roll
  166. Superstition Pattern Contest
  167. Futaba 18SZ mix
  168. New AJ Aircraft 2M Pattern Model Avail. 2016-ish
  169. Hudson Valley, NY (D1) Pattern Judging Seminar
  170. Excelarator airplane
  171. Pattern Judging Seminar in Northern Virginia
  172. Need manual or setup help for new pattern plane.
  173. F3A Servos
  174. Lipo Chargers
  175. Transportation from west to east NATS 2016
  176. Mythos - 125 parts
  177. 2016 Orange County Pattern Challenge at OCMA 4/2-4/3 2016
  178. 2nd annual Bear Mountain Flyers / F3A Unlimited Wild West Pattern Showdown
  179. RC Flight Assist - F3A training and learing system
  180. Trimming a Brio 2m
  181. Georgetown Texas Pattern clinic & contest April 2 2016
  182. Any pattern flying Port St. Lucie Florida?
  183. Hacker/Ditex servos
  184. Flying in the New Orleans Area
  185. Dave Brown Vibra-Damp Mount rubber isolators deterioated/rotted
  186. Futaba 12FG and S-Bus
  187. Appropriate servo for airframe
  188. 400'
  189. Painted wing, stabs and advanced graphics
  190. K&B 100 engine for pattern plane
  191. OPINIONS: Combining SPA/CPA pattern and AMA/FAI Turnaround pattern contest
  192. Two stroke for GP Sequence 1.20?
  193. Jacksonville District 3 contest
  194. Ys ignition plug
  195. Allure Glow Build
  196. Original landing gear wanted for wistmodels prestige
  197. Best Backyard Foam Practice Plane???
  198. D7 contest this weekend in Lancaster, CA
  199. Prophecy for lower level AMA?
  200. D1 vs D2 Hollywood, MD pattern contest
  201. 2x2 Electric motor choices
  202. PVMAC (Prado) AMA/& Classic Pattern - October 3rd and 4th
  203. D6 Pattern Contest, Alamogordo, NM, 10-11 Oct
  204. Pattern returns to Prado field Saturday Oct. 3rd 2015
  205. 2015 cajun nats
  206. D3: 47th Annual Rocket City RC Pattern Contest, Sept 19&20, 2015, Huntsville, AL
  207. Beloved YS53 bit the dust & a question
  208. NSRCA District 3 finals
  209. Dick Hanson Runaway
  210. "Blunt" trailing edge
  211. Axiome + wing
  212. D6: September 26-27th 2nd Annual Brazos Valley Fall Pattern Contest
  213. Build your own 4Csoft mount?????
  214. Good afforable .46 size pattern plane for 401 sportsman pattern sequence
  215. 2 Meter Viper question
  216. Ys question
  217. Futaba 12FG again
  218. Need Canopy for Integral
  219. Geared starter
  220. St Clairsville Pattern 2015
  221. D7: Morgan Hill one day pattern contest August 22nd 2015
  222. Pentathlon EVO canopy
  223. Pattern Contest
  224. Switched to Mode 4 - Sucess ! - Try it
  225. 2015 f3a worlds in switzerland website!
  226. YS 185CDI vs 185CDi Zero
  227. CA Models, F3A Mystery
  228. Vanquish flies slightly nose high.
  229. Looking for a 10s motor for a sebart mytho s 125e
  230. How to spin
  231. Lightweight trailers for pattern planes
  232. YS 185 pump
  233. Nats & F3A World Championship Coverage
  234. How about just one horizontal roll?
  235. Saturn 2 Meter question (Is this secure enough?)
  236. How to advice wanted- set up three horizontal rolls to a switch ?
  237. NSRCA District 7 Davis/Woodland Pattern Spectacular
  238. TRI- Village Pattern Contest June 27, 28 2015
  239. Pocono Pattern
  240. Harrisonburg VA Pattern
  241. Nsrca district three nats attendance
  242. Balsa Pattern model finishing/painting techniques
  243. Texas Republic Clasic Pattern Contest
  244. Wanted - 1/4Scale Great Planes - Patty Wagstaff - CANOPY please
  245. Oakdale CA Contest
  246. 2016-2017 sequences
  247. need instruction manual and/or plans for Black Magic VF#
  248. Good pattern setup/settings for Phoenix sim
  249. FARM pattern contest May 23-24
  250. Fresno/Clovis pattern flyers
