PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38
  1. not another aerobird thread I promise!
  2. Reinforcements on Aerobird-HELP!
  3. Naro/pico Or Other?
  4. Whats the differance?
  5. Hitec CG340 Charger
  6. Mini IFO video
  7. Help with soup-ups for aerobird
  8. Conversion gage kable to mm2 ?
  9. Aerobird tail screws
  10. Reusing radio on tiger moth
  11. Aerobird, Standard wing vs. X-Pack wing
  12. what to use for covering?
  13. Need more flight time
  14. Wattage Sukoi SU31
  15. CG question
  16. SuperCharger Flite Box
  17. Gws spitfire vs me109
  18. What motor for this sailplane? Opinions please......
  19. Aerobird elevon problem
  20. Motocalc accuracy wrt speed 400?
  21. Help! Hobbico MKII charger
  22. n/e sailplaines AKROPHAT
  23. History Channel Flight special on today (7/17)
  24. GWS Tiger Moth flight problems
  25. Motor and prop for Electric Piper Cub?
  26. Aerobird Boom Repair
  27. Zagi Fixx
  28. Guillows f6f can it be set for r.c.
  29. Wattage Mig 15
  30. Im on my way up BABY!
  31. Thanks Hitec!
  32. areobird tail setting help higher or lower on horns ?also the tail gear HELP
  33. megatech airplanes
  34. does anyone have a Vertigo A.R.F from jet set
  35. Firebird II will not climb
  36. Expert advice needed
  37. Need Plane Decision Help for Phasor 30/3
  38. Turbo Bee
  39. Sky Scooter Pro II needs more power, better prop?
  40. New guy with an Aero-Fire-bird XL hybrid...
  41. Zagi FIXX
  42. Firebrid XL Boom Repair
  43. Rookie: Did I do the right thing?
  44. Electric gets expensive!
  45. hobbico rtf ep
  46. Gws P-51
  47. Aerobird Repair HELP!!!
  48. Kyosho Cessna 180
  49. Best way to "Fix" a Broke GWS Foam wing.
  50. Flew my first electric today. Sky Scooter Pro II
  51. So how often do you guys get to fly?
  52. Terminal Strips
  53. I have a question on the Aerobird's rear tail assmebly.
  54. Motor Problems
  55. Are Electric Motors supplied by Kit Manufactures good enough?
  56. Folded another wing today....
  57. RIP Threedee
  58. Can I use this battery?
  59. weight calculation
  60. Possible problem with my Aerobird?
  61. Sky Scooter Pro II problem?
  62. Problem charging NiMH with FMA Supernova
  63. Comet Aeronca Chief
  64. Bill Fornoff's F8F-2
  65. Guillows Hellcat
  66. Help with Hacker
  67. Using Aerobird Electronics in another plane - Challenge
  68. Great Planes electric Firebat experience?
  69. Wattage Super Impress
  70. Katana
  71. Glitching?
  72. Wattage Live Wire
  73. Hobbico Quick field charger and a10
  74. Funtana scoop?
  75. Hacker B 50 11XI 5.2 ;1
  76. help! what motor setup for this plane?
  77. A Whole New Can of Worms...
  78. A Whole New Can of Worms...
  79. Gws A-10
  80. wattage f-86
  81. free-flight to park-flyer conversion help?
  82. Pico slow stick ailerons???
  83. mirage 2000 mods
  84. Wattage hawk mods
  85. Firebird comander XL
  86. GWS Mustang Hot Setup
  87. GWS tiger moth!!! awsome plane!!!
  88. Motor problem question for my Horsefly Hobbies Gee Bee ?
  89. speed 400 6V or 7.2 volt...whats the differenceHey guys....question for ya....i have
  90. starting of
  91. Aerobird: First flight report...
  92. Just got the Aerobird!!
  93. Zagi Sticker was on fire!
  94. Suggested Mods for GWS Slow Stick?
  95. Need help bringing vintage Cox Canario into the 21st century
  96. Gary Wright Model Products E3D purchase
  97. Temperature of Motor / ESC / Battery
  98. Help, Help with Electrics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  99. Pbf
  100. Mega Gearbox Lube??
  101. Aerobird wing reinforcement??
  102. Sky Baby & Lazy Bees
  103. no rubber bands
  104. GWS Zero or P-51 Mustang ? ?
  105. brushless motors
  106. Oh My God !!!! Fun !!!! Thank You !!!!
  107. battery charging
  108. Graupner DC-3 contacts ??
  109. New Club Forum Opens....
  110. T-hawk mods
  111. Na na na na na
  112. Think I need a catapult for barnyard flyer
  113. Electric power equal to 0.90 glow?
  114. MEGA brushless motor
  115. Viper Twin by Jet Set Models
  116. i need a pylon 400 racer
  117. is there a way to upgrade fighterbird or fire bird xl
  118. kontronics speedy
  119. ElectriCalc Problem
  120. Zagi Fixx Motor Replacement
  121. The Great Planes Slinger
  122. 8.4V battery, 6 or 7.2V motor?
  123. SE5a plans?
  124. What should be my next plane.
  125. battery will not charge
  126. Good day to fly
  127. Question ????
  128. How do you calulate the motor amp draw
  129. Is it possible to get an Aerobird to roll?
  130. Electra crash (bad battery?)
  131. Newbie Question- Mountain Models
  132. Firebird XL Go bye bye
  133. Mega 16/15/4 or Astro Flight 020 for Zagi ?
  134. what to get
  135. Fighterbird question
  136. electrical interference
  137. Going electric
  138. Need help with 4 ch GWS Rx
  139. Converting Aero Bird receiver
  140. newbie qestions...:
  141. Aerobird question
  142. Aerobird X-Pack upgrade - worth it?
  143. Computer power unit as mains supply for digital peak charger
  144. electrical testing
  145. Major RCU improvement
  146. Aerobird propeller upgrade?
  147. T-6 under powered?
  148. Is there a difference ?
  149. I need a park to fly in
  150. motor for 2m glider
  151. speed control
  152. Hacker and Controller wiring??
  153. Smallest extra?
  154. Help: Speed 400 Power Oscillation
  155. Aerobird tips and stuff
  156. E-Calc data for my Graupner GeeBee "Sportster"
  157. Advice on the GWS Me-109
  158. DF Selection
  159. Promax 4011 with gb. What prop?
  160. Compatible plane with 7.2V 600mAh battery pack
  161. Another Aerobird question
  162. Anyone have a sky scooter II ??
  163. How to use li-poly's without todays ESC/BEC's designed for 4.8v cutoff used w/nicads
  164. Anyone Building a T3D?
  165. superstar EP conversion to nitro...finished
  166. Firebird II 5 pack battery question
  167. Global Extra 300L
  168. Aerobird question
  169. 400 up to 480 - what gear box & prop?
  170. Electric Senior Telemaster
  171. Correct Switch Position
  172. ARF 22" Baby Bee
  173. mega 16/15 gearbox?
  174. Anyone flying an Electrajet?
  175. AXI vs. Hacker
  176. Birdworks Spud
  177. esc mysteries
  178. Which Tiger Moth: Flair or Pilot ???
  179. Best price on Hacker motors
  180. How to rewire eletric motor coil
  181. Left Zagi on roof of my car !
  182. Contra rotating props
  183. Propeller stall?
  184. max safe current for a Promax cobalt 14turn 400?
  185. Firebird engine into Piper
  186. Balsa Products
  187. ?? Plane
  188. Motor control for speed 300 in a hornet
  189. wattage IC-15A esc problem
  190. Kyosho motor 360 gold any good?
  191. GWS Servos - Should I use them?
  192. T-6 Texan
  193. New Hobby-Lobby Giant Electric Monocoupe
  194. Battery Voltage Question
  195. EMS Jomar? What's the deal?
  196. Spirit of Yesteryear e-kits -- anyone built any lately?
  197. wattage cobalt super 400
  198. TINY X, just got it
  199. Can a Hacker B2015l + 4:1 be converted to a direct drive and back?
  200. Download a free plan
  201. First Radio Choice?
  202. Beginner Dad Wants ARF or RTF Electric?
  203. DC 1524 Break in
  204. Putting Ducted Fan Blade On Motor
  205. Hacker B50 8L???
  206. Dogfight with the wildlife.
  207. Mega 16/15/3 question
  208. Use Of Electric Fan Units
  209. motor pulsing on and off
  210. Looking to start club in Indianapolis area
  211. Upgrade motor for x250?
  212. FMA Razor the same as Trick r/c Razor?
  213. Brushless Motor Question
  214. Hobby Store I Saw In A Catalog
  215. Battery for A10
  216. Folding Props???
  217. Looking for Klemm L25d plan
  218. HELp needed to choose motor
  219. Gearbox for speed 400
  220. Wattage scale aircraft?
  221. Standard Servo Electric Planes
  222. RD6000 Delta Mixing Help
  223. backyard flying
  224. Electric Magic
  225. glo to electric or electric to electric chart
  226. Glo to electric conversion
  227. Recycling unloved, crippled or even dead RTF planes.
  228. Any suggestions ON building 125mph +
  229. What's your favorite Electric plane?
  230. Little Stick Power
  231. Jerky Flying
  232. Speed 300 Brushless
  233. Size of Astro Cobalt
  234. Motocalc
  235. Astro .020 Brushless
  236. Swift .... COOL
  237. Bill Griggs Assult
  238. best way to clean moto...
  239. Ag Cat Motor Options
  240. Astro cobalt 05 geared- max watts & volts?
  241. Hot battery
  242. Top Flite Cessna 182
  243. want 4# E-planes for minimum cost!
  244. What size motor should i use
  245. Fighterbird battery ends
  246. Sky Scooter Pro 2
  247. Hacker Controller wiring
  248. Live Wire w/ 7-8 cell 500mah nicad enough power?
  249. Yayeee!
