PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Micro Flybarless System 3-Axis Gyro System for Helicopter
  2. Using flyzone Cessna batteries in Super cub
  3. PZ Corsair - Hot Battery after Motor Upgrade
  4. Hyperion ZS 4035-12 with ATLAS 90 amp OPTO ESC
  5. Electric P 38( looking for)
  6. Lots of Hobbyking discount codes!
  7. Looking for the biggest RTF Cessna 182/152
  8. Better Bearings for a BP A2810-9 Motor
  9. airfield cessna 182
  10. Canopy Latch ?
  11. Electric Motor help
  12. transmitter reliability concern
  13. AIR WING PRODUCTS, YOU HAVE ANY?
  14. Recommend me a new heli
  15. For sale nib Air raptor
  16. Zippy Batteries
  17. My AXN Floater catch fire in mid air! Plane totally burned up! Chinese smoke tube!
  18. Question on fan jet power
  19. What's your favorite charger?
  20. LiFe as RX Battery
  21. Information re: motor, ESC, battery combos.
  22. Plane recommendation
  23. Turnigy Accucell 8150 Life Charging
  24. Dynam P-51 Wing wiring ?
  25. Is it OK to not connect motor to ESC?
  26. best paint for homemade foamy
  27. Ultracote For Hinges?
  28. RC Flying Site Issues Due To Li-Po Fires
  29. X - UAV B17
  30. Tenergy Balancing Charger Problem
  31. Who is the manufacturer of this model
  32. Recomend me a motor?
  33. Compensating for to much current draw?
  34. can PL8 charge four 8000mah 6S batteries in parallel
  35. dynam "ICANFLY" review
  36. ***Watts over Owatonna 2012***
  37. What motor for an airboat?
  38. down and locked gear failure
  39. JR XP6102 battery conversion.
  40. Power HD servo 1218TH
  41. NiMH 4.8V 2000mAh Hydrimax - charge rate?
  42. EDF for Klingberg Wing 78
  43. Charger Recommendation
  44. Best choice for windy conditions?
  45. A bit disappointed in the Dynam Sky Trainer
  46. How much power does a PHASOR 45-3 putout?
  47. Hobby king discount links for 6s lipo charger and more...
  48. Help with new plane
  49. Batteries
  50. E-flite 80amp esc (v2) limits
  51. HOBBY KING 1300mm Lancaster LEMON Hobby Kings worst release yet ?
  52. Stinson Reliant
  53. field charging lipos
  54. Eflite Carbon-Z Scimitar ROCKS!!
  55. np F-16 fiberglass motor and prop
  56. Connectors
  57. tower hobbies vista glider
  58. Hobby king buddy discount links
  59. Helpme! Why do speed cut out
  60. Perplexing Problem - Help Please
  61. Parkzone Stryker F27Q setup
  62. Pics from the 2012 Flying Electrons fly in
  63. can the motors be throttled independently
  64. PBS NOVA program is looking for UAV hobbyist in DC area
  65. need help finding a motor for 80 edf
  66. YOUR chance to influence which Model aircraft a manufacturer will build in the Future
  67. Electric equivalent to .60 nitro for speed???
  68. HobbyKing 4B6 Multi port Charger
  69. Receiver antenna orientation
  70. rc universe foamie
  71. Strange e behaviour, neebee help.
  72. Eletc.event
  73. PARKZONE vs DYNAM
  74. Motor Problems
  75. Battery storage???
  76. hobbyking t-28 funfighter
  77. Run smaller motors on large ESC
  78. APC folding props?
  79. Whitman Flyers Electric Fly-In 8/11/2012 Bethpage NY
  80. In Trouble.
  81. Robbe PRO-line KE 536/7 PRO
  82. AXI 6mm motor shaft retaining clip...
  83. Cermark Extra 260 50E ep Manual
  84. lights for a night flyer
  85. battery charger
  86. MIG - 15 ?
  87. Hobby king discount buddy codes
  88. HOBBY KING budy discount for-Rafale +F9F Panther+1600mm P51 STARMAX COPY
  89. ESC throttle range...
  90. What Do YOU Want This Year from HH?
  91. Need some motor standoffs. Where can I get
  92. what 4 channel trainer eletric trainer to buy
  93. glow to electric conversion
  94. F27Q STRYKER ESC FRIED 10 flights
  95. denight special
  96. This is a safe toy?
  97. servoless retract problem
  98. Unique Models T-6 Texan II aka pilatus PC-9
  99. Unique Models PT-17
  100. twin ESC's
  101. MrRCsound Engine Sound; Review & Installation
  102. AJ Slick 51
  103. StarMax P-51?
  104. Disappointed in Grayson Hobby
  105. Suhkoi SU-26 motor cutting out
  106. Having trouble putting all rc plane components together
  107. ESC Question
  108. Erratic servos on initial power up
  109. Glow to Electric
  110. Got a buy on a Reactor Bipe
  111. I Won This Plane At RCX Long Beach
  112. 10kg Flyin King with Hyperion ZS4035-12
  113. Buddy DISCOUNT codes for Airfield F6F hellcat + GeeBee R3 and a 2200mah 3S lip[o
  114. changing connectors
  115. OS electric motors beware
  116. Which LIPO battery charger/balancer to buy?
  117. Need Advice - Epoxy Problem
  118. nimh to lipo conversion, PZ slow V
  119. Brushed 480 Gear Driven vs .10 Rimfire BL?
  120. E flite Pulse 25
  121. Spitfire motor mount
  122. motor wont throttle up
  123. RECEIVERS OR AIRPLANES FROM HOBBY KING FOR MY NINE EAGLES J-6 TX.
  124. Battery Selection and Setup for Converted Spitfire 90
  125. Help I am Looking to Purchase New Foamie Plane
  126. Park zones F4F Wildcat PNP
  127. Altitude Flying & decreased performance
  128. NITRO MODELS B25?
  129. Brushless 4250-KV500
  130. Balsacraft Spitfire
  131. Sky Surfer
  132. Noisy Motor
  133. Voltage limit for Lipo
  134. Thread Lock Tutorial For Helis
  135. bind question
  136. Killerplanes
  137. Hobby King Customer Service ?
  138. Super Brain 960 Help Please!!! Somebody!
  139. St Model Fox EP Problem w/Power System after Crash _Plz Help !
  140. Replicating engine starting sequence of actual aircraft on model airplane
  141. Schulze 7.36.12
  142. Motor runs after TX is shut off
  143. Sky Shark Ultra 80
  144. what accessorie do a new car need?
  145. Anylink
  146. Range Testing!
  147. Silicon Wire vs "Standard" Wire
  148. How can I lock my car DVD player to a TV stand?
  149. New to Electric RC
  150. R/C Equipment For Sale
  151. Wing area and weight question
  152. e conversion
  153. Dell Power Supply Help
  154. Seagull Zero
  155. watts up meter just a gripe !
  156. Aeronaut F7F Tigercat model kit
  157. J-3 Cub 25 ARF UltraCote
  158. MOST STABLE MICRO-QUAD OR WHAT??
  159. axi 2814/10 need plane, mono or bimotor
  160. Rimfire .32
  161. Wing MFG.
  162. Need help identifying this plane
  163. Radio System
  164. A question regarding electric field intensity due to infinite sheet?
  165. Electro-stik throws
  166. GP electro-stik motors,props,battery
  167. Techone Mini F18
  168. Manual for a Gee Bee 63" wing span
  169. Freeflight rubber power to RC electric ??
  170. 11.1v - balance lead to 5v RX via relay - help needed for lighting!
  171. My new KDS450S
  172. Can you help me on wire gauge???
  173. Twin motor issues/Questions
  174. Electric Twin set up
  175. Best 3 cell lipo for my Radios
  176. clunking noise
  177. HELP...on extended connectors...HELP
  178. would like help on seetting up elec large plane
  179. os Electric motors
  180. Spektrum AR600 6-CH SPORT DSMX RECEIVER
  181. Returning to hobby...thinking of moving to electric
  182. Replacement motor for Bf-109
  183. Corona R8FA Receiver binding problem
  184. WING WARP??????
  185. What type of connector is this?
  186. Question regarding Charging Batteries (Transmitter)
  187. Lets talk speed controls
  188. E mail address
  189. Flying People in New York City-Very Cool Video!
  190. outrage fusion 50
  191. venus 40 conversion
  192. Stupid newby to electric question
  193. need plane for axi 2814/10
  194. Bananna hobby b17
  195. Pull - Pull rudder cables
  196. Sig Rascal 49"
  197. Set up for two 4 cell Lipos
  198. where to purchase a e-flite deuces wild
  199. Cool Heat Sink Cooler for Jive
  200. Oops!
  201. fms mustang v2
  202. Turnigy Accucell 8 DOA
  203. Question about running brushless w/ 72mhz
  204. Kits
  205. e-flightline?
  206. ElectroStik tail wheel
  207. Mini plane motor issue, help????
  208. Great Planes - L-39 Albatros - "Need Some Advice on Components"
  209. Best of the Chinese electric plane manufacturers
  210. Need help programming flaperons on Dx6i, just won't work
  211. Charger woes!!!
  212. BEC low battery cutoff
  213. Denver area indoor fly-in 2012 Schedule!
  214. Great Planes - L-39 Albatros - "Need Some Advice on Components"
  215. Question on engine sound module for a B-25
  216. Suggestions for a foam PNP style airplane
  217. Double Horse 9053 Helicopter
  218. Dynam P51D Mustang Motor Powering Off
  219. Montly magazine for electrics
  220. Hobby People 4120/05 ESC
  221. Futaba 6EX... am I doing something wrong?
  222. inflight load verses on the ground
  223. Battery Hold-downs?
  224. Longer flight times please!!!
  225. Switch harness with Futaba Micro J connectors?
  226. Set screw sized for E-Flite Park 180 x-mount
  227. futaba 9c throttle deactivation and idle
  228. Jr x-378 programing help
  229. ducted motor help
  230. Sky Trainer 182 want to install larger batteries... beginner please help!
  231. lighted instrument panel for rc model plane
  232. HZ Supercub to BUSH SUPERCUB..
  233. Have anyone played the RC heli WLtoys V911 2.4GHz 4 CH?
  234. Electric setup for 60 inch Bipeplane
  235. 2.4 ghz TX/RX Question
  236. Digital Sound for a B-25 (ENGINE)
  237. Quick Remove Cowl?
  238. Charge Parkzone 3S Lipo on Turnigy Accucel-6 NO-GO!
  239. Park Zone Question
  240. ubec and rx pack - at the same time?
  241. Hi, I have two questions regarding the Hobby-Lobby B-25 Apache Princess
  242. 63"Pitts Hybrid 3D
  243. How to Wire XGY 1000 Head tracker
  244. xgffgx
  245. Charging Lipos, Need Help!!
  246. Motor trouble
  247. Large foam chuck glider- RC conversion
  248. axi 2820/10
  249. motor for 12 ft telemaster
  250. Aileron/Elevator Mixing vs Non-Mixed
