PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Short crystals... what do they mean by short... leads or size of crystal case...?
  2. Possibly the World's Smallest R/C Airplane
  3. Proper rate for charging Nicad
  4. Flight Instruction basics??????????
  5. New to RC' ing
  6. Motor - Prop Selection ???
  7. Slow Stick vs Yard Stick
  8. Dare (Pat Tritle) B-17 ??
  9. Air Whistles On TwinJet Video.
  10. problem understanding Dean's micro connector
  11. SIG Kadet EP-42
  12. can someone tell me what that connector is called....
  13. Antenna Length
  14. 480 in a Challenger?????
  15. Question about a speed 600 motor... how much will it take...?
  16. motor and controller
  17. graupner = JR?
  19. Slinger vs. Zagi
  20. comprobation of the transmitter
  21. graupner /hitec compatibility?
  22. Help with weight
  23. Freeware sim???????
  24. Should I even bother with a lipo for a Slow Stick?
  25. electric motor props
  26. Convert 1/2A Pattern Plane to Electric
  27. Screwy videos from a screwy site
  28. AXI 2208/34 brushless motor....what can I put it on??
  29. Li Po Question
  30. GWS dual motors hmmmm
  31. Should i dispose of Li-po battery?
  32. Newbie just bought a radio on Ebay, how'd I do?
  33. Night Flying... how many of you do it...?
  34. Flying for a fee - a business model?
  35. CANOPIES
  36. Easiest/cheapest way to charge lipos
  37. Novak Rooster ESC
  38. J-3 Cub Video
  39. Night Flight Module connector
  40. esc problem
  41. what do you think of the GWS Dream Starter Radio/combo kit?
  42. Which Zagi for a beginner?
  43. Receiver antenna mistakenly got cut...
  44. How to fuse brushless esc ???
  45. Erratic behavior of futaba radio system
  46. How many points do I get for this Commander Crash?
  47. Whats that flying wing called?
  48. Whats the best J-3 cub out there?
  49. Can I use a Firebird Battery in a Slow Stick?
  50. New to RC...need your recommendations
  51. Electric speed control switch install ??
  52. what does all this mean exactly.. fora futaba 9 ch radio
  53. futaba hitc recievers ahhhh help
  54. Calculating Thrust
  55. APC prop on a GWS Tiger moth
  56. Speed Controller and Radio Info needed
  57. Helicopter electronics on to a jet foam pusher
  58. Maybe a Purple passion?
  59. Do you guys ever paint your props...?
  60. Need Prop help
  61. new leecy plans
  62. Charging NiMH Cells
  63. SIMPROP SPEED 7/14 MOTOR with 3-1 Gearbox.
  64. Looking for a big fat slow electric
  65. Phoenix Sailplane CG
  66. T-Hawk,, LiPo batt & moter easy replacement ??
  67. T-Hawk,, LiPo batt & moter easy replacement ??
  68. Triton,,, not getting full charge ??
  69. Connectors on Himax brushless motors....
  70. gws corsair electrics problem
  71. Electric Motor speeds up when i pull on positive wire
  72. T-Hawk flight times with NiMh batteries ??
  73. kranich power
  74. I'm ready to buy a new speed controller, but don't know which to order... help please...?
  75. Hobby Zone battery chargers?
  76. electrifly ploy charger
  77. Tired of looking at the mini katana ad?
  78. recievers
  79. Please help me select a motor!!
  80. MOVED: Funtana 90 Electric conversion
  81. The Patriot 4 Channel RTF - Any Good?
  82. alfa models p47 thunderbolt
  83. price for electric fun
  84. how do i set up elevlons on a wing aircraft?
  85. Where to look ????
  86. Funny Planes
  87. Does Anyone Have a GWS Dream Starter Radio
  88. Hi-Tec Radio trouble. X-Post from gliders
  89. Cheap Wal-Mart non-RC planes; values of the capacitors and general parts information...
  90. What is your favorite GWS plane?
  91. Two fans for turning?
  92. Counter rotating props ?
  93. Great Planes Four Pack LiPo Charger...
  94. What size caps to solder across motor input?
  95. Do you have a "keep-in-the-car" aircraft?
  96. hobby lobby fmadirect
  97. Side thrust question
  98. lazy bee's
  99. new guy question
  100. Help please Micro Whizz B/less & Li-Po setup
  101. MODEL AVIATION MAGAZINE
  102. MODEL AVIATION MAGAZINE
  103. plane choice
  104. Battery Manufacture
  105. E-Flite Ultimate EP Brussless 400 12-6 prop
  106. How do you keep foam wings from flexing?
  107. LiPo batteries... don't forget to turn it off... hehehe
  108. Got Firebird 400 Today Pictures...
  109. measure amps
  110. BRUSHLESS Controler How to ???
  111. wire size?
  112. Making Servo Extensions
  113. Digital Servos and Analog Servos
  114. World Models Rambler EP
  115. AXI 2814/10 best battery?
  116. Cell type???
  117. Where can I find parts for an original Firebird?
  118. Where can I find parts for an original Firebird?
  119. MOVED: Goldberg Tiger 60 conversion
  120. thrust to pound ratio??
  121. thrust to pound ratio??
  122. thrust to pound ratio??
  123. Megatech Help
  124. PC Power Supply for AC/DC converter?
  125. Sombra Labs Shadow receivers
  126. Stupid me another wrecked plane
  127. Beginner's Question For You Guys
  128. rubber band glider
  129. funny motor pulsing
  130. Anyone flying foamies in Beaverton/Aloha, OR?
  131. some advice would be great
  132. Serious Glitch. Where do I look?
  133. P4 computer powersupply to 12v chargers
  134. Prop shaft Bending,, need a fix,,<<<<
  135. MOVED: Glow to Electric
  136. SMALL event.
  137. Eflite motor won't start
  138. Crashed Commander nose first-motor pushed in
  139. this isnt supposed to happen to electrics...
  140. Beginner Plane
  141. MY NEW WEBSITE
  142. how far will you trust a company
  143. WANTED: Superstar wing w/ailerons
  144. Wattage Corsair electric help
  145. Does anyone know were to get????????????
  146. MM Switchback Battery and Motor Questions
  147. Whats a more effective tail mod?
  148. 27 MHZ radio in a Glow plane. Is it safe?
  149. Hanging in a tree
  150. Wire to use for home made Landing Gear?
  151. Jeti Advance Plus controllers
  152. spinner for a motor with 3mm shaft
  153. Small pylon plane (27.5" - 7.5oz), cheap brushless?
  154. Smilies
  155. Calculating theoretical vice actual power
  156. Speed300 size racer plane, going brushless?
  157. nimh
  158. Hacker 20-20l / goldberg tiger 400
  159. Recommendations for P-38 ARF kit please.
  160. Himax throttle loss, servo glitching
  161. He
  162. Just bought a Firebird 400 - Questions
  163. Why so much battery?
  164. ESC cutting power to motor and other problems
  165. Toledo Coverage
  166. Triton Charger and LI-PO charge amperage
  167. Types of foam
  168. Blue Bird servos ( any good )
  169. Aerobird Extreme
  170. How to use POR UHU glue?
  171. Hobbico Digital Mini-Tach question
  172. Hobbico Quick Field Charger Input Voltage
  173. recommend motor for great planes yardstick?
  174. Night flying and new navigation light source
  175. small scale electrics
  176. Hobbico SS EP Motor Sparking/missing
  177. Using both Electric Ducted Fans and Fuel
  178. electric fun fly rockland county
  179. VOTE Electric Spitfire Color Choices
  180. Triton or Ice charger, Which is better overall?
  181. Need Cowl!
  182. Travelling with Lithium batteries.
  183. Why do the electric ARF's fly so poorly?
  184. Why do the electric ARF's fly so poorly?
  185. ***** Help on Navigation Lights *****
  186. Park Flyer Wheels
  187. Estarter props?
  188. Can I charge through my ESC?
  189. wing dragon acting loosing control
  190. Fast ways to charge the TX Battery
  191. Hobby-Lobby Raven
  192. Second Annual Kishwaukee R/C Flyers All-E Fly-In
  193. Li-Poly over-discharged
  194. **Help!** Transmitter Problem? or Receiver?
  195. Any good Electric RC plane with Ailerons?
  196. The LiPo dance
  197. wheelless landings
  198. I got my Wattage Micro Flyer today!
  199. How are you storing/displaying your planes?
  200. Alfa Model F4U-1 Corsair ARF ?
  201. Has anyone here tried an Ornithopter ?
  202. basic tricks that the Aerobird Challenger can do?
  203. Connecticut RC dealers?
  204. PT-Electric. Looking for upgrades
  205. What am i ready for?
  206. Please Explain Motor Turns, Sizes, Ratings
  207. GWS C-130 vs EAM C-130
  208. Help with hitec feather 4-channel receiver.
  209. Help with li-poly plane please.1
  210. What electronics with my JR PCM Tx
  211. Teaching 2nd graders about aviation.
  212. General Electric ???'s
  213. **Looking for U.S. Air force Decals C-130**
  214. servos and voltage on a esc
  215. FMS Simulator Problems
  216. Clear Tape Hinges
  217. GWS OR GP F4U-1A
  218. Firebird Commander Field Size
  219. What do you use YOUR broken props for?
  220. Aerobird - Fixing an electrical problem
  221. Hey where's the scale forum?
  222. Anyone help organize an indoor flying event?
  223. Crash Proof Trainer Kit??
  224. Ultimate dumb Noobie question....
  225. timing of cobalt 400 motor
  226. Brushless Motors
  227. battery weight problem
  228. Where Do You Fly?
  229. Took the plunge need help calculating
  230. very important battery help plz!
  231. How Long?
  232. Thanks Old Man
  233. Thrust angle
  234. I know i'm gonna get Newbed for this...
  235. Elevons vs V-tail
  236. Alternative to fiber-lite landing gear?
  237. RC schools??
  238. throtle cuts off on superstar ep
  239. are mini/micro accessories to small for this plane
  240. to good to be true?
  241. planes for the mpjet25/25-26 mk2
  242. Long-EZ by badsplice
  243. Battery help!!
  244. I Need HELP!!!
  245. Pacific Models Zlin
  246. GWS C-47 Brushless Conversion
  247. World's Largest Aircraft
  248. tly purchased
  249. Kite launch?
  250. Where to rout the antenna?
