PDA
View Full Version : Extreme Speed Prop Planes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23
  1. Speed trials in the spring ?
  2. Fast airfoil for a Delta
  3. What servos?
  4. Jett 50 and Shrike 40 Questions
  5. My first day with a whiplash (193.8)
  6. Whiplash hits mountain at full speed!
  7. Another Whiplash does 200+ MPH
  8. Weston Magnum - Destroyed on First Flight!
  9. Bottom Color of Whiplash?
  10. How heavy is your "Whiplash"
  11. My extreme speed machine
  12. Just picked up another R65!
  13. Fast Real fast Nemesis NXT
  14. What's a stock .46 turn a 9x10, and/or 9x7 APC props?
  15. Where to buy Jett 50
  16. something really fast
  17. diamond dust props
  18. Glass the wing of a world models dago red or not?
  19. Scratch Built Speed Plane
  20. Coroplast DDust/Whiplash -- Cheap Speed!
  21. Diamond Dust CG Range...
  22. Bladder tanks
  23. Whiplash Ready For Launch
  24. Modified Launcher
  25. New Whiplash Flies from launcher
  26. whiplash pipe mount
  27. this thing is really fast
  28. pulse jet whiplash
  29. Another option for going fast
  30. Patriot:Anyone start theirs yet
  31. Texas, weather, props, etc.
  32. engine for whiplash
  33. 1/2A Skrike and servo size.
  34. extreme speed contest
  35. K&B 7.5 DF for Whiplash
  36. Fast, Small, Cheap
  37. whiplash quirks
  38. Lanier Predator
  39. Rossi 65 prop...
  40. New owner of a "SpideyLash" (1st. flight)
  41. Cermark F16 ready for first flight
  42. OS 46 VF ABC-P, Is this any good?
  43. Kangke F3D/30
  44. Cyclic's F-20 maiden??
  45. servos
  46. Dang GRRT quiting in air
  47. Star Wars Whiplash
  48. K&B 7.5 Ducted Fan Engine
  49. Saito 100 plane recomandation
  50. WM Midget mustang or GP Shoestring???
  51. help me with me predator
  52. Silly question
  53. Prop for Enforcer
  54. Force One VideoPlane project
  55. 15 size speed plane( my own design), & prop question
  56. 1
  57. I require a very fast jet
  58. Sport 240 80" Wing - 19lbs 150mph ALL DAY LONG
  59. spiderman whiplash
  60. Whiplash needs more speed
  61. patriot vs f-20 vs kouger
  62. Speed on the cheap
  63. How to get the most from a K&B .48 ?
  64. Something new thought you guys would like to check into maybe??
  65. Nelson .65
  66. unloading question
  67. Norvel .061 Delta flies great!
  68. Laser Arrow Big prop or Small prop
  69. Single blade props
  70. DDust elevons
  71. Kangke F3D vs. Weston Magnum. Which is faster ??
  72. F-20 Retracts
  73. looking for foam delta
  74. Radar Speed Checks
  75. lanier shrike
  76. Batman whiplash
  77. The shocking truth about speed or, Dustflyer finally gets a taste of reality!
  78. Magnum Arf
  79. How many of you have a Whiplash?
  80. Butane can muffler
  81. cant get RPM readings
  82. Prop for K&B 7.5 DF on Diamond Dust
  83. Patriot is back!!!
  84. Whiplash Crash (Was Whiplash Control Throws)
  85. MVVS .40 question on carb
  86. patriot vs. tomhawk
  87. MVVS .49, mini or full pipe?
  88. Outlaw Photos & info
  89. New Whiplash
  90. Servos for Whiplash
  91. What Delta Plane Mode Is This????
  92. speed calculations
  93. 2nd DD test flight
  94. patriot
  95. Jett Sport 46 on Whiplash
  96. Great Planes Patriot
  97. quik question on covering DD
  98. Z bends
  99. armorall
  100. nelson whiplash
  101. Wonder with OS 32 SX, Prop!!!
  102. APC Props
  103. whiplash pipe mount
  104. fuel foaming
  105. twin deltas
  106. Balancing Props
  107. Whiplash vs Lanier Predator
  108. Whiplash launching
  109. twin deltas
  110. whiplash weight?
  111. Hobbico Spectrum
  112. Weston Magnum.....in stock anybody?
  113. Prop for weston magnum and weston v2 50
  114. Idea
  115. Weston Magnum - Engine Mounting?
  116. Ripmax RapierARF
  117. Whiplash first fligh report
  118. dust ys 45
  119. Dago Red
  120. Dust Holder
  121. I need Whiplash CG Quick!
  122. Notice To All Whiplash Owners
  123. Yay!!! It's Almost Ready!!!
  124. Mustang Racer style kit?
  125. Laser Models Laser Arrow
  126. My new Green Mean Machine! (Whiplash)
  127. Attention All Whiplash X Owners
  128. batman whiplash on its way
  129. Post your Whiplash Paint Scheme
  130. what should i get for my first speed plane
  131. Spidey Whiplash ready to fly!!!
  132. Value Of This Patriot
  133. Magnum / OS 46 Fx ...peformance?
  134. Building second DD w/ FAI GRRT
  135. Jet style ARF's - that move
  136. Whiplash needs a prop!!
  137. DD plus OS 32sx
  138. Need for speed
  139. They're Here!! " Whiplash X "
  140. In air RPM
  141. How much would you pay??
  142. Outlaw Flyers
  143. Jett FIRE 50 users.. what kind of rpms are you getting?
  144. Cermark F16 speed and style
  145. whiplash
  146. How about a contest?
  147. i'm rtf my vortec, any tips......
  148. Diamond dust motor mounting 1/4" higher than spec.
  149. Whats the Biggest engine on a DD?
  150. whiplash painting
  151. New Whiplash Paint Scheme
  152. Whiplash Header
  153. Jett FIRE 50 vs BSE FIRE 50
  154. Need for Speed - GP Patriot
  155. magnum arf or predator
  156. whiplash
  157. Building Laser Arrow
  158. Follow up on WHIPLASH mid air
  159. Fuel for a Rossi 53 ducted fan (older engine) The book says Castor no blends ??
  160. Ripmax Rapier Delta Wing
  161. Tuned pipe couplers
  162. muffler for norvel 25
  163. which one
  164. Jett Q500 vs Jett .50
  165. my first diamond dust
  166. nelson question
  167. Patriot pictures please!
  168. Is it ok to run an APC 9 x 7 with a Thunder Tiger .46 Pro???
  169. Landing the Diamond Dust??
  170. Sig Wonder
  171. 91 vfdf 40 size Shrike
  172. Cermark F 20 "Finished"
  173. Nitro = Speed
  174. Shrike 10
  175. Whiplash availability?
  176. Diamond Dust servos
  177. Pattern prop regular prop?
  178. Diamond Dust as first speed plane?
  179. TNC Tachometer
  180. New Speeders Questions
  181. econokote
  182. What RPM'S are you turning on MVVS 40 GRRT?
  183. Cermark F-20 ARF Winter Project question
  184. Wanted-Rear View Mirrors for Whiplash
  185. Whiplash 2 down RIP
  186. Weston Magnum Servos?
  187. Whiplash Midairs!!!!
  188. DiamondDust and Jett Q500 engine
  189. Weston Magnum Noise Levels and Fuel?
  190. Outlaw Construction
  191. Backlash, WhiplashX=When?
  192. D.D. or Whiplash flutter ?
  193. Whiplash fuel tank(s)
  194. problems with my dust
  195. what do u think
  196. Magnum Review (unauthorized)
  197. Diamond Dust fuel tank...
  198. Holy Smoke or Skyfire 40, anyone?
  199. Update and last update on my DD
  200. nelson
  201. a wiplash
  202. i would like
  203. Have a whiplash for sale?
  204. Whiplash?
  205. Ripmax Rapier
  206. Cermark F-16 on E-Bay
  207. Whiplash - First flights!!
  208. Whiplash video...
  209. flying multipuls
  210. WorldModelsP51/YS91AC/apc11x12
  211. Shrike 40 w/ 46 and I want it to go FASTER
  212. First Whiplash flight in the USVI
  213. F3D kankge
  214. McCoy #9
  215. HELP --> How To Balance the Magnum
  216. 'One-design' racing anyone?
  217. another shot
  218. whiplash
  219. Rules For Racing?
  220. What is a good plugg for GRRT?
  221. YS 45SE anyone...?
  222. less than perfect
  223. Hooooweee!!!!
  224. HELP to push my dust fast ( ??motor)
  225. flying a racing agwagon Pics in gallery And Dago Red racer
  226. dago red racer
  227. advice...outlaw linkage
  228. MVVS GRRT Rear exhaust 40 pylon motor
  229. Team Trials For Fai Pylon
  230. My DD after 14 hrs.
  231. Diamond Dust back to Dust...
  232. .15 size shrike w/OS32 Prop?
  233. K&B 7.5cc DF on Whiplash ?'s
  234. jett 60
  235. Lets See Your WhipLashes!
  236. Planes that work w/ YS .45 Rear Exhaust?
  237. question on carbs
  238. need speed help
  239. Outlaw
  240. Whiplash with a YS .45 FR ABC RC Rear Exhaust
  241. Kavan Projeti - would this classify as a extreme plane??
  242. WhipLash motor help...
  243. Flew my Whiplash first time today!
  244. Scratch building a Diamond Dust
  245. What would be a great FAST airplane for a YS 45/tuned pipe, side exhaust?
  246. Can you use an apc 9x10 on a .46?
  247. My DD after 8 hrs.
  248. Billy Hell wins "Whip-lash" !!!
  249. Landing Whiplash on asphalt
  250. patriot plans
