PDA
View Full Version : Electric Training
Pages : 1 [2] 3 4 5 6 7 8 9 10
  1. New To Electrics
  2. Beginners question
  3. lipo and ecs
  4. Easy Star Throttle on/off?
  5. Beginner with questions
  6. GWS Zero needs more power
  7. Slow Stick and the wind.
  8. Whole New World From 10 Years Ago
  9. Electric Motor Blues
  10. Beginner needs more power for Paramotor
  11. Lipo charger wiring?
  12. nexstar ep or eflite t-34 mentor
  13. Lipo Plastic Bags?
  14. 55" cessna as a second plane? Need Professional HELP
  15. Slow Stick Power Recommendations
  16. UBEC help please...
  17. Second plane advice!!
  18. Need advice on prop adapter
  19. Step by step (package) for a new-bee RTF
  20. Looking for new trainer
  21. LiPo battery discharge rate!
  22. where to get parts for (Famous )Cessna 206T
  23. need help
  24. help with first flights of a vapor RTF
  25. Cox EP380 4ch Trainer maiden...my first ARF.
  26. BP Hobbies U2212-10 Ultimate Brushless Outrunner
  27. Newbie in need of help
  28. Looking for a speedster
  29. Electric must haves?
  30. amps
  31. Anyone Going to the WARM Show - Feb 19-21
  32. Buzzard Bombshell conversion
  33. Is this a good set-up?
  34. what power plant for 1/2 scale foam dazzler
  35. Lipo Safety
  36. Battery Size? What is next?
  37. Electric twin, strange operation.
  38. all fixed
  39. ESC to use for a super Cup
  40. brushless motors unwind?
  41. Polycharge & Cell Balancer
  42. fist time with a plane
  43. ordering from HobbyKing
  44. Converting stick 40 plus
  45. connectors, ec3. deans,4mmbullet HXT which is better?
  46. Twin Engine question
  47. Should I sell the Super Cub?
  48. Parkzone Corsair or T-28 D?
  49. Blade 400 training gear
  50. Having just purchased a Dx 5e Tx, can I use it to fly my clearview sim.? and how do I hook it up?
  51. why are some lipos cheap and others expensive?
  52. Propeller installation : Sepac Mentor
  53. Elevon problem..
  54. blizzard landing aid
  55. charging battery
  56. What is the slowest, most forgiving electric park trainer
  57. motor suggestion
  58. Getting into electric flight... thought on this sim.?
  59. E-Sky Buddy Cable
  60. what simulator?
  61. Recommend a battery for this motor/esc combo???
  62. Did I jest get a Bad ESC?
  63. Motor rotates as I tighten prop
  64. Paintaing on Zfoam
  65. What motor, esc, and batt to use???
  66. ParkZone chargers and batteries, are they quality?
  67. flying simulater or airplane fist
  68. NEW TO ELECT.
  69. Apprentice 15e Nose wheel steering
  70. ESC question
  71. should expo be used on 1st time trainer?
  72. best prices on lipos?
  73. What plane to get next?
  74. Mentor vs EasyCub
  75. Switching battery and radio question
  76. Apprentice 15e
  77. Brushless Motor/ESC/NiMh Battery
  78. Brushless help.
  79. How about a DW Foamy for my first plane ??
  80. Mounting prop on slow stick
  81. any one know of a good trainer with a 38inch or less span?
  82. New flyer- eflite Apprentice 15e
  83. PRECISION AEROBATICS ADDICTION
  84. Landing on a Grass Strip
  85. warm li-po
  86. Battery Help
  87. motor,esc and prop set up?
  88. Electric Power Suggestions For Midwest Tri-Squire?
  89. Hobbico Nexstar Mini EP 2.4Ghz RTF and Rx-R
  90. Electric Configuration (Air)
  91. Help please
  92. Good 5th Plane
  93. Wattmeter Question
  94. Setup Question - AMPS seem high
  95. Cell pro 10s AC power supply what DC connector
  96. What do you do for training while flying?
  97. Zero Experience but Interested in building my own...
  98. Relationship between cell and prop ?
  99. Esky Nemo, CG question, nose dips
  100. 29 pound 3rd scale Cub going electric?
  101. Lots of sim time, but what kind of first plane?
  102. do Li Poly batteries self discharge
  103. Thermik Dream
  104. Will These Batteries Work??
  105. help with charger/batts!
  106. Ni Mh Charging question....Help!
  107. Hobbyzone Firebird Phantom Trim Help
  108. First RC plane
  109. Spektrum and FS one compatability
  110. mixing servos
  111. Need a little assitance with my first purchase Edit (Now a diary of my attempt to fly)
  112. Programming an ESC
  113. Motor & Battery Selection
  114. Spektrum Radios With Super Cub
  115. Any cheap trainers out there?
  116. New to planes - Want to learn something new
  117. Time to upgrade from the Eflite Apprentice! yay!
  118. broken wing what to use
  119. DX5e settings reset
  120. Music on the BEC???
  121. Lancair ES questions (great planes)
  122. BEC question
  123. Wood Glue versus Epoxy
  124. R/C Timer Brand ESC
  125. Need help with electronics.
  126. new piper cub wont fly...HELP??
  127. Question about landing.....
  128. emax 2215/20 peeping
  129. New to all this electric flight I need help!
  130. Arming motor using transmitter
  131. Stability of foam plane.
  132. kis this battery the right one for me
  133. First Plane help, please!
  134. Twin motors set up.
  135. Turborix Tx programming problems
  136. Battery for Power 46
  137. B24 4 engine Electric conversion???
  138. new to planes,Need a little help.
  139. Free tips for new Electro pilots!
  140. Burned it Up!!
  141. How to program brushless ESC
  142. Buddy Box Question Hitec Neon
  143. Electric flight books
  144. Flying in cold temperatures
  145. Electric Equivalent of .049?
  146. Kadet Seniorita EP 63" wing span
  147. Power system for Miss STIK Junior/ Slowstik
  148. Help setting up DX6i
  149. Slo V Question.
  150. battery questions
  151. How Long to Charge....
  152. Futaba S3107 Micro compatible with Hitec Supreme IIS FM receiver?
  153. Question on mounting engine
  154. I already have a TX and Lipo's but what trainer?
  155. How do I program my ESC voltage cutoff
  156. Electric prop injury.
  157. A dumb question
  158. Speed control problems
  159. A123 battery setup
  160. Hobbico Electristar question
  161. Speed Control
  162. breeze trainer 40-ep
  163. new to electrics- i need help choosing the right system
  164. moving to electrics
  165. Looking for T-Hawk
  166. What plane is the best to use A123 batteries?
  167. CNC cutted EPP airplane
  168. First Plane?
  169. Motor Load
  170. Ever just want to hand a noob something they cannot handle?
  171. Lipo newbie please help
  172. Squirt 700 brushless motor
  173. New to Electric Plane question
  174. hyperion duo charger
  175. Flight Simulator Recommendations...
  176. Calmato 1400EP airfoil.
  177. 2 to 6 cell lipo testor
  178. Battery switch
  179. I hate to do this, but..
  180. I want to start flying airplanes.
  181. Super Cub Or Apprentice 15e ?
  182. Indoor electric "Spider"
  183. How to wire a brushless speed controller?
  184. Reverse the direction of a brushless?
  185. Charging batteries
  186. Designing and building!!!
  187. which plane?
  188. Reciever question.
  189. Who knows about an arf Twin Otter?
  190. Powering up a Ryan
  191. help me to find brushless
  192. Complete Li-Po info
  193. Just purchased a supercub
  194. Predator parts list
  195. need help picking a new plane
  196. Battery Wiring for multiple packs
  197. Going Electric
  198. Motocalc & sig rascal 110
  199. MiniMag Perfect Brushless System??????
  200. HOW TO DO ROLLS
  201. Aerobird Swift Aileron Trainer???... My personal experience
  202. Help with a solid trainer
  203. Hitec CG-335 Charger
  204. ESC shutting down at WFO
  205. Looking for recommendation please
  206. need help configuring an airplane for electric flight.
  207. Stryker B Controller and Aerobird 3
  208. ESC Choice
  209. Zacki Elapor glue
  210. Hobbizone Arobird Swift
  211. E-flite Apprentice 15e RTF w/DX5e Radio
  212. Minimag
  213. What are the benefits of going Lipo vs Nimhs?
  214. E-flite Apprentice
  215. Falcon 56
  216. Charge New Batt.
  217. reciever voltage
  218. Which servos
  219. lipo's in my nexstar ep
  220. Multiplex Mentor
  221. Parkzone Spitfire or Hobbyzone Swift
  222. Very good trainer!
  223. 2nd Plane Help
  224. LiPo Care
  225. receiver question
  226. Multiplex USA Mentor kit question
  227. newbie question
  228. ugly stick plans
  229. Balancer question
  230. Is this correct about charging Lipo's
  231. 12 pole motor / 10 pole ESC
  232. test running on ground
  233. Drop Module
  234. Don't know what to do or where to look!
  235. New to 4 channel transmitters, please help.
  236. Newbie Question - Battery Management
  237. Flyzone J3 Cubtai
  238. Easy Helicopters to fly?
  239. Slow, Easy, Indestructable
  240. Broken Super Cub
  241. First Plane
  242. Monster Power 160 245Kv
  243. How to connect Motor and ESC
  244. First Electro Acrobatics
  245. HobbyZone Firebird Freedom Electronics problem
  246. Looking for brushless combo for Mini-Mag
  247. What LIPO do you use?
  248. Better battery charger ?
  249. Super Cub advantage?
  250. nexstar brushless ep
