PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38
  1. Need help choosing plane
  2. Servos on ebay
  3. Pusher props coming loose
  4. 8 cell 1100mah pack too much for GWS ICS-100??
  5. Seeking Advice
  6. Radical RC Edge 540
  7. Astro-15 motor
  8. Mini Sukhoi 3D
  9. charger for 1cell, 2cell,&3cell lithiums?
  10. Battery Wire Keeps Frying!
  11. Why wont my motor work for Mini Piper?
  12. RC Car Motors???
  13. Prop question
  14. shrike.40 electric
  15. Is my Motor Temp to High?
  16. HE1100 and Mega 1615-3???
  17. GWS A-10, P-51, or Zero? Help Guys!
  18. BEC or not to BEC
  19. What size LiPo for zagi...
  20. Target dropping on a park flyer
  21. brushless mega on geardrive
  22. Wright Flyer
  23. converted gas to elec, what size motor
  24. Motor upgrade for zagi fixx??
  25. Mini Piper tailskid
  26. Electric PBF Help
  27. JE180 ESC problem
  28. Starting in Electric
  29. Combat Models A-10..Engine and fan size?
  30. Electric Glider
  31. GWS 3 channel and servo jitter PCM/PPM??
  32. Wattage Extra 330L set-up
  33. Laser 3d electric?
  34. Sukalyn?
  35. Electric motor break-in
  36. micro whizz
  37. cell phone battery for small plane?
  38. Where to buy motor/gearboxes?
  39. Air tech stealth control
  40. GWS electric mini-motor
  41. K&A Models P-38 speed 400
  42. Reverse motors?
  43. Different motors for A-10?
  44. Electric Shrike?
  45. brushless motor
  46. E-Tec 1200 3s w/a speed 300
  47. Multiplex Micro Jet
  48. AEROBIRD RX board....HELP!!!!
  49. Plane with ducted fan for beginer?
  50. Best aerobatic plane for AF 40G
  51. Easy Enhancement to the Firebird/Aerobird series
  52. Sky scooter pro and 480 motor
  53. Polarity on GWS ESC ???
  54. VMGM600 (6.0:1) Gearbox
  55. Gary Wright
  56. E3D Power System
  57. Cheap, fun plane
  58. Mega Planetary Gear Box
  59. Who has best price on MPI-50HP servos + Ultracoate?
  60. Rain, rain, go away, I want to fly my Beaver today!!!
  61. Anyone have a hobby Lobby Cobra?
  62. I Hate Wind!!!!!
  63. Wattage Super Impress
  64. Its all gone...
  65. Brushless Motor Comparison
  66. Size of BEC?
  67. Global .46 Piper Cub (ARTF) Electric Conversion
  68. Pusher folding prop?
  69. aerial photography?
  70. LT-25 conversion
  71. Speed 400 Gearbox suggestions
  72. maximum thrust prop for S400
  73. diy outrunner meet & electric fly-in, June 22nd, Nijmegen, the Netherlands
  74. mega acn 22/20/2
  75. New to electrics, need battery and motor help
  76. What are the best windy day electrics?
  77. GP Taylor Craft 20 size conversion HELP
  78. First Flight of Superstar EP at Home
  79. Propellers
  80. 400 motors
  81. firebird ????
  82. New motor break in..... For Electro Streak
  83. EASY TRIM ON FIREBIRD XL
  84. Brushless motors in twin configuration
  85. Brushless motor comparison?????
  86. Is a specail ESC required for Lithium-Poly batteries?
  87. CG turbo 550
  88. Need help picking electric motor?
  89. What motor/box/battery combination?
  90. What size prop?
  91. GWS Tiger Moth final weight considerations.
  92. I need a Prop Hub
  93. Covering foam - methods and final weight’s
  94. EDF Rafale HELP
  95. Best yard flyer
  96. Draganfly Vortex Extreme
  97. electric thrust ?
  98. Do oil and electric motors mix?
  99. Brushless Motors
  100. Keith Shaws latest?
  101. Motor for ARF Electra Streak
  102. Funtana
  103. What do you think about this?
  104. power/weight ratio, gas vs. electric?
  105. Supermarine Seagull
  106. Sean Kinkade's Pteryx Skybird (ornithopter)
  107. Receiver heat problem
  108. 280 motor direct/gear drive reversal???
  109. Dc-6.....
  110. Deland Fl electric info
  111. Electric prop and motor question.
  112. P51 racer for Mega power
  113. "V" in pushrod?
  114. Tower Hobbies EP ARF Sailplane
  115. Help! Info and links on electric power systems
  116. Using a Fighterbird Sonic Gun on an Aerobird
  117. GLOW vs ELECTRIC
  118. Dustbuster motor??
  119. Impressive Micro electric with Live Video
  120. Zagi 400X vs. ViperTwin?
  121. Brushless motor failure!?
  122. E-Force Delta Electric New GWS Flight Pack
  123. Omega 1.5 Electric V-Tail Settings
  124. Need Help
  125. beginner on setup for specific flight no areobatic
  126. Aspire Electric Gider
  127. klemm 25 D HELP !!!!
  128. Got a question for Tampa residents
  129. Brushless... worth the money?
  130. GP Ryan STA EP
  131. Speed 400 6.0V
  132. EAM F-18 and bungie launcher
  133. Fixx
  134. motocalc vs. reality
  135. Speed Control Problems - Help!
  136. I Need HELP!
  137. Folding Prop Size
  138. S.A.C. Trainer?!...help!
  139. Using tx charger to slow charge packs?
  140. Electric Power for Aquila
  141. Graupner SPEED 700 Electric Motors
  142. TwinJet cutting out problem
  143. GWS ICS 50 - Help!
  144. Motors of unknown specifications
  145. Wattsmeter
  146. Which connector is best?
  147. Top Flight Elder 20 Electric
  148. PB Fly Mini Fun Fly Aerobatic SPEED 400 ARF, any thoughts?
  149. Prob/battery for Sig Rascal
  150. Pat Taggert
  151. Allerc?
  152. Zagi Fixx
  153. Are Electrics good?
  154. Brushless speed controller?
  155. Please help with power supply
  156. indoor flyer
  157. Electrifly 5 ch rcvr. with 30A esc!!!
  158. Motors and Capacitors
  159. Need Help with Cobalt 400 motor
  160. Cobalt 400 Motor
  161. I have a question!
  162. live wire!
  163. Any warbird guys out there? Need help with powerplant choices.
  164. CA verses Wood Glue
  165. Spirit Electric help
  166. High power from can motors.
  167. Vtol
  168. MINI EZ connectors
  169. Hobbyzone Aerobird - Owners Speak- up!!
  170. Need advice on a motor
  171. razormotors.com anyone used these!
  172. 3rd Plane, Can't decide! Got 4 choices, Please Help!
  173. THRUST FOR ELECTRICS
  174. Crazy Max Balance Problems!!!
  175. PLease help newbie get started...
  176. Grauper Monsun and Pitts Special
  177. Recommendation for speed 400 motor
  178. trying to find a delta wing
  179. Projeti...capacitors needed?
  180. 20+ OZ thrust from a 480?
  181. building *very* cheap brushless motors
  182. Help with Hacker speed control
  183. FIREBIRD OUTLAW
  184. building *very* cheap brushless e-motors
  185. Graupner Terry vs. Accipiter Badius
  186. Senior Kaydett
  187. Hangar 9 P51 Electric Conversion
  188. Profile Mustang from Hobby Lobby
  189. lady bug
  190. Motocalc for brushless setup wanted please
  191. Slow Stick Suggestions?
  192. good aerobatic/3d park flyer ???
  193. faster!!!
  194. Designing 3D Limited Production Run airplane
  195. Designing a Limited Production Run plane
  196. Accord 2 or not to Accord
  197. Aveox brushless help needed please
  198. Herr p-51 EP conversion, whats it take.
  199. Multiple Brushless Motors, one Controller
  200. Does anyone know of a b20l sized plane that will do 3D and have unlimited vertical?
  201. Hobby-Lobby ThreeDee 400 upgrade
  202. need small footprint 600 gear drive for Primera Cloudhopper - who sells?
  203. ESC Ques.
  204. Speed 400 set-up question
  205. Zagi Fixx Question
  206. sig's Jenny
  207. TBF/TBM Avenger
  208. EDF wingloading
  209. help!!!
  210. Bulk supplies where to find?
  211. Electric Resource Center Needs Help
  212. Adrenaline (my latest design) - Pictures!
  213. they say theyre aint no dumb questions
  214. Help please...
  215. Astro Flight 02
  216. two speedos, one motor
  217. WHO HAS A <15" WINGSPAN ARF/KIT AVAILABLE
  218. Speed 600 help
  219. Jeti info needed NOW!!!!
  220. M100 does it need a diode?
  221. Electric Motor question about Specific type
  222. wattage 380 esc ,HELP PLEASE
  223. direct 400 or geared 300?
  224. Scaling down Uproar 40 to speed 400 electric
  225. IFO-How to attach 1/2a control horns?
  226. For Any Slow Stick Owners
  227. who makes decent wheels for a Slow Stick?
  228. Radio Interferance
  229. Speed 400 Motor, HELP!!!!!
  230. Astro 15 motors
  231. wattage 380 esc (128471 part #)?????
  232. Watt-age Live Wire
  233. Will it fly? Advice Needed!
  234. Alfa models p-47 Thunderbolt or p-51 Mustang?
  235. Has Anyone ever Flown A Pleaser 2 or 3 ?
  236. A hobby newcomer.....
  237. Converting a Ace Simple Ultimate to electric?
  238. PICA 1/12 scale P51 E conversion?
  239. Brushless Motor Question!!!
  240. Balsa Craft grumman bearcat! anyone familiar with it!
  241. What motor to choose???
  242. Indoor Planes
  243. INDOOR FLYNG
  244. Motor timing?
  245. Jeti 110 speed controller brake?
  246. Zagi, FMA Razor, Wedgie, Taipan, Combatwings, Wing Warrior, Eletric Bee, Pro Jeti????
  247. New motor for GWS P-51?
  248. GWS 1047 Prop
  249. Good Aerobatic Park Flyer
  250. San Diego fly in
