PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. GPS track?
  2. Anyone flying in Lake Charles?
  3. Newbie question - Esky xmitter works with airplane?
  4. GWS DD-8040 cavitating?
  5. Control problem, Please help
  6. Beginner plane???? Need Advise!!
  7. Field flightbox setup
  8. Wing damage on Rascal40 - how to fix it-help!
  9. electric engine sputtering?
  10. PO'd about nitroplanes
  11. Lightmax Battery Prices
  12. What discharge rate
  13. ESC CAPACITOR QUESTION !!!!!!!!!
  14. MWE Spring Fling May 15-17 2009
  15. BRUSHLESS MOTOR HELP!!
  16. wild wing
  17. Need more power! Help
  18. T-Hawk out of business? Little help please..
  19. what airplane for 3800kv motor and what gear box?
  20. Watts
  21. Flying sites east of Tampa Fl
  22. DX6i - can it be used with non spektrum receivers?
  23. old Airtronics MA-3 ESC
  24. Parkzone J3 Cub reconstruction
  25. Working backwards from a battery to chose an airplane.
  26. Clips for ESC
  27. Parkzone J3 Cub Problem
  28. silver calcium field bat
  29. Wing Mount Re-inforcment on Electrify F4u Corsair?
  30. Parkflyer Begin air first plane.... want to upgrade
  31. Parkzone RTF F4U
  32. quick avion question
  33. AMP and Voltage Checker
  34. GWS Tiger Moth 400 question
  35. Bantam BC6-10?
  36. Motor and ESC combination
  37. Wilga 2000 Prop
  38. How many servos on a esc
  39. Newbie Questions About Airplane Electronics and Things...
  40. Electrical interference problem from motor/ESC
  41. KMP Twin Otter
  42. REVERSE THRUST SYSTEM (RTS)
  43. WHERE IS A GOOD PLACE TO BUY A123 BATTERIES
  44. What apc prop?
  45. Lipo charging with a car battery charger
  46. O.K., Who sells Luppo Motors?
  47. Gas or Electric for P-40
  48. wing tips
  49. Cessna Citation EDF?
  50. Who is the Distrib. for Luppo motors?
  51. hextronik servos wire color
  52. Charger Questions
  53. SWIFT mini
  54. Brushless Motor - How to Dismantle?
  55. I need your advice re my glitch problem
  56. Electric C-130 motor/Esc wiring help please
  57. Flight Power V-balancer.. need specs.
  58. charging help
  59. IS THIS BATTERY GOOD?
  60. Question about old heli
  61. Battery Choices
  62. Onboard vid questions.
  63. Max wire length between motor and ESC?
  64. AXI 5320 with a 32 cell NIMH pack problem
  65. What about the GPlanes Electrifly SU-31??
  66. Multiplex LN-5014 Display
  67. Super Cub Pilot/Looking to try another type of plane any sugestion.
  68. Cleaning Planes
  69. Need Help Identifying Plane.
  70. Guan-LI Thunderbird Power Glider- HELP
  71. receivers
  72. ElectriFly Gearbox S280
  73. Convert HiTec System X 5ch to Spektrum
  74. Measuring Up
  75. Charging bigger (More cells) LiPo Packs ???
  76. 3 blade vs 2 blade prop
  77. Potensky XXL finally finished!
  78. Balsa rib constuction/Prowler construction
  79. HobbyKing, NEED HELP, Canadians!
  80. fly carnival in fortaleza BRAZIL
  81. need help to get lipo to 4.8 to 6 volts
  82. Expected Flight Time / Distance on this airplane?
  83. looking at esc's
  84. FlightTech ESC
  85. Electrifly Silver Series ESC
  86. prop question
  87. I need a fuse
  88. electric conversion
  89. Easy Tiger Cessna 185 Floatplane/Landplane?
  90. E-flight 480 problems
  91. Brush on insulation???
  92. Towerhobbies cessna 182
  93. What battery do i need?
  94. Setting up AXI 5320 - any tips appreciated
  95. how big of a plane? 350x90'
  96. How to bind a DX5e
  97. Connecting two motors
  98. Master power / arming switches
  99. Quick motor question
  100. Woah! phishing email sent through RCU?
  101. Kyosho prop replacement
  102. Need help with Hitec Laser 4 radio
  103. 40-50 watt motor needed
  104. Good First Plane?
  105. Help with Spektrum DX6 TX vs DSM2 receiver
  106. Practical difference?
  107. Good Beginner Airplane For me?
  108. longer run times
  109. Charger battery
  110. GWS P-38 props
  111. VQ "Delta Rocket"
  112. HobbyZone Supercub repower
  113. Newbie to RC flight
  114. Unintentional Motor Runaway!
  115. HOBBYCITY SUCKS (HONGKONG)
  116. Multi Engine set-up question
  117. broken battery
  118. speed control
  119. HELP!! radio compatability issue!
  120. balsa wood
  121. E-Flite 46 at full throttle pulsates
  122. What Lipo for 540 brushed
  123. Using heli electronics for a plane
  124. More & more rejects with poor customer service.
  125. I WANT TO SEE LOTS OF POSTS AGAIN !!!!
  126. Differential throttle-steering on an elec. twin.
  127. creator
  128. wing area and weight for 123 batteries
  129. Twin motor Funster
  130. Help with class of Motor
  131. can you put a bigger bat in the hobby lobby F-18
  132. A123 balancing ?
  133. EFlite 25 won't run!!!!
  134. ESC SET UP
  135. Rocket powered RC
  136. futaba 6exhp or futaba t6exp
  137. BEST TWIN ENGINE AIRPLANE
  138. I AM CURSED!!!!
  139. WHERE IS EVERYBODY.
  140. Hacker basic 90 opto esc info
  141. Twin Motor Question
  142. Warranty claim on motor???
  143. Surging Motor?
  144. How is this set up?
  145. New product: Emeter II & RDU
  146. Combat models F-16
  147. eletric plane in BRAZIL
  148. Mid winter blues.
  149. BANANA HOBBY planes ?
  150. Electric fly contest info?
  151. Spektrum neck strap adapter for DX radios - NOT
  152. Aircraft storage
  153. GWS P-38 power cord
  154. HITEC 5065 digital servo problems !
  155. Easy Star simulation
  156. I Need a servo tester
  157. Which plane should I get?
  158. You probably have free rare earth magnets..in your shop.
  159. Lipo batteries
  160. 4th Annual E-Fest Event Coverage, Feb 7 & 8.
  161. Cox (or similar) Micro Warbirds
  162. Electric equivalent of 50cc Gas engine
  163. servo glitching ?
  164. Will E-flite ESC's run in parallel?
  165. New Hitec HS-82"HD" servos... ???
  166. 2 ESC's and y-connector
  167. Landing without gear
  168. Parkzone Li-Po charger?
  169. Thrust and Payload (X3D + Hacker 20-22l)
  170. Imax B8 charger
  171. Wattage Cessna 180 (brushless?)
  172. Slow Flyer
  173. What is this?
  174. Motor and esc for 450 helis?
  175. Connect two LiPo battery (1S - 3,7V)
  176. Thanks to everyone who tries to help one another !
  177. Which Motor vs Which Motor
  178. 3 mm drill bit ?
  179. YAK 54 EP 3D PERFORMER BY COMMON SENSE RC
  180. F27 Stryker servos
  181. Receiver??
  182. Source for UltraFly Models
  183. ELECTRIC MICRO-TELEMASTER SETUP - please help
  184. Programmable channel mixing DX6i
  185. E-Flite 30-Amp Pro Switch-mode BEC Brushless ESC
  186. Help me put my 1200kv motor to work.
  187. Is my AXI 4130 setup worthy? (AeroDesign Competition)
  188. AK-Models ok with me!
  189. rimfire 35-30-950, 3s, 12x6, burnt - was it overload?
  190. Change Batt Powerd Charger To Plug in DC
  191. RC Nitro Plane Help
  192. Motor Mount Spacer
  193. CM PRO DISCUS CS
  194. propeller on a 15t elec motor?
  195. Problem with LiPo cells in MotoCalc8
  196. A charger for this Li-po?
  197. a few questions...
  198. Mystery 100 amp ESC
  199. THUNDER POWER CHARGER
  200. Noob question: What does the 4S refer to as in 2100mah 7.4V Li-Po 4S?
  201. Need advice on pack charger
  202. My aerobird is a jet now!!!!
  203. GLOW TO ELECTRIC CONVERSION
  204. Neeed Help -Receiver Crystall
  205. The C-rating on Li-po batteries???
  206. Money no object. what Charger?
  207. Size/type of a/craft for this motor?
  208. Twisted Wiring for Interference Reduction
  209. source & spec for esc capacitors: electronics guru needed!
  210. Parallel Packs of Dissimilar Capacity
  211. Brushed ESC used as a glow driver ?
  212. EPP vs.pink bldg. foam & 2lb white foam
  213. GP 12-amp ESC
  214. .46 IC CONVERSION
  215. Triton 2
  216. Electro Dust
  217. FlyCamOne2 Question
  218. ESC Amperage Size
  219. Hobbypartz.com : Anyone have any dealings with this site?
  220. F4U Corsair from RC Nitro Planes
  221. Never flown a small Plane
  222. Choosing motor and prop
  223. Speed 400 Pylon Racer Question
  224. Help!!Which plane?
  225. Our first electric - glo mid-air
  226. Dean's Connectors... Can't live without 'em!
  227. PRECISION AEROBATICS ADDICTION -REPAIR HELP
  228. Tx Range Question.....!
  229. Hi I messed up
  230. WHAT PACKAGE FOR THIS TAYLORCRAFT?
  231. Done with heli's.
  232. ST model DG1000
  233. hacker A10-15S or E-Flite park 250
  234. How Would You Outfit an 82" Corsair?
  235. I dont get it ....!!!!!!
  236. Prop RPM Power question
  237. HI i am new here
  238. Erased
  239. Flaperons or Spoilerons for landing....??
  240. servos
  241. I've been a silly boy
  242. WARNING
  243. Brand spankin new to electric need advice
  244. Transporting lipo's on full size aircraft
  245. Seperate Receiver Battery ? BEC Switching Regulator ?
  246. home made stickers for foam planes
  247. assume amps
  248. ESC Problems
  249. whats the best radio and charger for me?
  250. Best on line store to buy E-flite products
