PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Watt Age Sopwith Cowl fix?
  2. Scale/Profile/Pattern
  3. Prop size question
  4. HTS - SS Blue Sensor Station
  5. What plane to get
  6. Turnigy 5065-380
  7. Prop Balancing
  8. Micro T-28
  9. Need Light Weight Lighting
  10. Delete
  11. check hotliners
  12. HELP I'm Ready for my 1st composite electric sailplane...Opinions
  13. What Happens When You Pop a Link
  14. Just getting started with electric
  15. BeastX V.3.08
  16. HobbyZone SuperCub turning problems
  17. ICARE Sets the Standard for Customer Service
  18. Plane for 400 or 450 power system
  19. Paid deposit for plane now no response captcraig
  20. ? about the Airfield P51 1450mm warbird
  21. Where to find specific plane threads?
  22. Bird of Time Electric (WattBOT)
  23. Airtronics Speed Controler
  24. Midwest Aerostar 40
  25. Cox .Pee Wee conversion
  26. Piper Cub Super Cruiser conversion
  27. SPAD Debut
  28. Help regarding power system.
  29. Electric flight training
  30. Need help with CC160 hv
  31. Manta Jet- Where to buy?
  32. Maximizing Available Power
  33. Cooling Air flow problem
  34. Where are Scale Electric Airplanes in RCU
  35. Wanted: Electric C-130
  36. HK out of chargers?
  37. sig seniorita electric ARF
  38. Turnigy TGY 9X and 9X8C radio system
  39. Stinson Tri-motor
  40. Battery voltage can be read on the ground?
  41. Slightly puffed Lipolys??
  42. GP Fokker E.V / D. VIII Flying Razor Prototype Flies
  43. Guillows conversion to electric
  44. Does size matter?
  45. Possessed CC Phoenix 45 ESC?
  46. Looking for a plane...
  47. Dual Motor Set Up
  48. Set-up question
  49. GWS Prop Part Numbers Confusing
  50. dodgy charger gt 606d
  51. 30 second charge time? Friday humor
  52. Serious Questions about "Buyer Beware" Posts
  53. 1/3-scale Culver Dart
  54. Just got an Eaglet 50! Some questions.....
  55. servo gear strippng
  56. New to electrics/ opinions
  57. Banana Hobby
  58. Best Electric RC Airplane Online Store
  59. Spektrum Dx6i charger question
  60. B6AC charger died?!?
  61. electric setup
  62. Looking for Info on Spinners for Electrics
  63. Victor Valley R/C Flyers "ELECTRIC FEST
  64. E flite retracts
  65. WARNING!XAVIEN
  66. foamy in the dark
  67. zagi 35 amp speed controller programing instructions.
  68. Mike Buzzeo's Electric Flying Witch
  69. converting glow to electric
  70. best way to charge
  71. The Mentally Unbalanced PROP-BALANCER
  72. BEST IN THE WEST JET RALLY
  73. Noob
  74. First Water Takeoff of the Electric Amphibious Lazair
  75. Neu 22XX motors fatal design, check your setups!!!
  76. Changing Battery and ESC connectors
  77. chit chat thread
  78. kv question
  79. Electric Hellcat or Bearcat
  80. art tech yak54, with super tigr .10 motor installation problems.
  81. RX /SERVO I.D. OLD KRAFT ?
  82. Astro 15 Cobalt??
  83. fms flight sim questions
  84. Melted battery connectors
  85. Finesse 1.20 patern plane Electric conversion
  86. Electric Motor Set-up
  87. Burning up motors! What gives?
  88. Want to move over to LiFE
  89. Twin Motor Synchronization
  90. Cessna 182 Skylane GP/EP Gold Edition ARF 81"
  91. New to electrics...could use some feedback
  92. Hawk Sky motor upgrade.
  93. Eflite Motor Heating Up??
  94. Vampower Pro gone???
  95. WHITMAN FLYERS ELECTRIC FLY-IN 8/13 2011 Bethpage NY
  96. HobbyZone Super Cub LP Ailerons?
  97. prop size for Hacker 20L
  98. To give finicial assistantce to the research team or manufacture corporation of eletric aircraft
  99. SuperCub B/less Conversion ... WHY ???
  100. FPV Video
  101. Air exit holes on fuselage?
  102. Plane recomendations
  103. What's your opinion? ESC airflow, prop balance
  104. Battery wire problem (for new Brand)
  105. Multiplex Fun Cub
  106. Help choosing a flying wing
  107. trying to land a pylon plane
  108. Parkzone Typhoon 2
  109. F27 Stryker motor choice
  110. The Hyde “Not –So- Soft” Soft Mount for the NEU 1521
  111. What went wrong?
  112. Help choosing a motor / esc combo for super skybolt conversion
  113. hobbyshop warehouse EDF planes
  114. P-51 motor mount
  115. POGO EF-1 Pylon thoughts
  116. Entirely carbon fiber rc plane?
  117. Micronradiocontrol.com Should Keep Stocking Plantraco RTF's
  118. Using GPS Logger and Dashware
  119. Help with a low budget build for C-160 parts
  120. Need Rec, 2nd Plane
  121. eflite park 480 cheap alternative???
  122. DX6 vs DX6i
  123. Transmitters for foamies
  124. elec help P51 Bluenose
  125. Aileron ???-help!!!
  126. 4th of July Special from Wowplanes
  127. Parkzone Trojan losing tape during flight?
  128. F27Q Stryker Questions
  129. Super Cub Motor/Gearbox Mount
  130. I need a balance charger for 6cell that works
  131. Smoke System
  132. Turnigy/shaft/ducted fan
  133. Turnigy/shaft/ducted fan
  134. The Great Hobby King Motor Shortage of 2011
  135. Super Cub motor fails past half-throttle.
  136. Best charger and batteries?
  137. sbec causing interference
  138. Need help with hawksky upgrade
  139. Electric speed control gets wet and fails
  140. need help with foamy....need speed!
  141. Flap conversion on electrifly mini ultra stick
  142. using a seperate BEC
  143. Surge Ep 1 - Rc Plane Electrics/Components Explanation
  144. Group Buying of Extra 330 57"
  145. Cessna, but which Cessna?
  146. Operating Servo on its own
  147. Throttle Problem
  148. New E-flite Super Cub!!
  149. brushless thrust help
  150. Super Cub
  151. Transporting
  152. Hangar 9 Piper J-3 Cub 40 electric conversion
  153. Elec Eng for EFlite SU 26?
  154. Problem with pitts plane climbing constantly
  155. CMP Hellcat Electric Conversion???
  156. LiPo: Cell Balancer behavior
  157. Turnigy Accucell 6 Help needed
  158. That sound is ice settling in hell... Cubby Flys!
  159. Best glue for EPO foam
  160. RCX Chicago August 6th, 2011
  161. Need help choosing an airframe
  162. Will this Airplane and Lipo battery work?
  163. Eflite PT-17 Stearman PIREP
  164. BlitzRCWorks MX2 Pro PIREP
  165. reversing the shaft so that it sticks out the front and not the back
  166. NEFI 2011 (National Electric Fly-In)
  167. Turnigy Battery & Charger
  168. AXi 5345/16 HD & Phoenix 120HV - settings ??
  169. They were dropping like flies...
  170. Pretty is for girls...
  171. I need help with the right size motor for a scratch built foam plane.
  172. Brushless motors and what makes them work.
  173. CBA 2
  174. Totally Awesome Very Cool BMF Day! MX2 Pirep!
  175. Is this battery any good for RC?
  176. Batt question
  177. Battery Drain
  178. Classified posting work (5867)
  179. Nona air wheels?
  180. Duct or prop for beginner?
  181. Electric Warbirds?
  182. hitec x4 charger why not 240v power?
  183. Blade sr 120
  184. Electrifly TritonEQ will not fully boot
  185. Modeltech Mini Magic Extra Electric Setup
  186. Accu-Cycle Elite charging question on li-po
  187. electric power plant recommendation
  188. Please help
  189. ENGINE EQUIVALENTS
  190. motor selection?? Opinion from the pros
  191. showtime 50 to carbon z
  192. WHITMAN FLYERS ELECTRIC FLY-IN 8/13/2011
  193. Nitro/Gas or Electric or Gliders?
  194. Help with Parkzone quick charger for single cell lipo
  195. Closed
  196. Battery to ESC question
  197. Wattage S 3 upgrade question
  198. Aircraft Outrunner Motor on Car ESC With Reverse
  199. Nav Light system
  200. my f27c stryker lost 90% power in flight
  201. double post
  202. Why no switch?
  203. prop confusion
  204. Good micro servos
  205. BP Hobbies Mooved
  206. Larger electric airplane
  207. charging cord between electrifly polycharge4 and flyzone 4 wire battery
  208. Shipping your Electric Planes with UPS
  209. Does Anyone Have The The Great Planes Edge 540T E-Performance Series 3D?
  210. rc10
  211. E-Flite Mini Funtana Undercarriage
  212. Well I guess I will Post My Banana Hobby 64mm A-10 EDF Complaint too.
  213. RC Wiki
  214. Help Please w/ GP Escapade 61 Elec...
  215. Great Planes Edge 540T E-Performance Series 3D EP ARF 50
  216. Nitro Planes Disappointment
  217. Propeller Size
  218. Binding DX6I tx (DSMX) with AR6000 rx.
  219. esc id.
  220. HobbyKing Variable 6s charging problem
  221. NESP Vermont belle
  222. NEED HELP WITH TWIN HOOK UP
  223. Purchases from Hobby Lobby at Toledo - NO WARRANTY!
  224. Silk on foam/balsa covering techniques
  225. Brown Paper Covering wbpu/glue
  226. Hobby King DSM2 receiver - faulty batch
  227. The battery question!
  228. What plane, please?
  229. Super-cub mods
  230. battery c rate calculations
  231. Need help with a Electrical question, and would like to know if anyone is running this setup
  232. Jacksonville Fall Electric Fly In May 20-22
  233. is it ok to start with electric?
  234. New scratch built finished
  235. Freeair Blast with lights on
  236. Need to upgrade Skyhawk TW 742
  237. Dynam radio crystal switch to Futaba TX failure
  238. Clear Heat Shrink for ESC or Receiver
  239. Standardizing battery connectors?
  240. multiplex mentor
  241. 11.1 lipo
  242. Best lipo charger for under $75
  243. Vk Nieuport 17
  244. Eflite Bonanza motor question
  245. Motor
  246. HK Futaba RX clones battery??
  247. need expert advice
  248. bphobbies.com
  249. Resistor
  250. Banana Hobby's ESC programing
