PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38
  1. SWEETEST VIDEO EVER!
  2. build around 2212\26
  3. My reciever is broken.....
  4. Charger Questions.... please help
  5. Electric Sailplane--Need advice Guys
  6. Electric Plane for 5500' Altitude
  7. Antenna inside or out ??
  8. Just crashed my Wattage Turbo Vector Ducted Fan plane...
  9. Help with Kyosho AP 29
  10. New P38 from Flying Styro, how is it?
  11. My Wind Dragon II is melting.
  12. Mig-3 build - new design
  13. airplane set-up
  14. A rubber powered Sea Fury converted to electric RC??
  15. Flight battery and wireless video
  16. What's the diff?
  17. Mike ShowTime McConville Joins TEAM RCU!
  18. ARF vs GFY
  19. battery
  20. battrie charger for li po ?
  21. Jack Stafford Models
  22. Mini Wireless Camera?
  23. Commercial seller supplier inquiry
  24. Commercial R/C seller supply inquiry
  25. Combat Models A-10
  26. I just got my first rc plane!
  27. Aerial Photography
  28. ESC, BEC MOTOR SIZING QUESTINGS?
  29. REALLY weird slow stick
  30. It'll be out WHEN?!?
  31. Astro speed control manual \ programming
  32. Can I change crystal ?
  33. Li-po charging rates
  34. My Flying wing Slinger (HELP)
  35. Astro flight 010
  36. Who here has the best forum avatar?
  37. Depron compatable paints
  38. VIP
  39. Ripmax EasyStreet!
  40. Wattage Any Good?
  41. Radio Cut out
  42. Thunder Power "C" Rating
  43. Does anyone know of a nice sized electric mustang?
  44. Not Cutting the Red Wire when using a UBEC?
  45. Vintage Mattel Electric ARF???
  46. Question about radios and receivers
  47. sodering hands from Harbor freight $2.99 pic
  48. brushless rpm same as brushed?
  49. Calculations for Electric Motors
  50. Hobby Lobby Travelair Mystery Ship
  51. What would be the best lipoly pack for this?
  52. Great Planes electric douglas DC3
  53. Help with Sig rascal electric
  54. what kind of reciever will work
  55. electric B-17
  56. Smoke
  57. Best Brushless Setup for Heckler
  58. Gillows Fokker Dr1. HELP!!!!!!
  59. New to Rc flight.. need some help
  60. Glues--super 77 in particular
  61. SCALE ELECTRIC WARBIRDS
  62. Transporting
  63. great planes j3 cub
  64. Maidened my GWS 109
  65. PC power supply cuts out
  66. Plans for Depron "built up" flying wing
  67. converting to brushless
  68. newb ????s
  69. Will hs-55 servos work with twinjet?? battery?
  70. Beeping from motor and no throttle control
  71. my first flight/wing dragon
  72. Sig Rascal Nightmare!
  73. Can a frequency checker cause glitches?
  74. Calling all Hacker with ThunderPower Pilots!!!!
  75. want a new 4-channel reciever
  76. need help on gws servo gear replacement
  77. Astro 020 "Corona" Heli work on a GWS SLOW STICK?
  78. Simple Question Concerning Triton And Accu Cycle Elite
  79. Chargers
  80. how to set up radio gear
  81. MOVED: Post in wrong thread
  82. Are these Kokams enough for my use ?
  83. GWS 370 motor break in ??
  84. Astroflite 035
  85. Wattage Reno Racer
  86. Triton charger problem
  87. My new Stryker F-27!!!
  88. Depressed!
  89. GWS 109 Paint help please!
  90. CF Tubeing replacemant for wing stiffining?
  91. My first Plane!!
  92. 2s or 3s LiPo for 6 volt Speed 400 motor ?
  93. Electronics question.
  94. Motor ID
  95. Electric Flight International Jan/Feb '98
  96. Supplier at SEFF
  97. Multiplex Micro Jet
  98. fb commander or megatech airstrike
  99. How do you test motor amp draw?
  100. !wow!
  101. Warbird starter plane help!
  102. How good is Hobby-Lobby's return policy ?
  103. can you fry a receiver by hooking it up wrong?
  104. Vodoo Electronics!?!
  105. formosa gearing question...
  106. Ordering a Slow-v...HELP!
  107. hotliners,pylon,powered gliders
  108. Why join a club?
  109. Astro Flight
  110. Firecat after 240 Flights...
  111. MOVED: needing advice on setting up a electric kit
  112. MOVED: Electric Fly-In in CT
  113. GWS ZERO WHIPPED!!!
  114. MOVED: JR Indoor Electrc Festival
  115. How to increse throw on JR341 servos ?
  116. Slow Stick- Built and soloed today
  117. mp jet 25 35 20
  118. Best stores for e-flight gear
  119. Who makes the AVX 434 Mini 2!
  120. Charger Not Charging......
  121. I have Carbon Fiber and I need advice
  122. ACT Me163
  123. Telemaster Electro
  124. Firebird Commander landing on sand??
  125. Formosa motor upgrade take two...
  126. Formosa motor upgrade.
  127. A call to all ParkZone Cub owners
  128. getting into electrics(first class)?
  129. firebird 400
  130. KAN BATTERY BREAK-IN???
  131. ESC, BEC and Reciever's
  132. GWS...how good?
  133. Backyard Hobbies Warning
  134. Anyone have the newest Quiet flyer and a scanner?
  135. precdent high-fly glider help
  136. good brushless motor for gws gearboxes
  137. Annex flying wing from hobby lobby
  138. Need some suggestions !! badly
  139. Battery question
  140. Power Problems
  141. ParkZone/Kyosho J-3 Cub foam material question
  142. [Deleted]
  143. [Deleted]
  144. Problem with radio instalation...
  145. New electric only Super Chipmunk
  146. Motor lubrication
  147. fCCLEE Cub Help Me!
  148. WHAT TO BUY...USE...ETC.
  149. 3D RC Planes, Check them out!!
  150. Inexpensive UAV, carrying radio repeater
  151. Difference between Graupner & other?
  152. aerobird extreme
  153. receiver crystals
  154. What is too hot??
  155. Increasing Visibility and Amateur Radio Frequencies
  156. Foam!! Where to buy??
  157. Trim keeps changing
  158. Anyone Flying A Kavan Sopwith Pup? Need CG Info!
  159. next plane?
  160. GWS 300E speed controller with 400C Slow Stick?
  161. new plane pic
  162. Radio Inteferance from ESC or Motors?
  163. Glue questions
  164. I need help about a quick charger.
  165. Inteferance
  166. Which “Speed x00 motor” for 12V 3cell Lipo
  167. Jinxed plane
  168. MEC Brushless Motor Line
  169. Himax 2015 or 2025 for GWS Corsair
  170. Hobbyzone Sonic Combat Module questions
  171. short lifespan...
  172. Which Plane to Buy?
  173. Kyosho - aka ParkZone - J-3 Cub FIRST FLIGHT
  174. what to buy?
  175. ABC replacement fuse- need help
  176. Jumping Jack 3d motor choice?????
  177. Airplane Identification
  178. Slow throttle response
  179. Indoor flying in Houston
  180. E-Flite Park 370 w/Vasa 55 and JES-8-3P question
  181. Stadium flying
  182. 7.2V 900mAh battery in Slow Stick
  183. Elevater pushrod failed!
  184. Weird charging problem - HELP !!
  185. First F27 Stryker Flights!
  186. Prop size vs Current draw
  187. The dreaded flat spin
  188. gearbox selection questions
  189. Freedom Flyer Batteries
  190. Looking for a good kit
  191. Help on Easy Star
  192. Strong, Extremely Fast and less than 4lbs!
  193. HF 30A ESC (w/ BEC, Break, programmable Cutoff...) ?
  194. HELP, I can't fly!!!
  195. where should I set up my COG?
  196. PBY CATALINA
  197. Why more people are turned off by electrics
  198. Futaba Tx prices
  199. To or Not To Shottky Diode
  200. Are the Wattage Servos any Good?
  201. Looking for bulk carbon fibre slow flyer spars
  202. Mabuchi same as Graupner?
  203. Kyosho Electric Zero M36
  204. Slow Stick Package
  205. Hi Performance 280?
  206. GWS products in Japan ??
  207. Potensky Charger help
  208. What servo's work?
  209. SR Smart charger manual?
  210. Antenna Spools?
  211. RCU Magazine Review - Northeast Sailplane Products Vermont Belle 1300
  212. [newbie] Servo adjustment?
  213. Best Way To Add Ailerons To a Foam Wing
  214. Tower Hobbies radio compatiblity
  215. Battery Charger Capacity
  216. Electrolytic (Distilled water?)
  217. Frozen Servo?
  218. slinger problems
  219. axi motors
  220. Wattage Mini Thermalaire need advice
  221. Electric
  222. Zagi Aveox Electric Motor.....What Could Be Wrong???
  223. setting up thrust angle
  224. IC pilot looking for Electric plane advice
  225. anyone now about the slo v
  226. TWIN MOTOR - plans wanted "GWS"
  227. battery weight
  228. wattage extra 300 ?????
  229. Sparking connection
  230. GWS 400 set up
  231. new web site?
  232. no subject
  233. Batteries and batteries how can I build them?
  234. Lil Luscomb Sport
  235. flyzone ventura
  236. Tower Kaos conversion
  237. aerobird extreme question
  238. GWS receiver versus Berg vs FMA?
  239. Parkzone J-3 Cub crash help
  240. What charger for this battery?
  241. please help
  242. Best plane for a beginner?
  243. A Fistfull of Propellers?
  244. Need to buy Electric Plane, suggestions?
  245. Radio glitching
  246. Help finding video
  247. Transporting
  248. motor break-in/lubrication
  249. Triton and My 8 Cell TX NiCD
  250. EPP foam QUestion.....
