PDA
View Full Version : Extreme Speed Prop Planes
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Need info for AK SU-27 Flanker
  2. been neglecting my planes and why
  3. Sundowner covering
  4. tuned pipe and header?
  5. Sig Kobra(25size) w/32sx
  6. p-51
  7. Looking for small F3D style electric
  8. What prop for a .91 OS 2S?
  9. OS 40 VR-P in Screamin Demon
  10. Best/Fastest Plane for a Moki 2.10 !?!?
  11. Which engine for Extreme Flight Outlaw?
  12. aileron servos for .40 Patriot (HELP)
  13. Oddball engine
  14. Patriot xl
  15. Shrike 10 CG
  16. patriot 40 plans - help
  17. K&B 6.5 FIRE / SCREAMIN' DEMON
  18. fly king nitro planes webra 1.20 pusher
  19. Patriot XL Help
  20. WESTON MAGNUM MANUAL OR PICS/INFO
  21. Speed Stick.
  22. What prop need help?
  23. Norvel .074
  24. Looking for a prop jet kitsuggestions
  25. Patriot 40 engine advice
  26. Hitec HS225 or HS85MG enough for Sundowner 50 ailerons?
  27. What do you think??
  28. sig doubler
  29. HAPPY NEW YEAR!!!
  30. Evolution .60NX W/ Jett Muffler for Sundowner
  31. Crash the party..
  32. new speed plane sorta
  33. 100 mph foamy for around 100 bucks.
  34. Maynard Hilll's FAI speed record - article
  35. 60 size delta
  36. SCREAMIN' DEMON / JETT46
  37. Clipped Wing Diamond Dust / OS DF 25
  38. Ok guys what do I put my JETT Fire 60L in?
  39. JETT Engineering
  40. Sorta OT and has a lot to do with why I don't fly in winter.
  41. WEBRA 50 IS THE SAME THAT WEST 50 V1
  42. Don't forget, your prop is an airfoil
  43. I think this qualifies....
  44. Field box
  45. need piston and sleeve for west 50 v1 engine ((((webra 50 is the same engine that west 50))))
  46. magnum for sale of the east coast
  47. Looking for a real FAST plane!
  48. Hottest .91-.120?
  49. brief heads up on new engine
  50. Screamin Demon cowl take 3
  51. gasoline speed engine <30cc ??
  52. OS 46 VR-DF on the bay
  53. Making a tail with glass and kevlar/homemade peelply
  54. Yummy looking kit
  55. How fast is extreme?
  56. West .50V1 bench run
  57. Throttle vibration isolation
  58. FAI F3D plane RTF
  59. What's A Good First Time Speed Plane
  60. Diamond Dust Electric
  61. Wild Wiz 60
  62. Can't decide which plane Help
  63. Nuthin but hot stuff went in the truck today!
  64. RFB 600 Fantrainer
  65. ACEGLH
  66. Which .46 2stroke engine makes most power,,
  67. What glow plug????????
  68. Bobcat 50 notes (nitro Planes)
  69. some nice speed here
  70. OS 46 AX
  71. Whiplash
  72. ak-models Flanker and prop questions
  73. SPEED Lekkie 400
  74. Electric set up Help
  75. Sequence of shimming vs nitro
  76. Need speed proppeller,Patriot,O.S.95AX
  77. Weston Magnum/Nelson Q40 w/ video...195-ish!!!
  78. Speed plane for OS 108 and OS160
  79. Delta target Drone
  80. Jett 90LX/ Cline
  81. Looking for something...
  82. K&B 7.5DF engines
  83. Engine test stand (Show and tell)
  84. Rosie 45 vs 61
  85. x48b delta, are those jetcat turbines?
  86. Screamin Demon .65 build thread
  87. What's the fastest ARF in the world?
  88. Laser arrow, 91vrdf video
  89. Holy smokin' pipe Batman, lemme see that for a sec..
  90. "FAI" fuel eh..?
  91. bobcat setup help
  92. Diamond dust with os .46 df (props)????
  93. Rossi .67
  94. ROSSI 45
  95. What engine for Patriot XL
  96. Screamin' Demon cowl plug #2 - nearly done!
  97. grudge match-who's going to win?
  98. bobcat pictures
  99. SCREAMIN' DEMON DOES 202 MPH!!!
  100. Jett 46
  101. needful things for speedfreaks like us
  102. Deep Impact
  103. Novarossi 50 help
  104. My new and improved wing is RTF (Take 3)
  105. pusher prop???
  106. Combat Models F-16N Canopy HELP!
  107. bobcat .40 + OS .61 MAX
  108. Next Project! Kyosho Kelly, Jett 50 sport
  109. Whiplash Elevon Control Throws?
  110. Demon cowl, take 2
  111. 2 x 400cc moki radials
  112. corsair
  113. vmar f5 tiger 11 build
  114. sort of fast P51 mkll
  115. Westonuk out of business ?
  116. DeNight Special 50 ARF
  117. What you think ???
  118. OPS .65 bench run.. finally!
  119. airplane for this engine
  120. Nelson Q40 too much for LR-1 Speed Cat?
  121. horns
  122. Engine Bearings
  123. What are your thoughts on this engine?
  124. Vne discovered (Electric Flying Wing)
  125. SCREAMIN DEMON Small Block Bash
  126. what is the best delta?
  127. DIAMOND DUST PLAN
  128. new speed records
  129. Torque question
  130. New Model Aircraft International Record Claims - 30 September 2009
  131. So, what about this new 60 in a 40 size Evolution?
  132. Al mounts
  133. ys engines
  134. O.S. 46 max vx
  135. Picco 60
  136. sig wonder part 2
  137. Cheap eBay "Screamer" build.
  138. Tune pipe and prop size for kougar
  139. Completely OT but involves speed..
  140. sig wonder
  141. OS 77 df
  142. Screamin Demon Thuddddd.....
  143. Important announcement
  144. 1930's racers
  145. viper
  146. Oakdale Aircraft still in business?
  147. Screaming Demon big block bash
  148. Pusher Prop New, but 30 mins later & ovaled out? *Help* What did that?
  149. thinking about getting rid of some combat models
  150. Nelson 40 info needed
  151. engine swap???
  152. Where can i buy a diamond dust?
  153. Header Tank vs Perry Pump vs nothing - Bobcat 50 prop'er
  154. 77DF pipe size?
  155. ACE Simple 400 - 125mph
  156. A Speed NOMOGRAPH for you all to use
  157. WM tucan 60?
  158. Biggest engine on a hanger 9 P51 60 size
  159. Suggestions for an engine I have
  160. Nelson Q40 without a home.
  161. Phoenix Models F-20 tail linkages?
  162. 50,000 rpm and then poof
  163. Good place to post a for sale item
  164. Best prop For Webra 55gt P5?
  165. Best engine for a Patriot XL?
  166. Completely OT - but funny
  167. Could he have flown any lower?
  168. Revolver a speed plane?
  169. BEST DELTA EVER! Post your deltas
  170. Doppler????
  171. Rossi engine info?
  172. F20 tigershark ...low pass
  173. Nemesis NXT Sport
  174. Midget Mustang and DS821 is this OK?
  175. Vintage Delta Kit
  176. pipe question
  177. new plane.
  178. S header
  179. BROKEN MANIFOLD
  180. OPS 120 20cc available in the USA?
  181. YS 60 short stroke
  182. Shrike .10-OS .25 vrdf project
  183. PHOENIX MODELS F-20 TIGERSHARK CG?
  184. New fast airframe in the works
  185. need for speed sundowner question
  186. OS 95AX
  187. MAGNUMR NOT FAST ENOUGH
  188. Looking for B&D retracts
  189. the new delta
  190. Weston Outlaw
  191. You Asked for It, Dart XL - Bigger and Better
  192. Flat plate wing thing
  193. .40 SIZED FLYING WING
  194. Twin engine speed planes
  195. Cheap speed plane
  196. engine to use on outlaw
  197. Engine for a fast 20% (sport) Mustang?
  198. NEW VIDEO,SMOKIN' H9 80" Sundowner
  199. OS 160 FX and 80" sundowner
  200. NOW BE HONEST....
  201. I had a fun day today.kindda scary
  202. OT - airshow, Elyria OH yes, me
  203. need help picking first "go faster"
  204. SIG WONDER
  205. Gremlin Motor choice
  206. Miss America
  207. I out ran a bobcat 50...
  208. SMOKIN, F1 80" Sundowner
  209. Diamond Dust experience?
  210. i've missed you sweet mother speed!
  211. Sundowner 50 with Saito 82a
  212. Don't let this happen to you guys!!
  213. Beginner speed?
  214. Weird Radio Problem with my Diamond Dust with Jett 60LX
  215. Sig Wonder
  216. SCREAMIN' DEMON/ YS .45 FS???
  217. Tuned piped OS 75AX
  218. max spinner rpm
  219. Any experience with neo planes
  220. Looking for a spectum player
  221. 150 to 200 mph+ speed planes => Where to buy them? - An overview
  222. Anyone seen or tried the new MA props?
  223. Pusher props
  224. Sundowner 50 with a YS110??
  225. Simple Things to Add Speed - Your Tips
  226. Demon #1 passed inspection and ready to go again
  227. HP Gold Cup .40
  228. LOOK what arrived today!!! Keecat II
  229. OPS Speed .15 RCA
  230. sundowner and ST 2000?
  231. THE SPEED POLICE HAVE ARRIVED!!!!!
  232. kEECAT II
  233. Jett 90L got a new home
  234. Little tony unstable in flight ?
  235. Best prop for speed with a .91 FX?
  236. OS .25 VRDF rpm's for Shrike .10
  237. TT46 rpm Question.
  238. DD throws
  239. OS .35AX
  240. Nelson Engines
  241. Could somebody please try to doppler this?
  242. A bit OT but good to know - Geneseo
  243. Shark XV .15 speed plane?
  244. Do you recognise this plane?
  245. 4x Red arrows
  246. A new summer hat for demons
  247. rossi engines, take a look
  248. PLEASE READ!!! Critical safety tips
  249. Canada Day is coming!
  250. Spitfire and tuned pipe
