PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38
  1. Mega motor 16/15/3 came without tab
  2. Indoor place to fly near Portland?
  3. need help with jeti-08 3p and li-po's
  4. Astro 109 Prices?
  5. Mark Rittinger P-40 Warhawk - Plan
  6. Is the wheather this bad everywhere else?
  7. fms flight simulator
  8. Lipo Charger
  9. Good Flying P-38
  10. RX TX Servo set up
  11. Apache 2500 power source?
  12. Tensor kit???
  13. battery charger
  14. lights
  15. aileron or rudder
  16. JR 8103 & Hitec Electron Dual Conversion RX?
  17. GUILLOW ELECTRIC POWER PLANT???
  18. Better battery for Estes Sky Rangers Jet?
  19. Praise Where Praise Is Due!!!
  20. lipoy's and brushed
  21. TX antenna length question
  22. Need Help w/E-flight Ultimate
  23. micro bipe plan??
  24. Heat sink on ESC
  25. Equivalent of MABUCHI 550SH motor?
  26. SON OF A GLITCH!!!!!
  27. eflites - ascent glider
  28. ATV
  29. What size brushless?
  30. Newbie Quick reference needed!!
  31. GP Electricub with Magnetic Mayhem
  32. Bluebird Servos
  33. Biplane CG
  34. Fly Electrics Near Yorba Linda, CA?
  35. Li-Po and Brushed (can ) motor
  36. Balsa Products Co
  37. LiPoly and Phasor 30/3
  38. Covering material comments
  39. *****Cheaper in Price Question
  40. 240v to 120v conversion
  41. Help, looking for motor mounts
  42. HELP Why is speed control kicking out
  43. How do you know if an ESC is appropriate for LiPo?
  44. Razor V2 in Shockflyer???
  45. Go Brushless CD Motor and Delta Electronics
  46. New to electric
  47. Electric motor breakin Please HELP
  48. receiver ? for SmoothE (mountain models)
  49. **Questions 400 Motors, Battery packs, Speed Control***
  50. Clancy Turbo Bee - Does it fly with a speed 400?
  51. trying to decide between Smoothe & Dandy Sport
  52. Get your toddler a plane - sorta
  53. Speed 400 ESC, battery, charger choices
  54. Whats this? How to make it fly?
  55. You know the Jobar....?
  56. ECalc?
  57. F27 Stryker Questions
  58. ****Thrust 10 oz Questions *****
  59. Tigermoth 400 battery question?
  60. Where to get fiberglassing info?
  61. slow burning jato for takeoff
  62. Great Planes SLINGER
  63. Is this a good plane?
  64. Draganflyer IV problem : constantly need to compensate for heading
  65. Plane for Astro Flight .15 Cobalt
  66. GLITCH CITY!!!!!!
  67. Which engine/Li-po combo for a Super Cub??
  68. A couple questions regarding JR8103 Tx and GWS flight pack?
  69. 45" Tucano Plans??
  70. Triton Cutoff Voltage
  71. B29 Quality?
  72. Smoke for my Ultimate? electric?
  73. zap foam safe ca cure problems
  74. Beaver Battery Upgrade
  75. help me choose a model please
  76. FUTABA 6XA SUPER COMPUTER TRANSMITTER
  77. Carbon Rod question
  78. Q: I want to change my "fly-for-one-minute" electric airplane in one that can fly longer
  79. Battery Charging
  80. recommend a gearbox for speed 400
  81. ANyone fly the Mountain Models planes??
  82. Juvenile Diabetes Research Foundation
  83. speed 400 gearbox
  84. Looking for TINY Pushrods
  85. veneered foam wings online?
  86. Battery Charger Question
  87. Need help wih special RC Boat
  88. why not have the tail on the bottom?
  89. Beginner Park Flyer
  90. Tail Dragger AARRGGHH!!!!
  91. Finding the CG
  92. omei 2000 ep basic questions
  93. Elevator to throttle mixing
  94. GEARBOX ratio question!
  95. Carbon Rods???
  96. ***What Size Motor would I need*****
  97. An equipment question..
  98. Titanic Airlines Electric B-29
  99. HS-81MG servoos
  100. battery connector
  101. Micro receiver question
  102. *****Help on Scale Size C-130 ****
  103. Looking for EPP sport flyer
  104. Zinc Matrix - Future Of Batteries
  105. Slinger question 2
  106. Kyosho Stratus Sport
  107. electron 6 question?
  108. CG Calculator
  109. Changing GWS EPS 300 gearbox shafts...?
  110. ESC/Receiver Interference
  111. Estarter and/or SuperStar EP 4ch set up
  112. Fred Marks on LiPoly Tech in AMA forum
  113. Help..what does
  114. Zagi power problem
  115. ESC - what do you use when you say it?
  116. Li-Poly Power Density Numbers
  117. Switching frequency of brushed motors.
  118. Disapointed with park zone
  119. Write a review for RCU
  120. IRC Channel up and running
  121. Pico stick J3 hopped up
  122. Inviting Entries to Electronic Design Contest win $100
  123. Foam only kits ????
  124. VTOL motors
  125. the big dilema
  126. MOVED: Foam Safe CA
  127. using electric power in a guillows kit
  128. Q about my new KOKAM
  129. 2 questions re: triton
  130. Gold Eagle XXL
  131. Replacement ultrafly gearbox?
  132. "CHARLEY" New Plane
  133. well I am hooked now LOL
  134. ****Help Again 4-blade propeller*******
  135. Found a new use for my hyperwing
  136. charging lipo's
  137. NSP brushless motor deal
  138. FORCED OUT OF THE SKY!!!!!!!!!!!!!!
  139. Alfa website URL
  140. My Latest Build, Aeroswift Flying Wing EDF
  141. Source for colored packaging tape?
  142. Megatech MegastealthII
  143. Purchased an Ultrfly Cessna 182.....
  144. CD-AC conversion
  145. Want to try electric
  146. NEAT Fair Washout & Heroics
  147. Ultimate LI Charger (Robbe)
  148. ?lost model alarm?
  149. Prop mounting question??
  150. Stronger gears for Hitec HS 55?
  151. Thrust line
  152. ShayRC Picture Gallery - Win A Model Airplane
  153. Hobby People Micro Flyer?
  154. New WM Clipped Wing Cub and Rambler
  155. gearbox on an IFO??
  156. mah draw on GWS R4PII
  157. New Plane
  158. Plane in a treetop
  159. Help - Down and right thrust amount?
  160. Polks Hobby model airplanes ANYONE ?
  161. Graupner Ultramat 5 How many cells?
  162. K&A,A-10
  163. ? about speed controllers battery limits
  164. IM SO STUPID!!! ARG!!!
  165. New Pictures and Video - Chilliwack Electric Fly In
  166. graupner ultramat 25
  167. Mig-3 Original Mega Power
  168. timing Kyosho Endo
  169. NEAT Fair event
  170. USM Drive
  171. Best connectors for Super Whattmeter
  172. gws spitfire
  173. airplane storage problems
  174. Small Sail Plane 55", What motor?
  175. Do I have this right about "POWER"?
  176. GWS Mini Retracts?
  177. first laser beam to power aircraft!!! Way cool!
  178. Jeti Speed Controller, Is there an auto cutoff?
  179. $$200
  180. MOVED: Hanger 9 Gas - DC
  181. Newbie - brushless nimh Slowstick or not?
  182. A slightly strange idea: Industrial Design Project
  183. TDL MODELS
  184. Looking for people to fly with in Tualatin/Portland Oregon
  185. RTF High performance wings
  186. Pictures and Video of the Chilliwack August Electric Fly In
  187. Looking to build a B17
  188. Wing design help...
  189. Help - Am I flogging a lost cause?
  190. P-51
  191. [Deleted]
  192. FMA Low Voltage Flight Packs
  193. Important tip to prevent warped wings!
  194. New to electrics
  195. controler problem
  196. [Deleted]
  197. Hobby Zone Battery packs
  198. do DARE models fly with what they recomend
  199. Good second plane?
  200. Building Question
  201. would a 370 motor burn up an ics 300 esc
  202. Ultrafly Cessna 182 w/400 ARF
  203. RC Amnmeters
  204. Multiplex LN-2010 NiMH & LiPoly !?!
  205. anyone live in Portland, Oragon ? or know RC Hobbies aka micro r/c racing ?
  206. Frequencies for Wing-Dragon II...
  207. Help with a ELECTRAFUN please
  208. Broken Landing gear.. can I solder or not?
  209. Nitro Capitol Flyer Problem
  210. ANY SUGGESTIONS ON WHAT SCALE TO BUY????
  211. Has Anyone Flown The Electric 63" DeHavilland Mosquito From Dymond?
  212. High Performance/durable combat plane?
  213. covering balsa fuse
  214. motor mount question
  215. Know of a good LHS around Baltimore?
  216. Need a micro servo for aerial photo?
  217. Need help with whacky servos
  218. Sweet Mini Digi Camera I got for Aerial Pics.
  219. battery website
  220. software program? and battery question
  221. A funny thing happened at the field last night...
  222. busted my speed control
  223. need help ordering first electric plane
  224. Problems with my himax 2025
  225. PJS vs AXI 2208-34
  226. Electric B-17???
  227. Good motor, NIMH Batt, prop, setup for my Thawk?
  228. Hacker Motors Alliance Model
  229. shocky pix
  230. Source for carbon fiber spars?
  231. What is the largest size electric plane on the market today
  232. need help with covering
  233. Anyone ever fly while DRUNK?
  234. Hummer W/400
  235. Should i get a SKY SURFER?
  236. noise-suppression capacitators question:
  237. Popularity of speed 400 motors
  238. Where to buy JST connectors?
  239. Electric Help
  240. A-10 50 to 55
  241. WHERE DID AV8HOBBIES GO ?
  242. Importance of Brushless ESC for a Brushless motor
  243. Battery Packs and Shrink Wrap
  244. GP yardstik.. ACTUALY FLEW~!!
  245. Need help with my Himaxx/Lipo Set up
  246. radio problems!!
  247. How do I hook up my pinhole camera?
  248. splash-e
  249. IM CONFUSED ( AS ALWAYS )
  250. Programming a Kontronik Sun 300 ESC?
