PDA
View Full Version : Electric General Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. 4 Channel Park Flyer. Harbor Freight P51 No Good. Need Advice
  2. Prop Size?
  3. Wingsland Scarlet Minivet 5.8G FPV With HD Camera RC Quadcopter
  4. Horizon F4U Corsair S trim question
  5. Best brushless motors for alias quadcopter
  6. trim wont be exact
  7. How do you un bind a receiver
  8. Innovation on RC aircraft modeling
  9. fly then charge
  10. Proctor Mini Antic- Conversion to electric
  11. Tower Hobbies Corsair rxr prop
  12. How to know how much power is left???
  13. video drone configuration advice
  14. Ammo 36-88
  15. esc 8 c lipo
  16. Tactic computer Tx 6ch 2.4G
  17. Anyone ever use CY Models and/or Texas RC Planes?
  18. rager ex parts
  19. Best scale kits designed for electric?
  20. Please tell me my C-130 isn't too heavy!!!
  21. Tower receiver ready F4U Corsair
  22. ranger ex prop.
  23. Help Identifying Plane
  24. Newbie reiever capatibility
  25. Electric C-130 motors twerking??
  26. ranger ex flap issue
  27. Motor runs very slow now
  28. dx6 throttle recovery
  29. Electric noob question
  30. Charger
  31. New VTOL RC Aircraft Kickstarter Campaign
  32. Source for info on power output of electric motors
  33. Electric Prop Install Question
  34. Ya got about 50 bucks for a charger!
  35. The search for the right brushless motor
  36. which charger for LiPo's and NiCds and NiMhs
  37. Hobbyking
  38. Entry level help please!
  39. Electric Nieuport 17 1/4 scale
  40. Hubsan Q4 H111 RC Quadcopter
  41. Larger scale belt reduction.
  42. paulpaolozzi XPS NANO RX will not bind..
  43. Syma X11C Camera Drone Quadcopter review good and bad points
  44. E-Flite RARE BEAR reviews ?
  45. Review - GP TOYS F2C Aviax Quadcopter
  46. New Ritewing plane, the Drak, 60" EPP now on Kickstarter
  47. Which Receiver Battery to use
  48. motor temperature scale flying / motor comparison HELP
  49. See World’s First "Split Thrust Vectoring System" and What It Can Do
  50. Align 500 Servo set - will a 3 amp BEC work to power the servos
  51. slow props
  52. Solar plane
  53. slow fly props
  54. Glow ---> Electric Beginner - Best Resources to learn?
  55. Luftwaffe's best kept secret flies again - reichsadler
  56. Quad Pilots Wanted
  57. Electric Retract Question
  58. Planes at the Central Penn Flea Market
  59. Lipo safety
  60. Anyone used CHEETAH MOTORS OR BATTERIES?
  61. hobbywing 100a external bec question
  62. Syma X11c Quadcopter (w/ HD camera)
  63. Calibrating an ESC with Transmitter.
  64. parkzone Sukhoi su29 V ParkZone Sport Cub
  65. I want to add a UBEC
  66. "Common Sense" ACDC-6 Charger - output transistor
  67. Variable pich propeller automatic
  68. Using a Watt Meter ?
  69. Sbec ?
  70. reccomendation
  71. Flight time for my elec jet?
  72. excited but!
  73. Turnigy 46 brushless ?
  74. Quadcopter control idea?
  75. TRouble with bantam charger
  76. Switching to Lithium batteries
  77. Hobby King Invictus
  78. fms 800mm t28
  79. Realistic sound for BIG electric models (inc. startup, shutdown, gun sounds)
  80. 1/5 Scale Electric Warbird: 10S or 12S?
  81. Mono-Phan Technology With Multiwii - Amazing new 64mm module
  82. power lab 6
  83. New project - Help
  84. Torque 4016T/500 - Timing? Frequency?
  85. Flightpower LIPO balance plug help?
  86. 'Real Thing' setup?
  87. Frequency Problem
  88. Motor
  89. Heli Motor In Plane
  90. End of flying season
  91. extending antennae on dx9 to roof mount
  92. 2.4Ghz receivers LONG or SHORT antenna
  93. Horizon Hobby - Corsair with SAFE
  94. Wing tip illusion on a e-flight Nieuport 17
  95. Hobbyzone Super Cub
  96. Changing pitch affects speed but what else?
  97. Need Some Help with a Dynam Grand Cruiser retract issue please
  98. Sign Kadet Senior Sport? Too much weight and power?
  99. Hooking up 2 4 cell lipos to make 8 cells
  100. Which aircraft has .................
  101. cem 2812-840 motor
  102. Parkzone Sukhoi SU-29MM Programming
  103. Airfiels 800mm P51
  104. What glue to use on the parkzone su-26
  105. need advice on motor for lancair legacy
  106. only batteries get hot
  107. any balancing tricks for high rpm? (12000 to 15000
  108. electronic ignition
  109. DIY efficient propellers
  110. Monocote ?
  111. 1/5 Scale FW190 Conversion
  112. Need short reviews of products that you already bought willing to pay
  113. Wire length
  114. ESC problem
  115. 4 blade conversion to 2 blade prop
  116. receiver question
  117. Kontronic Power Jazz ESC
  118. Reviving an old hovercraft design?
  119. Experiences with different Hobbyking battery types
  120. Parkzone Sukhoi SU-29MM and DX7 HELP!
  121. Aileron and motor control only???
  122. Starmax P-51 Gunfighter prop & spinner
  123. 1/8 Electrified Twin Otter
  124. That Electric Rotarywing
  125. Hacker X-70-SB -Pro and Futaba SB rx
  126. huanyupcb.com Aluminum pcb led metal core mcpcb pcb prototype top manufacturer
  127. Storch 1800 Balance
  128. Is this a normal level of sound when gently releasing the brake pedal?
  129. Hobbico Avistar conversion to electric
  130. cell numbers
  131. Tvector – Not an acrobat yet but will get there!
  132. When do they get too big for electric power?
  133. Looking for a way to turn LEDS on/off from TX.
  134. Is my ESC overheating?
  135. Good Second Plane?
  136. lost canopy on Park Zone T-28
  137. I need to replace battery connectors
  138. Pls suggest the best EP BIPE !
  139. Slow stick
  140. ESC info
  141. Help locating Chinese manufacturers
  142. Setting flight duration using LIPO voltage telemetry
  143. Turnigy K-Force ESC program card
  144. Who is the manufacturer of Tactic Radios??......
  145. Connector Choices: Deans vs Traxxas or ?
  146. Setup for brushed motor?
  147. Econokote question
  148. Carbon Z Cub wing strut
  149. Extra battery packs
  150. Proto X Erratic
  151. Old Crow 1100mm 11.1v UPGRADE
  152. Motor, propeller gyroscopic effects avoid rotating at takeoff.
  153. Suppo motor, BL28BEO51 and accesssories:
  154. Parallax in Model Aviation
  155. Motor not developing full power
  156. Motor not developing full power
  157. TX/RX question
  158. Throttle lock program on JR
  159. buyers, please be aware of shady business practices...
  160. Need prop advice
  161. Night Flying
  162. Amps Over the Heartland 2014
  163. need charger adjustment help
  164. Delta Ray
  165. Blitz Skysurfer V5 won't fly
  166. What size motor, ESC, battery pack, and servos?
  167. Parkzone's S.E. 5a and Albatros
  168. Prop question for the experts
  169. what is the best charger
  170. 150 Class electric - what are my options?
  171. Spectrum AS3X in balsa warplanes
  172. Motor shutting down
  173. Caculating gas to elect.
  174. Parkzone VisionAire or Artizan?
  175. I Maidened the PKZ Albatross yesterday
  176. losing throttle connection to brushless motor
  177. Charge rate for NiMH Rx packs
  178. Electric motor with switch harness
  179. Help me with the Numbers on Amps!
  180. 12 Volt Jump-Start Battery as Power Source
  181. Aerial Photography
  182. Esc over heating
  183. EC2 & 3 connectors; difficult to disconnect...
  184. Motor problem - Flyzone micro rc
  185. Using KV as a guide from one motor to the next
  186. lipo battery chargers
  187. Suggestios to electrify Right Flyer 40T Trainer/ and PT40 Trainer
  188. A li-po question
  189. us aircore planes what do you think
  190. Hong Kong Landscape Day / Night Flying
  191. The same old power to weight question
  192. Electric airplanes
  193. Junior 1100mm (PNF) Wire
  194. Twin motor angle
  195. Important LipoSack modification
  196. Futaba R617FS Bind Problems (Strange!)
  197. 049 to electric
  198. HOB Electric Motor Recommendations
  199. Flying wing
  200. Dynam P-47 electric retracts
  201. Replacement brushless for Speed 400 with 4:1 gearbox
  202. FMS 60amp ESC programming?
  203. Glue questions
  204. Scratch build, need motors and battery packs???
  205. Motor compatibilities
  206. Connecting remote control to pixhawk flow sensor
  207. Decisions decisions
  208. Smoke for an electric plane
  209. supra x connectors
  210. LARGE Electric 4ch RTF?
  211. Great Planes Electricub II
  212. Hobby King Trainstar & DX6I
  213. Series vs. parallel battery hook up
  214. NEW hobbysiglo Flight controller testing video
  215. Parts for tw 747 cessna
  216. How to turn off 3AX stabilization system during flight?
  217. Buying planes
  218. ZD Fly Fantacy Racer
  219. Maxford USA Thanksgiving Special!
  220. Scale prop hub source?
  221. ESC Kill Switch
  222. Can you put an ECS and a 2.4ghz reciever next to each other?
  223. Dynam Products
  224. programming futaba 14sg
  225. What does the Electric flight field box look like?
  226. Beware the prop adapter.
  227. Dynam Tiger Moth....thoughts?
  228. Funfly 50
  229. Am I The Only One?
  230. Multiplex Twin Star II wing retainer straps quick fix?
  231. Electric setup for 108" C-130
  232. Catapult Designed for RV Jet Electric RC Plane
  233. Ornithopter
  234. DX6I transmitter with 27.145 receiver
  235. Electric set-up escapade .40
  236. Motor shaft replacement
  237. Second Plane Suggestions
  238. Lipo Battery Suggestion for Hanger 9 pulse xt electric pkg aircraft
  239. 130A WATT Meter could be used as chargers?
  240. Heli-Max TX610 work with Parkzone receivers (AR6400)
  241. E Sky heli 2.4ghz TX/RX on a Radial 3 ch. glider?
  242. battshare
  243. Quadcopter crash in Manhattan
  244. OrangeRx R410 Spektrum DSM2 Rx not compatible with JR x9303?
  245. Fast setup for Multiplex DogFighter
  246. Wing Servo Problems
  247. I'm sure this question is asked alot here...
  248. How to chose the right batteries for my set up?
  249. Help with Fuse Selection (challenge!)
  250. weight
