PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. TinyBriteLights On F16 EDF >>A++<<
  2. Need plane for misc equipment.
  3. Knowledge & value of different parts of electric flying.
  4. Battery Discharge Rating?
  5. solor rc plane?
  6. 2808/20
  7. antenna bobbins in fiberglass fuse...
  8. Color coding servo to receiver leads
  9. NEW Product Annoucement: Electric Scimitar Props from CERMARK
  10. Is this normal?
  11. ESC ??????
  12. Flight time of J-3?
  13. Sea plane help
  14. new to leckys
  15. Neumotors outrunner
  16. New Electrostik Likes To Nose Dive
  17. Micro citabria float plane
  18. Indoor Electric Fly-in Denver Nov. 28
  19. aerobird xtreme
  20. Overheated E-flite Park 370 In-Runner Motor
  21. Ceramic Insulator
  22. servo problem
  23. PARKFLYERS?
  24. Power upgrade question
  25. Parkzone Warbird Brushless upgrade?
  26. UltraFly SR-22.. anybody?
  27. Brushless motor problem!
  28. Hobb-e-Mart equivalent?
  29. electric motor
  30. aerobird 3 problem
  31. recommended first plane?
  32. GWS P_40 Warhawk VS. Ultrafly P-40 Warhawk. What's the difference?
  33. How did you mount your Mega RC600/30/7
  34. Himax 2025 4200 on GLM Corsair
  35. Dead Li-po?
  36. Please help! ESC/Motor Problem
  37. RC Club Australia
  38. Need Data on airplane
  39. Quick charge for NimH battery??
  40. Super cub.....What's next
  41. What's the screw size for the aileron/rudder/elevator HORNS on Park Zone T-28 Trojans and Corsairs?
  42. Megatech Avion io insides needed
  43. cmp aquila AT01
  44. increase battery time
  45. Sebart Shark owners?
  46. Scale planes w/retracts 25 size or smaller?
  47. Does This Look Right
  48. What can i use
  49. Custom Paint Job on Micro Citabria
  50. Heat shrink over a battery pack - Need tips
  51. Rcs cessna?
  52. SKY ARROW
  53. Smallest plane.....
  54. Which Outrunner Motor and ESC for a slow stick?
  55. Easy Way to Adjust Thrustline ???
  56. New plane....??
  57. I'm pretty proud
  58. Spektrum receiver problem.. help!
  59. Tx question
  60. TURBULANCE?
  61. Megatech Prowler - not accepting any input controls
  62. dx5 or dx6?
  63. Light Strings noise
  64. ratched throttle
  65. Any body use the Pilot View camera from HL?
  66. Need 5pin balance lead for Astro blinky balancer for a123
  67. Things I learned the hard way, pt. 1
  68. Mounting Servos
  69. Electrifly SE5 motor wont go
  70. Different connector types question (for power/esc/chrgr)
  71. Elevon travel issue...
  72. Club Electric Flying Help
  73. Can't get off the ground
  74. CONTROL ROD HORN PLACEMENT
  75. hobbico electristar question
  76. STORING LIPO BATTERIES ???
  77. Help! E-flite pitts model 12 25e
  78. Length of battery lead to ESC
  79. Cooling
  80. AP2000i - Will this work on 6 channel System?
  81. confused
  82. Help with RICCS Mirage 2000......
  83. how do you install retracts?
  84. superbright leds??? how to install????
  85. Great Planes Electrifly 5Ch FM Rx w/30A ESC instructions
  86. Understanding electric power requirements
  87. Blinky balancer lighting sequence
  88. NEAT Fair video clips
  89. Charger question
  90. Tx / Rx NiCd charging questions !
  91. Misc RC flight questions !!
  92. Lipo Twin Adaptor?
  93. My Deuces Wild experience
  94. WHY DID MY ESC DIE ??
  95. AT-6 Elevator Servo Problem
  96. Pulsar 2000 glider -motor and battery set-up
  97. Setting up the Hacker x-30 ESC With the Typhoon 2 motorp
  98. BEC Question
  99. Seagull Electric Extra
  100. Did anyone go to NEAT show in Downsville, NY this last weekend?
  101. battery??
  102. SkyRC Imax B8 LiPo Charger
  103. PZ Corsair not up to T-28
  104. Weather conditions?
  105. I didn't entirely vanish...
  106. When to land?
  107. Hanger 9 Sopwith Camel
  108. Frustrated! Electric/Aluminum prop adapters
  109. Graupner Unltramat 16 Voltage Query
  110. Recomend a plane please
  111. Folke Wulf-190
  112. 'SHOCK' controllers
  113. Smoke from ESC, motor fault?
  114. Sun ip SU/R 6FM 72m receiver
  115. high wind piper cub?
  116. Ereaper wing crash
  117. hmmm Got a question or 2 (new to electric Dont strike me down Rawr)
  118. Need elect info for Sundowners in USRA Pylon racing
  119. No throttle control
  120. Discharging problem?
  121. Lipo battery help
  122. Big Motor Test
  123. Whats a good brand of "CHARGE SWITCH"?
  124. lipos
  125. New to Electric Flight and Li-Po's
  126. Futaba 6exa radio Rx nicd voltage reading
  127. Massively confused
  128. Jim ryan p47 kit
  129. Futaba S3103 and S3108 Replacement Servos
  130. Servos for a Ryan STA EP
  131. more dangerous than glow?
  132. graupner mx12 on e-flite e-flite AT-6 Texan 25 ARF?
  133. Kv problem
  134. Motor selection for a E-Flite Pitts
  135. How and where do you store your planes
  136. ,,,,,
  137. Rascal 40 EP - Antenna question !
  138. Enter To Win A $500 Dollar Online R/C Shopping Spree!
  139. Rascal 40 - Wheel pants issue!
  140. converting from brushed to brushless??
  141. interference noise from GWS naro servo
  142. WW1 Electric
  143. Need advice on stop watch /flight timer
  144. Need simple flight stand made of thermocol
  145. tee heee i fixed my lipo...
  146. Experience with Corona CS929MG Servo ?
  147. Spektrum DX6i question
  148. Motor -Wooden mount question
  149. VPX batteries as rcv/CDI power source
  150. Electrajet or Stryker?
  151. Holes in spinner base plate and Prop - bigger than Shaft!
  152. covering foam wing
  153. Digital or Analog Servo?????
  154. A proper charging the NiMh Battery of Super Cub, please!
  155. how can I tell which motor or esc to use???
  156. fliton almost in the dumpster...
  157. Snapped Rx antenna
  158. dumb mistake,possible salvage?
  159. Deuces Wild advice
  160. futaba pcm bec problem
  161. Lets Get RC Flying, Helis, and Aeromodeling on TV! -Campaign
  162. F27 C RTF transmitter beeping! what to do?
  163. Charging LiPo
  164. Motor Problem
  165. AC to DC converters?
  166. Seagull Dual Ace conversion to electric
  167. I am thinking of crossing over to the dark side
  168. Substitions for Tsunami 72 amp brushless controller
  169. F16 arf
  170. Battery Connectors
  171. Electric motors
  172. launching a ZAGI
  173. LiPo Recommendation for E-Flite AT-6 Texan w/ Power 32 Motor
  174. Guanle A-10 electric jet
  175. tips for ESC cooling
  176. motor installation
  177. motor installation
  178. Good dogfighting plane
  179. Controller Jumper placement?
  180. Banana Hobby Super Cub
  181. New to R/C Electric Buggy
  182. PA Electric Fusion
  183. Where to buy stand offs etc?
  184. Newby questions, ESC's and props???
  185. Question on Batteries
  186. Please help!!!
  187. 5 cell lipo
  188. new heli or plane?
  189. Lipo/Li-ion Charger
  190. Seagullep XRAY
  191. HELPPPPP!!!
  192. Assistance in matching equipment for multiengine
  193. Electric motor
  194. Adjustable Battery Tray
  195. Dymond Modelsports
  196. GWS 15 Vs Great planes l-39
  197. Electric conversion
  198. LiPo Batteries
  199. Brushless, SENSORLESS?? Motors
  200. Throttle Lock for Electrics
  201. Dead hobbyzone NiMH batteries
  202. Building Board
  203. Help getting started with a 4 channel transmitter?
  204. Prop saver centering Question
  205. Scale Model Advice
  206. Hobby shops in Shanghai, China.
  207. Servo?
  208. Balance charger.....
  209. Brand New to this site, Somewhat new to the hobby. Couple of questions please?
  210. How to set two servos for Elevator(Hyperion Yak 54)
  211. need help with a prop issue ...
  212. Travel Limiter Needed?
  213. Bantam Two-Meter
  214. is this the right choice?
  215. Hv-85 help
  216. Motor shaft too long?
  217. Can triton2 Charger Charge a car battery?
  218. Flying a plane for the movies
  219. DESPERATE need of help... PLEASE..
  220. iMAX B5 charge
  221. Brushless motor using NiMh?
  222. Venom charger - what do you think?
  223. New to electrics - What fight duration can I expect?
  224. Zagi Tazz LiPo set up?
  225. Has anyone used Turnigy 50-65A?
  226. Battery connectors and adaptors.
  227. Help me find a charger please !
  228. Spectrum RX Problems. Please Help!
  229. E-flite T34 Mentor 25 ePTS RTF
  230. E-flite Piper Pawnee Battery Choice
  231. DX6i
  232. Newbie ESC question...
  233. E-flite T-34
  234. Help wiring in series
  235. Help with first electric setup
  236. Zagi CG
  237. Servos for e-flite 25e ultra stik?
  238. Wireing of 123 cells
  239. What Plane to Buy?
  240. TP 210V Balancer problems...?
  241. Trojan problems
  242. ESC timing ?
  243. ROBBE Curtiss Jenny JN-4 ARF
  244. servo twitching
  245. Problem with my Parkzone Trojan
  246. End play in 400 style electric motor
  247. End play in 400 style electric motor
  248. I don't know what to get ????
  249. Ideas for providing charging power at the field?
  250. Replacing an ESC
