PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38
  1. AstroFlight Whatt meter. Where to buy?
  2. Question about proper battery charger use,,,
  3. Need Help BalanceingMy Mini Telemaster
  4. I guess everyone is out of the Shock Flyers, right?
  5. NEW REVIEW: Alfa Models F4U-1 Corsair
  6. Thrust to Weight (newbe)
  7. newbie alert :)
  8. Speed 400 setup please help!
  9. Electric Engine/prop & Batt. set up
  10. E heli Video on Lipos
  11. MOVED: Yellow Aircraft P-38 Conversion
  12. Electric events
  13. Tiger Moth
  14. Best LiPo Charger?
  15. What is this??? Help identify this plane.
  16. Slow Stick keeps going up at full throttle and stalls... help? Noob
  17. flight box battery
  18. lipo battery chagers
  19. SLOW STICK Wing reinforcement braces (MUST modification)
  20. Trivial Question
  21. Superstar ep battery
  22. Indoors south Florida
  23. New Wattage Ultimate. What battery to use?
  24. Fighterbird
  25. Astro Flight The Electra Twin
  26. E-starter CG
  27. Problems with the Ikarus Bleriot III
  28. Help with motor spec for Motocalc
  29. Can't get it off the pavement...
  30. Funky Chicken motor suggestions
  31. Volt vs Amp question
  32. 9.6V Fast Charger
  33. how I know a used battery capacity?
  34. GWS Spitfire
  35. swift racer
  36. MOVED: GWS PT-17
  37. Bugz planes by Backyard hobbies
  38. motor to ESC connectors
  39. Soccer has started, flying season is over
  40. Secure that Battery
  41. Best Prop for Mega Brushless 16/25/3?
  42. New to electric and need advice
  43. PLEASE READ!!.....But dont laugh.... Radio shack F4 electric DF
  44. Efficient Charger System
  45. Please help me complete this combo
  46. new to electric!
  47. Help finding the right size pinion for spd 400
  48. motor stops and won't restart without pushing start button
  49. Fastest electric
  50. GWS Formosa
  51. Speed 400 prop recomendation, 29" plane
  52. Industrial strength dufus vs. Hitec transmitter
  53. Great Beginner Flying Wing
  54. Battery for Firebat
  55. Better battery suggestions?
  56. best light wheels?
  57. Is flying a Biplane much different from flying a single wing plane?
  58. X-EC Battery Help
  59. HAS ANYONE USED THE ....
  60. variable pitch prop on outrunner
  61. FireBat Question
  62. GWS receiver with no CH 3....
  63. MEASURING THRUST
  64. REtiming motors WOW!!!
  65. Where to buy motors?
  66. Covering Lil' Poke
  67. T HAWK380 MODS/IMPROVEMENTS
  68. Great Planes Really Messed Up!
  69. Im fed up with my multiplex twinstar
  70. Electrify
  71. More Flight Time Superstar EP
  72. How about polyurethane varnish?
  73. Motocalc versus Electricalc ? Opinions ?
  74. Aerobird Challenger Wing Area
  75. GWS Shift changes??
  76. CG on Hobby-Lobby freeflight Corsair
  77. RCU launches "RCU-Book" market values service
  78. MOVED: Convert GP 40 Size Mustang to Electric?
  79. Bungee Foot Release
  80. Can anyone tell me about this motor?
  81. MOVED: Wattage Cessna 180 Help
  82. Phasor 30/3 on 6cells?
  83. Pilot Mark Leseberg Jr. Joins TEAM RCU
  84. Li Poly Charging Question
  85. APC Prop question
  86. Deans Connectors the Best?
  87. Noise Suppression Capacitors
  88. RCU WRAM Show Coverage...!
  89. zagi repair parts?
  90. motocalc calculation please
  91. Question on GWS Motor Usage
  92. Sig Fokker D-VII ARF
  93. Escaped from Helicopter Hell: I'm Back.
  94. Speed Controler
  95. . help with estimate for "throws"
  96. wet plane
  97. Almost ready to fly my first elec piccolo. crystal quesh
  98. GWS Stearman ok for a second plane?
  99. Astro Viking
  100. How to measure amp drain??
  101. Adding ailerons to Superstar EP
  102. What paint to use on GWS foam, and how to camo?
  103. What's a good hinge tape
  104. Fokker DVII Any Options/Kits Electric?
  105. brushless for the turbo bee/ Himax 2015-3600
  106. GOLDBERG 550 , can it really ROG on grass?
  107. Need Help...What to Use???
  108. projeti pusher confused
  109. Flaps on the GWS BN-2 Islander
  110. How do I press gears on motors
  111. Anywhere still stock Fantex 600 fans?
  112. Electric Formulae
  113. newbie... aileron servo problem
  114. NEW R/C Electric Heli!!!!!!
  115. Motor/Battery question
  116. Mounting micro servos
  117. Concept Type ll helicopter,
  118. 3d plans
  119. Anyone know anything about www.b-p-p.com
  120. Pics of Skis for Aerobird
  121. 4 blade props
  122. Looking for a Club
  123. motocalc ? (batt and motor amps)
  124. nicad to alkaline change, help!
  125. good engine set up for 3dx
  126. was going to order a nippy from HL, but out of adapters..
  127. Park Flyer and E-Flight Websites
  128. Been seeing some of these electric planes and I'm becoming interested.
  129. Has anyone flown northest sailplanes electric epp jets?
  130. Flew the Slow Stick today
  131. Can't get a shockflyer, now what?
  132. Dandy Covering
  133. Need Your Advice Guys
  134. jason shulman exhila!
  135. ESC doesn't work with a PCM receiver?
  136. Push rod attachment???
  137. Humming Bird
  138. Power Supply from a PC
  139. Nimth battery help
  140. ultimate bipe
  141. Beaver Taxi/Takeoff Mystery Problem
  142. Electric Combat
  143. Yard Stik Issues
  144. nav lights
  145. Electric power cost analysis
  146. Filing suit tomorrow...
  147. World-Class Aerobatics Pilot Quique Somenzini Joins TEAM RCU!
  148. Beginner Electris R/C Help.
  149. Aerobird Challenger CG
  150. himax 2025-4200 prop question
  151. Nosedives
  152. motor series
  153. WRAM Show in White Plains, NY
  154. Slow Stick to Formosa part 2
  155. Is there any Balsa 'Warbird' kits for Electric Available?
  156. Use automobile charger?
  157. Himaxx Dandy Sport upgrade... wow!
  158. I'm short circuiting
  159. Best Online Shop for Electric?
  160. Can someone help me with a few things?
  161. Kulbutin-E
  162. battery/motor question
  163. Slow Stick to Formosa
  164. Convert a Bird of Time to electric
  165. aircraft recommedations wanted
  166. Quick Question
  167. 2 cents on the E-Starter
  168. PBY-5A
  169. Himax 2025-4200 Slow Stick Report
  170. 8.4 volt to Li Poly Battery
  171. Best motor/plane for 7.2V 2100 LiPo's?
  172. hitec radio questions
  173. Wheres the CG on the GWS P-51 Mustang?
  174. SoaringUSA.com is Great!!!
  175. trying to mix 4 speed controllers - help
  176. Who kitted the Apache electric plane?
  177. Anyone have a LEXX?
  178. Which sailplane? aspire ep or spectra?
  179. ESC/Motor Question
  180. LI-PO failure QUESTION
  181. Anyone know this plane
  182. Quick Question...
  183. fundango performance
  184. Formosa or Switchback?
  185. Any input welcome
  186. NORTH EAST SAILPLANES A LIAR!!!
  187. Will it fly??????
  188. Flightpack suggestions
  189. Fms Flight Sim
  190. Will an antenna next to a CF tube hurt the signal?
  191. Bullet Bitten - Brushless for Slow Stick
  192. Large lipo charging
  193. Look at this motor
  194. MOVED: What exactly is 3D Flying???
  195. Help--2 Questions--1 Zagi and 1 sending videos
  196. Help! I'm having female problems :) ...
  197. slow stick build process
  198. POST YOUR SKYSCOOTER PICS HERE!!!
  199. Receivers.....vertical and horizontal pins????
  200. GWS slow stick Maiden flight vid
  201. Slow Stick Mods
  202. GWS ducted fans??
  203. Hitec Buddy Cord
  204. Indoor E-flying at the Golf Dome in Indy
  205. A-10 help
  206. Any suggestions on covering my new Dandy?
  207. easy to make prop saver
  208. Mounting the Master Airscrew Motor with Gear Box
  209. Electric system software
  210. I need good indoor starter heli any experts?
  211. Does any1 know where to find a P-38 Electric RTF
  212. NEW REVIEW: Flying Styro P40 Warhawk
  213. GWS dream starter set
  214. futaba antena
  215. New to slow flyers and have a few Q's
  216. Slow Stick hard to adjust to after flying fast
  217. hand launch or bungee ???
  218. Best place to get Lipos and charger?
  219. $50 REWARD !
  220. Motocalc - Motocrap
  221. Slow Winter?...Winter Slow Stick!!!
  222. MOVED: NiMh Charging question
  223. Freedom Flyer Blues
  224. lipoly setup for e-starter (did I get it right??)
  225. Watt Age Corsair
  226. BEC Questions
  227. mini manta plane
  228. beginner, trying to select a radio transmitter
  229. MOVED: PDF's and Printing
  230. kill servo glitches now and for good
  231. How much wind?
  232. RC Powered Paraglider help?
  233. does the type of connectors matter?
  234. Best charger for LiPo 4s packs?
  235. quick motor/battery question
  236. Firebird XL servo problem
  237. MegaStealth II
  238. Flight Pack Recommendation
  239. Dandy sport flight report
  240. Need help picking flight pack for parkflyer
  241. Great planes yardstick...
  242. Thust Line Question for pushers
  243. Freedom Flyer Customer Service Top Notch!
  244. zagi cam
  245. Why buy foam kits. just build them for cheap
  246. Aerobird below freezing: Don't try it.
  247. Twin Electric Warbird
  248. Astro 05 Battery?
  249. Skimmer Kit
  250. looking for high quality electric
