PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38
  1. E-Flight Tribute-More questions(servos, hinges)
  2. How do you figure CG
  3. Motor magnets exploding
  4. COLD HEAT SOLDERING IRON MINI REVIEW
  5. Glitches / motor problems caused by 2mm connectors
  6. 1.25 mm connectors needed 4 FMA receiver
  7. Fort Collins Colorado
  8. Montana organization?
  9. MINI dean on esc??
  10. E-Flite Tribute 3D & basic hookup questions
  11. blue arrow servos???
  12. Looking for people to fly with in Indiana
  13. Electro Fieldbox - How do you guys lug it around?
  14. prop question
  15. Question on a 100w Power supply
  16. Fun times flyin' the Stryker
  17. Great service from E-Flightline!!
  18. Welcome LVRCFlyer!!!
  19. krylon short cuts paint..for painting foam...
  20. Parkzone Servo Plug
  21. ? Four "unused" pins on Stryker Receiver?
  22. MOVED: MATCHSTICK PLANE POWERED BY FLIES!!!!!!!!
  23. Very interesting story.
  24. Blue Himax gear box and prop adapter?
  25. Flyrc L-19 BirdDog Plans
  26. Sudgest a Plane for a Brushless 400
  27. Smokin' Slow Stick (gotta see the pics)
  28. Brushless motors
  29. Last post in electric section
  30. Electric 'problems'
  31. Jinxed Tiger Moth 400 ??
  32. Too many crashes to count... but plane keeps tickin'!
  33. Question about HobbyZone Firebird IIST
  34. Bishop Power Products
  35. WATTAGE HYPER WING 400....
  36. what is wrong-I need some help
  37. Hyper wing 400...
  38. Slow Stick UFO
  39. That horrible feeling of seeing your plane...
  40. simprop sukoi/mpjet/batteries?
  41. XF-11 Plans
  42. HAPPY NEW YEARS ALL eom
  43. NEVER BUY THE WATTAGE CESSNA 180!!!
  44. Gorski29 or southwest rc warning.
  45. Opinions on reflective/refractive tape...
  46. Which is better...
  47. Best Choice - 2808 and 2812 Himax.
  48. any electricians out there????what should i try next??
  49. any electricians out there???? what should i do next??
  50. Can you convert hard drive motor to brushless?
  51. mpjet 25/25-26 mk2 lipo configuration
  52. Customer Service
  53. Point of CG on the Wattage Cessna
  54. Need help on purchasing a Li-Po Charger
  55. I dont like himax/maxx products!
  56. 2.4Ghz camera range
  57. Apache 2500 charging...
  58. P-38 profile foamie
  59. My first flight was so awsomely bad....
  60. It may be obvious...but humor me.
  61. pro-peak mercury ex not charging
  62. GWS Slowstick Flite pac
  63. New F-27 Stryker for x-mas! Frst flight adventures!
  64. Electric LT-40
  65. noob to electric
  66. Prop for NESailplanes Mamba
  67. FM/AM Radios
  68. ***Help on a Battery Charger****
  69. It is great
  70. can you put a exterior charge plug on batts where
  71. Where is a good online battery store?
  72. single conversion receivers
  73. Newb question, newb answer, just like that
  74. Horizon Hobby tech info
  75. Kavan Tri motor
  76. Luminescent glow in the dark paints...
  77. Fantrainer
  78. Any good flying areas near New York City?
  79. homemade plane question - newbe
  80. Electric plane to carry/launch 2M sailplanes
  81. Merry Christmas to all!
  82. Suggestions for a behind the seat Park Flyer
  83. Anyone own something from Kavan?
  84. Airplane suggestions for a Himax 4100??
  85. PARKZONE,,,, J-3 CUB battery question!!!
  86. instructions for TMM et3 Controller
  87. Lately Ive been looking into Biplanes...
  88. 12 VOLT POWER SUPPLY..BEST DEAL...
  89. Tape.....checkerboard...
  90. Be careful of COMPUTER VIRUS..
  91. Electrics in Amador and Calaveras counties?
  92. dual vs. single conversion receivers
  93. Do they make an AC to DC power ....
  94. KADET ARF
  95. motor for sukoi simprop
  96. pt19 seagull plane glow to electric
  97. motor sukoi simprop depron
  98. A good second airplane
  99. Flyers in Portland OR
  100. I need SHOCKFLYER control horns and screws,,,
  101. weigh planes
  102. New electric rc flyers flights
  103. Cold Heat-soldering iron review...
  104. Help on Battery, ESC and Radio
  105. GWS PIco Replacement Parts?
  106. adding electric to home brew sailplane
  107. Triton Charger and Lipos
  108. New Cessna from Wattage
  109. 3 channels, four channels?
  110. Wattage Pitts Questions
  111. How would this plane be
  112. TMM 18e+s controller Instructions HELP !!!
  113. Electric flight is still too young
  114. "Watt's Up" R/C Watt Meter
  115. GWS Beaver
  116. Sunracer CG Location
  117. ***HELP on ESC, Battery and Radio****
  118. FOUND NEAR BOSTON: An electric-powered RC model
  119. FOUND NEAR BOSTON: An electric-powered RC model
  120. Will my Berg Stamp work with my tmm ESC?
  121. Extreme Flight Yak 54 - 68" E-Conversion Review Online in RCU Magazine
  122. CAN,T SEE THE WMV VIDEOS ON MY IMAC HELP
  123. I.F.O covering help!!!!!
  124. Battery Problem Alert
  125. Fromosa.... fastest GWS plane?
  126. any members on here in the Maryland area...
  127. Electric Flight Boxes
  128. Help setting up a GWS system?
  129. Hobbl-Lobby's ThreeDee 400 C.G.
  130. want to build the sickest, fastest ProJeti ever!
  131. Motors with built on controllers
  132. ultrafly cessna or graupner Stinson Voyager
  133. Looking for 1/2" square carbon tube!
  134. WattAge Staggerwing
  135. Tensor-where?
  136. looking for online sales for LEHNER BRUSHLESS MOTORS
  137. Aerobird Balance and COG
  138. Plane for PJS 800
  139. Electric calculating programs
  140. allerc hobby shop..
  141. advanced trainer query
  142. Slowly converting to electric... charger advice.
  143. SWALLOW CHARGER CONFUSION
  144. ***Painting Question C-130*****
  145. Frequencys for electric flyers...
  146. Speed 400
  147. Question about Ikarus Shock Flyer servos
  148. Miracle epp
  149. electric info needed
  150. Problem with Berg receiver
  151. Hooray !!! for allerc.com
  152. honey bee2 esky
  153. Hobbico Quick Field Charger MK2
  154. Castle speed controler
  155. BEC (Battery eliminator) construction
  156. Charging Lead Acid batteries
  157. EPP Adhesive
  158. Electrical load...
  159. ***Where can I purchase Decals?***
  160. FYI: Mobsterhobbies on E-Bay -- YMMV
  161. Removing graphics?
  162. colco tail motor help please!
  163. Blitz Flying wing from Dymond
  164. Air Whistles.....
  165. CoverLite
  166. Apache 2500 vs. Electrifly
  167. sanyo cells, 1.2 volt
  168. GWS TigerMoth 400 - What ESC/Li-Po/Charger to get?
  169. Reversible ESC In A Plane?
  170. Cermark Dragonfly Hop-ups
  171. hacker b20-26s
  172. $99 proportional 4 engine fan jet 48" span @ Walmart
  173. My Firebird Commander Lights
  174. Apache 2500 lights flashing? Help?
  175. Plantraco DSP4
  176. Projeti power setup?
  177. Seattle Winter Indoor Mar 5, 2005
  178. slow stick drop
  179. Help - Brushless motor set up problems!
  180. what type of 3d electrics
  181. what type of foamies
  182. Easy Star or Ventura?
  183. Post pictures
  184. Flaperons
  185. Prop opinions for level flight
  186. Another GWS Tiger Moth terrorizes the sky...
  187. My favorite online sources for electric fliying supplies
  188. anyone tried this Thunderbat??????????????????
  189. Hobbico Quick Field Charger MKII any thoughts!
  190. HITEC CG 335
  191. Can the Triton Charger recharge my 8.5 V 3 Cell Li-Poly?
  192. ***Question on wire gauge size****
  193. Where can i find free plans?
  194. Firebird Commander
  195. 4-Motor Slow Stick Video
  196. Best lite covering
  197. Can someone offer advice on this setup?
  198. R/C flying book ideas?
  199. Great indoor flyin!
  200. Little Hobby-Lobby Mig-15 Video
  201. Li Poly charging container?
  202. Actro 60-175/ Carden cuda electric
  203. Use of APC 12-6E prop on Himax gear drive
  204. Light weight iron coverings
  205. Better battery for Tyco Sky Scorcher???
  206. Dual/Single Conversion
  207. Erratic Servo/Motor problems
  208. ESC for NMH vs Lipo Bat
  209. The basics of electricity
  210. NEED HELP WITH ESC ???????
  211. Anyone doing aerial photography?
  212. General Li-po and newb electric q's
  213. Please Suggest First Electric Park/Backyard
  214. HELP! HELP!Ripmax Pro-Peak Zing Charger
  215. Help, what is this plane? Proper CG?
  216. Interferance
  217. Flying near an electric company substation.
  218. Hobbico Superstar EP CG
  219. Rx vs Tx
  220. glitch fix?
  221. Electric RC Plane Video Contest
  222. Good Electric Plane For Moderate Wind
  223. Center og Gravity
  224. Should i get a new plane?
  225. What cells would you recommend from CBP?
  226. your scratch builds
  227. An X Plane
  228. best plane for a beginner?
  229. Colco Thunderbird
  230. NiCad Chargers
  231. Challenger Guts Put Into A New Plane
  232. Mounting options
  233. Dominator 500
  234. how big is too big
  235. Serious Duration!
  236. cells
  237. Hitec Feather Single convertion with Futaba 6VA dual conversion !!! Is it possible?
  238. Question about 27 mhz
  239. Cermark Easy Electro-72 question
  240. SS/Slo-v snow skis?
  241. Ultrafly Model Extra 300
  242. chargers
  243. Affordable housing gearbox question?
  244. Flying on channel 55 in Trophy Club Tx
  245. anyone ever fly the CCLee C17E?
  246. high tech question Please read!!!!
  247. AXI 4120w/jetti70 ESC or Mega 22/30w/Phoenix80?
  248. Battery Question
  249. will I stall my estarter
  250. 1/12 scale DC-3. Electrics Yes or No?
