PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Problems with Flatouts
  2. I NEED HELP!!
  3. Interference on Slinger
  4. Do any planes still use NiCad's?
  5. Solar Electric Aircraft
  6. another Accipiter Baduis thread
  7. Fly RC Mag
  8. E-Power batteries
  9. Drive Calculator v3.02, Windows & Mac
  10. S & P
  11. Lipo battery capacity issue
  12. Anyone heard of a QQF brand radio system??? Need Info.
  13. wrong type of servo connecters
  14. Question to other JR radio Owners
  15. Which flying hydro?
  16. Electric Planes?
  17. new here and have TX questions
  18. Eflight Esc Question
  19. Electric Conversion Questions
  20. Removing rear cover on hitec optic 6
  21. BURNING SERVOS?
  22. Scale 2nd Plane
  23. Brushless or LiPo?
  24. Brushless upgrade for Multiplex Micro-Jet
  25. Which battery to use?
  26. First plane
  27. Heli Parts on a 3D Plane???
  28. x-ufo knockoff
  29. 49 " Nemesis 3 from hype ?
  30. GWS Slow Stick - Lead Balloon
  31. Power switch for battery
  32. First electric - what would you recommend?
  33. charging lipolys
  34. fried motor?
  35. Problems with sig kadet EP motor (smoking)
  36. E-bay Brushless 600 watt
  37. question
  38. Photos from recent Indoor Fly
  39. will this burn up my motor?
  40. seriously fun models. Zero cg ? please help..
  41. hitec 05s
  42. Multiplex EasyGlider pinion gear problems with brushless upgrade...
  43. Hobbico Sky Fly - Great $100 3Ch package
  44. Servo Speed reducer Help needed
  45. Can this be true?????
  46. a26
  47. foamy Best Covering?
  48. Hacker A30-28 Bullet Connector?
  49. amp meter question
  50. I call it "2Scoops
  51. GWS slow stick
  52. GWS Corsair 33.5 W/S
  53. MINIMUM Voltage for discharging a LI-PO is 3v per cell RIGHT ???
  54. Arlington TX
  55. Thunder Power 1010C Charger In Stock - Free Priority Shipping
  56. APC Slowflyer Props?
  57. E-Flite stick mount
  58. Painting fomies
  59. First electric plane
  60. APC Prop Snapped
  61. Great Planes Wright Flyer
  62. flight box
  63. QUESTION - RC RECEIVER CRYSTAL
  64. Recommend me my next plane...
  65. MOVED: Thunder Tiger Lazy Tiger Cub to Electric?
  66. Thunderbird-18 Brushless
  67. dare design catalina
  68. MWE Spring Fling 2006 San Diego, CA May 5-7
  69. Formosa stab incidence question
  70. Need help determining discharge rate.
  71. Hobbytron.com
  72. ELECTRIC FLY IN THIS SAT. IN ALABAMA
  73. 80's KYOSHO ZERO INFO?
  74. are polyquest good
  75. if you had 100 million dollars to spend...
  76. Simple Problem Please HELP!
  77. "Getting More" from Kyosho Ferias?
  78. How do I check CG ??
  79. Brushless motor power leaks
  80. Kawasaki KI61 - all balsa
  81. CArbon fibre Shocky mounts
  82. Term kV
  83. Please Delete
  84. Range Check
  85. The question!
  86. Any of you use these?
  87. kavan bloody mary video??
  88. CAP 232
  89. Brushless motors for Slow Stick
  90. Retracts on E-Flight P47!
  91. COX micro P-51 Mustang
  92. Great Planes ElectriFly Lancair ES EP ARF 43"
  93. looking for plane suggestions please
  94. Gluing servos in foam and be able to remove out
  95. Are electrics confusing or just not standardized yet?
  96. Ontario Ca. Creekside flyers
  97. outrunner - inrunner etc.?!?!
  98. ElectroStreak and Warp 4 4T motor
  99. Dummy Radial Supplier?
  100. Help! Electric Conversion for Buzzard Bombshell
  101. Kavan Wingo CG
  102. Electric Spacer Walker
  103. Battery AMP Setting / Challenger has NO POWER
  104. BECs - Elimination
  105. EZ 400
  106. dont you just love being ripped off?
  107. starting
  108. Brushless break issues?
  109. Help w/flaperon mixing on Futaba 6EXA
  110. PARKZONE F-27B STRYKER
  111. Flying Styro - P-38 Ligntning
  112. typhoon esc problems
  113. What is a fast plane for a Mega 16/15/2
  114. Installing pinion onto motor shaft
  115. lazy E bee
  116. Lipo esc vs Nimh Esc
  117. Lipo charging
  118. New 2006 catalog
  119. How do you make a bomb drop?
  120. anyone know anything about the f3a genie parkflyer?
  121. 2 speed 400's gd or speed 600gd
  122. Getting Back into the Hobby
  123. green models easy cub
  124. What electric motor do I need?
  125. need help an brushed 400 motors 6v and 7.2
  126. Pico Tiger Moth flimsy wings need tips
  127. Anyone using these Servos?
  128. Kokam Cellpro's
  129. Wattage AT6 Texan w/ retracts
  130. Katana Mini Questions
  131. E-filte P-47 motor ?
  132. electric connection help??
  133. GWS Warbird Outrunner Mount
  134. Basic Servo Question
  135. Mid-America Indoor Fun Fly
  136. Dyeing Wood
  137. Watt meter conections
  138. flying wings
  139. Gws Formosa Or Thunder Tiger Christen Eagle II Profile
  140. Hyperion P-51 first flight.
  141. enetring programme mode on c+c pheonix 10
  142. How Fast can I go for $500, less radio?
  143. Paul Gunther Prop
  144. batteries
  145. Electric power system questions for a large PBY-5a
  146. which plane
  147. Steerable, retractable nose wheel
  148. Time to vent!!!
  149. 24 volt mustang
  150. gws c130 help
  151. newbie Radio question
  152. Looking for Speciality Sources
  153. Something Wrong, I think!!
  154. How hot is your RC model! RCU's new photo rating feature live!
  155. Is this EP plane good?
  156. Brushless Wheel Chair Motors
  157. mini edge cg?
  158. what would be a good brushless setup for my AXON
  159. THUNDER POWER PACKS ??????
  160. new to electric questions
  161. Need a Airtronics manual
  162. RC ELECTRIC HOVERCRAFT
  163. Ultrafly - Ultimate Biplane ARF
  164. Thunder Tigre Rare Bear
  165. What is a good first float plane
  166. Esc cutout?
  167. electric park flyer
  168. hyperion yak-55p 3007/30 outrunner??
  169. World Models Cessna 182
  170. VirginAir 747, Where to buy?
  171. Video Capture Device for InFlight Video
  172. Parkflyer Cessna 182
  173. Hydro-Plane..Where is CG ?????
  174. Airtronics to Futaba servo wiring
  175. **free Miss Hangar One Plans***
  176. Customer support
  177. Motocalc and Wipa Firecat
  178. Soldering tip for a dummy
  179. j3 cub question
  180. newb help+suggestions
  181. Suggested 3d plane for AXI2808
  182. Why does my motor have a mind of its own?
  183. NiCD batteries won't take charge, whats up?
  184. Electric Profile Corsair
  185. Pictrures of you flying field?
  186. 3Dhobbyshop
  187. Hobbico Red Hawk and Sky Fly - Anyone Flown These?
  188. What plane? parkflyers, or....
  189. Advice from a NEWBIE for NEWBIES!!!
  190. Mini Ultra-Stick troubles
  191. Ulitimate setup
  192. Speed 400 servo selection
  193. anyone have an old "Cessna Centurion" made by "Union Model Co."
  194. Kill your Lipo..
  195. Battery Question
  196. Staudacher
  197. Best motor for Graupner HydroPlane 3D
  198. RIPMAX XTRA AIR 14 ESC
  199. removing press-fit pinion from shaft
  200. Electric combat
  201. reciever change
  202. Low battery power alert!!!
  203. help with mpjet gold connectors?
  204. Predator UAV- Anybody flown this yet?
  205. Ultra Mini Stick Battery
  206. Hinges on Tiger Moth 400 ???
  207. Upgrading - need your opinions please
  208. control surfaces
  209. THEFT ALERT - BATTERIES STOLEN
  210. GP Yak 55 EP Upgrade
  211. aero works
  212. Where can I buy a Twinspeedy?
  213. Help. Can anyone give me some advice on which products I'll need for my Aircraft
  214. Washer in brushless motor
  215. Bigger is better??? Anyone tried this?
  216. Changing Aerobird Xtreme frequency
  217. Glider To Electric
  218. RPM for GWS 350 6.6:1 geared with 11 x 4 Prop??
  219. ABX engine on takeoff
  220. Help with newbie prop shaft question
  221. Is there even such a thing
  222. What is needed to make a Electrifly PT-Electric take off on it's own ?
  223. e-flightline Tiger Moth 50 Help !!!
  224. Lipo battery charger did I get the right one?
  225. MY 1ST ELECTRIC ON ITS WAY
  226. Sig Rascal or GP Sportster?
  227. Dean's Ultra Plug
  228. Electric Motor Question
  229. how to measure small amts. of resistance???
  230. electric trainers
  231. electric rtfs
  232. MOVED: Buying Electric 3-D heli...advice
  233. Creasing foam airfoil ??
  234. Typhoon motor and electronics in a magpie???
  235. experienced gas/glow pilot 1st electric conversion
  236. Can the stock F-27 StrykerB batt charger charge this?
  237. plane just loops
  238. Sig Kobra Conversion
  239. GWS Pico Stick S elevator and rudder attachment
  240. Help me here brothers
  241. MOVED: HYPERION YAK 55 SP
  242. Michigan Hobby Shops List
  243. FMA Co-Pilot
  244. TOp new transmitter WK-1001
  245. prop saver and spinner???
  246. MOVED: Indoor Feb 2ed toronto, ON, Canada
  247. motor for a "TRIBUTE 3D" foamy
  248. Hangar 9 46% Electric Ultimate?!?!?!??!
  249. Cheapie from China via Ebay
  250. fliton extra 330
