PDA
View Full Version : Electric General Discussion
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Jet Waco Jimmy Franklin EP+EDF
  2. Spektrum AR 400 receiver won't bind
  3. KV
  4. SeBart Angel S 50 parts
  5. Sig Kadet Senior Conversion
  6. Help me make this video go viral!
  7. Replacement motor for E-Flite Carbon Z Yak
  8. Old Goldberg Cub Kit
  9. Prop vs RPM
  10. Electric Flying Boat Kit (Hydrofoam/Hydro Hawk) Wanted
  11. Fitting retracts to Hobbyking electric Spitfire
  12. Micro receivers
  13. Help me choose. ...seawind or icon ?
  14. Fly zone micro p38 lightning
  15. Need electric prop advice
  16. Problem with 3G-R Sport Gyro
  17. Need canopy
  18. Looking To Get A DJI 450 Any Other Name Brand Quads Of This Size I Should Know About?
  19. Apprentice S floats
  20. Need help for my A6
  21. Need Electric Motor and ESC Recommendations For 30" Herr Piper Cub
  22. Question on ESC
  23. Burning Lipo Battery
  24. cleaning electric motors
  25. NEWB antenna/wire questions
  26. New Safeguard On/Off switch?
  27. Help electric motor size for 46 size trainer
  28. Epo-Grip Adhesives Summer Savings
  29. 90mm EDF holes
  30. Tissue for wing´s
  31. Heli pilot's 1st plane
  32. Twin Otter batteries
  33. Battery
  34. Trojan nose gear issue
  35. Trying to find Cessna RTF that is not Red in color
  36. Major RC Universe upgrade planned for Monday - This should be COOL!
  37. Eflite electric retract
  38. A123 help what ever the chinese call them now!
  39. Vibrating Noise ONLY at a certain level on throttle
  40. RC Airplane Similator for Lap Top
  41. glow to electric
  42. Electric Fly-in July 13th -Houston, TX
  43. Regulator question...
  44. Servo dilemma
  45. NiMH battery packs and NiCD chargers
  46. newcomer with a dream please help!!!
  47. Newbie questions re power...
  48. Need Help to ID Parts Starmax F-86 Sabre
  49. SERVOS
  50. question on propellers for Dynam foamie planes
  51. Help gas to electric conversion YAK 87 inch
  52. A great place to buy a plane
  53. HELP: Question on Air Brakes/Speed Brakes(air tank) for Venom F86-70
  54. Help needed..Paint Color
  55. simulator
  56. Question looking for Venom F-86 Skyblazer Canopy/Cockpit Cover
  57. Shaft on eMotor?
  58. Receiver for a FMS 1400 V3 Corsair
  59. CMP DHC Beaver from Nitroplanes ?
  60. Electric Power Set up for a SIG 4 Star 54
  61. speed controls
  62. Turnigy 42 -58 motor ?
  63. What does the formula tell you?
  64. Destroyed the prop on my Starmax Pitts...
  65. Electric Pros PLEASE help.
  66. etracts
  67. Motor won't give torque
  68. Where have all the Chinese airplanes gone??
  69. Prop adapters
  70. 1/2A POWER SETUP
  71. GT Power A6 charger voltage on first two cells wander
  72. Where to get Stand offs ????
  73. need a wing tube
  74. Please help me with my gearbox problems!
  75. Need help with EP J3 Electricub
  76. Parallel Charging of LiPo packs.... good idea?
  77. Electrifly Seawind ARF power setup suggestion !
  78. RCU Picture caption contest
  79. Battery charging at home ?
  80. Need help with prop choice on Hacker A30
  81. Deans Connecters?
  82. Adapter balance for hacker top fuel
  83. After binding everything works except engine
  84. X-Mount/Hardware:Power 32/46/60 bolt size
  85. Trying to learn but im terrible at math!
  86. Need help choosing power set up
  87. RC Hangar Time podcast show
  88. Recharging a dead lipo?
  89. twin motors, one motor surges
  90. X4 Charger help
  91. Aircraft gearboxes?
  92. Glasair Binding and Question
  93. HK15158A Digital BB / Coreless Mini Servo 25g / 2.8kg / 0.07s
  94. Charging the new NiMH batteries
  95. apprentice 15e motor problems
  96. Twin Electric GreatPlanes
  97. How to stop a BL motor through use of a switch
  98. ESC from Monday's bombing???
  99. Titan Air Hog Stunt Glider
  100. Need help with my Electrifly Tiger Moth
  101. Flyzone Corsair - Can I forgo Anylink and install my own?
  102. Picture Upload Help
  103. Guillows B17g
  104. Guillows B17g
  105. taylorcraft 450 arf
  106. Theres an APP for that
  107. Turnigy K-Force Query
  108. Hangar 9 extra 260 27% electric convertion
  109. Parkzone Wildcat Pics
  110. elec batt question
  111. Dangerous incident happen to me today …
  112. Electric wiring
  113. Mr RC SOUND SYSTEM
  114. has anyone ever seen this
  115. Balancing a 2S pack ?
  116. Aerial Video
  117. Avro Arrow
  118. Electric Rotowing for E.Vs
  119. SEFF 2013
  120. GRAUPNER GOES BANKRUPT !!!
  121. rimfire motor squeals on maiden takeoff
  122. How Much Voltage Can Can A Hobbico Starter Take?
  123. RC Night flyer airplane
  124. .25 size Brushless
  125. How to setup Lipo Low Voltage Tester
  126. Propeller advise for multiplex parkmaster
  127. sf prop vs e-electric.
  128. ultrafly motor
  129. Can't tighten Prop Nut without spinner backplate moving
  130. Night Flying
  131. Insulation Issue
  132. Cellpro 10S & Honda Generator
  133. Slow Stick X Bush Plane!
  134. Dynam Sbach
  135. Ferrite ring on BEC
  136. How much power to the Receiver from the ESC
  137. HK ME-163 DISCONTINUED!!
  138. ZIPPY Compact 4000.
  139. Central Jersey flying fields?
  140. Foam wing glueing
  141. Albany NY special regulations?
  142. Apair of 11.1 volt batteries makes 22.2 volts?
  143. EC3 housing
  144. Exponential??
  145. Custom Mobile App: RCcoPilot
  146. Need help looking for new electric motor
  147. Dynam f4u corsair retracts
  148. Need Help with spinner sizes.
  149. need help!!!!!!!
  150. fms 5060 kv270
  151. binding
  152. Lipo battery charge time
  153. Help with ESC
  154. Inny or outy
  155. 2 Wire ESC
  156. Prop adaptor for dynam T28
  157. need help wit pusher motor thrust set up
  158. is a R600 receiver pcm
  159. 4 motor ugly Stik
  160. Falcon 120 help
  161. are all watt numbers equal?
  162. 2013 Indoor Electric Fly-in Schedule for Denver metro area
  163. N 20 DC motor
  164. Turnigy LiPo and Deans connectors
  165. New to the E-flight line...
  166. Power HD motor
  167. Which electric heli????
  168. ESC application
  169. Lipo Batteries in the Mail
  170. Dynam T28 RTF
  171. Sadler Vampire Manual
  172. FPV Newbie
  173. Club Night Flying
  174. Freewing Typhoon Canard setup
  175. gonna like electric
  176. Can an RC aircraft lift 25lbs. With only 1300W of power?
  177. UMX Sbach 342 3D
  178. Hubsan FPV
  179. A question about TCI
  180. Speed gun, wires, plugs, servo tester... Hobbyking discount buddycodes
  181. Hitec X2-400 charger question?
  182. Telemetry with Voice Callouts
  183. Cox Sky Cruiser
  184. Are T connectors the same thing as Deans?
  185. Green R/C Mini Sopwith Help
  186. Keeping things cool
  187. Tacon motor for airboat
  188. What Connector is this??
  189. DX4e good for heli AND plane?
  190. What size plane would this fly
  191. What typcially causes motor failure?
  192. Need help! won't bind
  193. E-flite Albatros D.Va 25e is a Lame Duck
  194. Hobby Zone Super Cub
  195. Connectors
  196. Buddy Box?
  197. can any of the receivers work with most types of 2.4 Ghz
  198. Need some help with new to me setup
  199. Balance plug question
  200. Electric Help Needed
  201. new to this site
  202. New to the RC Universe
  203. Batt question
  204. What is wrong with Foamies?
  205. esc or motor problem
  206. 130A watt meter and other HK buddy codes
  207. Hobby King yuck
  208. Indoor RC DOME flying and instruction in N.E. Illinois
  209. Video of indoor electric event in Denver
  210. Electrifly AMMO 28-45-3600 info
  211. Common Sense RC motors
  212. props make a difference
  213. Learning about Electric RC
  214. Twin electric setup the battery is getting hot and puffing
  215. Need your opinion on the two below jets
  216. Smoke for electric aircraft
  217. Binding Help on Electric plane
  218. retracts
  219. what is correct crimping location on power pole connector
  220. Rotten Bananas
  221. Corona Synthesized Receiver,will it work with Futaba
  222. Orange RX Receiver
  223. FMS P-47
  224. Problem with Lipo batteries
  225. Electric X-650 FPVHOBBY.COM untrustworthy
  226. Wiring for twin out-runners
  227. Lanier Shrike vs Sig Wonder
  228. Right Angle Banana Plugs?
  229. Lithium ion recharge
  230. PATS CUSTOM MODELS, what I should have said earlier
  231. PATS CUSTOM MODELS, BEWARE !!!!
  232. Getting back into RC.... Maybe in too deep already?
  233. Dynam Sbach 342
  234. servo mAh?
  235. Prop mount on Tacon motor
  236. Drive 8 minutes
  237. Hyperion ZS4045 mount
  238. TOWER HOBBIES VISTA EP PROBLEM
  239. dropped replys
  240. Flyzone Nieuport Prop removal
  241. Electric Retract Question
  242. nitroplanes
  243. Motor trouble
  244. Converting to Electric
  245. crash and burn
  246. IMAX B6 charger power cable
  247. led lights
  248. radio
  249. Remove retaining collar on motor shaft ?
  250. Educate me on charging Lipos
