PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Simprop Piaggio Avanti & a few others
  2. Where do you fly?
  3. lost in lipo help
  4. which is better?
  5. Inner or Runner Motors
  6. Charge 3.7 LI-ION using Turnigy accucel 6
  7. Using DX7 on simulator?
  8. Calgary Flyers Group - Air show!! Video
  9. Info on Blue Ice lipos, any good?
  10. Great Planes - L-39 Mods. and Radio Questions:
  11. Best for the $ LIPO charger????
  12. How about some advice....
  13. Where's Reaper Brushless Motors
  14. The Right Charge
  15. KV's ?s
  16. Heating iron question
  17. Sbach 342 30e class
  18. jet thrusts inverted to contols
  19. Hobbico Superstar EP Question
  20. anyone try the new Gorilla Glue?
  21. AR DRONE QUADCOPTER
  22. sim software for usb trainer
  23. WTB AXI 5330/18
  24. T-34 Mentor by World Models - Elec. Conv.
  25. Guidance needed on first electric
  26. F/A 18 70mm
  27. infinite esc
  28. Probably silly question!
  29. battery placement, higher or lower in plane?
  30. HELP new lipo no voltage question??
  31. Powerful EDF conversions anybody?
  32. Looking for a Simulator for HC-Hobby EuroFighter EF-2000 EDF Jet
  33. Eflight Apprentice 15 Hardware match?
  34. Bent prop shaft
  35. Multiplex FunJet COG
  36. Motor help.
  37. Brushless motor
  38. What's a good charger for 6s, 5000mah batteries?
  39. Help no elevator on my new eurofighter
  40. 12x6 to 13x4e amp question??
  41. Engine sound
  42. Installation of a BEC
  43. motor noise
  44. help with battery selection??
  45. Electric Flight Box
  46. 90" lazy ace HXT 63-74 200kv Brushless Outrunner
  47. Cessna 182 Skylane - electric w/ CG issue
  48. Dony buy Banana,nitro,etc
  49. Tri Motor Setup
  50. Paint and foam issues
  51. Electric prop question regarding amp draw.....
  52. Hitec Ecplipse 7 QPCM Compatibility with Receivers
  53. F-16 PICS
  54. Lots of questions for the pros:)
  55. Dynam Hawk Sky motor cutting out...
  56. Slowing down servos
  57. Ziroli Turbinator-E Parts List
  58. Exceed RC Optima Brushless Ducted Fan 70mm EDF Motor 2700KV
  59. E-flite park 250
  60. .
  61. Ghost
  62. Props
  63. New flyer picked up a ParkZone J3 Cub BL
  64. Any recomendation for what size prop to use for eflite t-34 25e?
  65. HobbyKing
  66. What is this?
  67. Best Plane
  68. turnigy esc
  69. Electric Conversion for a scale aircraft (Scratch Built)
  70. where to get spacers for power 32 eflite motor/t-34 mentor
  71. newbie need help with wing dragon sportster
  72. Converting glow to elec, some questions.
  73. Dual rate
  74. Are eflite lipo batteries durable and worth buying?
  75. help with a receiver DSM2
  76. Smallest Servoless Electronic Retracts -18.8g!
  77. Hobby King 60/70 amp esc
  78. What happened to newdirectionsrc Vecjet
  79. spike the ultra dinasour
  80. NEED HELP FINDING-*******
  81. Lifepo4 vs Lipo
  82. Reinforcing Undercarriage
  83. which motor is stronger?
  84. RC Lander F-16 EDF
  85. electric conversion
  86. -25 C flying
  87. how can i calculate what "C" rating battery to get
  88. eflite power 32 3s question
  89. Imax B6 Charger
  90. "Rafale" park flyer EDF by HobbyKing
  91. Depron Survival
  92. Are there any 3 blade electric props? If so where can I find them?
  93. Flying electrics in wet weather
  94. t-34 mentor using flaps for landing
  95. Lipo chargeing questions
  96. Will this work?
  97. aircraft 4 3 cell 2100mah lipos
  98. Can someone explain the ratings on brushless motors.
  99. What would you recomend for a first channel?
  100. Linear or Switching bec?
  101. which eflite planes power packages 2 use with cell 2100 mah lipos
  102. Jetiger
  103. brushed and brushless motors
  104. Question about CA glues and activators
  105. Are Lipo Charging Bags a Must?
  106. Want ad
  107. RX
  108. remote
  109. Electric Retracts
  110. Wattage Biplane question
  111. E-flight whats going on?????
  112. Gee Bee Fantasy Flyer
  113. ELECTRIC FLYING @ EL TORO MARINE BASE??
  114. Failsafe?
  115. electric motor help
  116. Best way to find my CG??
  117. Trainer repair
  118. What electrics for Goldberg Cub?
  119. funjet wiggles all over the place!
  120. gravity cox guts
  121. We Need ELECTRIC WARBIRD Forum
  122. Santa could have put examples in the manual
  123. Bringing Model Aviation To Your Schools! MASC - Check It Out!
  124. flaperon on AT6
  125. Begginer rc plane
  126. Flying out of Country
  127. JR Models Mosquito
  128. Picking Correct electric setup?
  129. have you had problems with the AR 6400 parkzone reciever
  130. HELP! SOMEBody HELP! Eflite Park 450 motor and Castle 35amp ESC
  131. looking for a good starter
  132. dx8 setup for elevator
  133. Electric Rotowing
  134. the dyson hand held Hoover can we use the motor
  135. Charging with triton
  136. glider electric conversions
  137. CrazyBall Spin at 150' altitude FPV aerial video
  138. overtightening prop shaft
  139. Can anyone recommend an alternative to the discontinued E-Flite Deuces Wild?
  140. Cold weather question..
  141. Propeller selection for Electrics
  142. rimfire 300 and 12a esc question
  143. ESC vs. transmitter for throttle curve setup
  144. Power eFlite Celectra 4-port charger with a Lipo?
  145. Banana hobby or Nitro planes airframes??
  146. Y harness or separate channel for aileron?
  147. WING LAUNCH BRAZIL
  148. ESC in Tower's P-51
  149. where else to get "banana hobby" type jets??
  150. Horizon Hobby and Parkzone Electrics
  151. Nitro plane T-28
  152. Great Planes ElectriFly ElectriCUB Kit 58.75"
  153. RANGE VIDEO FPV EQUIPMENT
  154. US Aero Modelers AssociationModel Insurance
  155. RYAN STA-M 120
  156. Nitro Planes T-28 Trojan C.G.
  157. watt meter
  158. Electric setup for a seaplane
  159. motor swap ?
  160. stuck servo maybe??
  161. Dave Bottita Phase 3 F-16 Build
  162. CMP PA 28 CHEROKEE ARF EP
  163. charging batteries
  164. Battery No Voltage
  165. deans connector male or female on battery?
  166. DX6 I losses settings
  167. Twin,Motors don't start together?
  168. Indoor Flying in Teaxs
  169. data on brushless motors
  170. Indoor Flying in Atlanta ?
  171. repairing a lipo battery wire
  172. Motors
  173. Changed motor in plane... Have to add many clicks of down Elevator.. Question?
  174. Techone Mini-Eagle biplane
  175. E-Flite Platinum Series?
  176. where to buy blue arrow crystals
  177. LiPo Supplier
  178. park zone champ
  179. Parallel LIPOS w/different MAH
  180. beginner question
  181. Seagull harrier 3D
  182. looking for a 48" OV-10 Bronco ARF any Condition
  183. looking for some ideas
  184. Texas Electric Challenge
  185. Under powered motor..... Let's make it fast!!
  186. Antenna Length
  187. Best place to buy depron
  188. Prop adapter question
  189. HobbyKing Aero L-39 Albatros Jet Plug-n-Fly Review
  190. Alternative Heli
  191. Aux channel on a Parkzone Typhoon
  192. Cool new plane from E-flite
  193. Fast Motor for Stryker F-27 ??
  194. Navigation Lighting
  195. aprkzone P51 rcvr
  196. Parkzone sv80 servo specs
  197. BH Mosquito.....which electric retracts?
  198. Hepl with Astro Flight motor size????
  199. polished spinner
  200. Mega Inrunner - removing backplate??
  201. New to electric planes
  202. German radial engine sound
  203. Never mind...just overlooked it
  204. BEC Question / ESC question
  205. Flite Test - First Episode!!! F4F Wildcat Review
  206. Build a plane with speed 400 brushed?
  207. Dry cell or soldered pack ?
  208. Banana Hobby P-38
  209. Motor Voltage Question
  210. WHERE DID ZERO GRAVITY RC GO?
  211. Wouldn't it be cool to have a Parkflyer 25e Size BEAST???
  212. HELP !!!
  213. Help with Dynam A-10 EDF
  214. Flight Sim (Phoenix) question
  215. World Models Extra 300 EP???
  216. 9g Servo Current Pull in a Mini Ultra Stick?
  217. Electric RC planes made history this month
  218. Electric motors 2
  219. Turnigy charging/balance plug question?
  220. Motor Alignment / mounting issue
  221. Protecting Decals & Trim - EP
  222. Ypgtading Li-po oack can I keep the same ESC
  223. Beeps in Airfield Airplane
  224. esc hot
  225. Battery simple Q's
  226. Does the battery pack PUSH amps into the motor?
  227. Switching from gas to electric, and I'm confused
  228. Can Spectrum 2.4 bind to JR 2.4?
  229. Techone Bluefox
  230. cheap Vs "expensive" LiPo's
  231. How do I get a motor to turn opp direction
  232. Swollen Lipos??
  233. A manufacturer who stands behind their products
  234. Don't Use Banana Hobby
  235. AW .60 - .90 Extra 260 Electric Set-Up
  236. starter plane
  237. BL outrunner setup problem
  238. Need input from the pros.....
  239. Do I have a defective BEC?
  240. ESC Issue?
  241. Need motor mount
  242. Telemetry for Voltage
  243. How Do You Add On for RealFlight G5?
  244. best buy for the buck 60-75 size?
  245. Budget RC Arrow II
  246. Prop selection
  247. Futaba Battery pack (for 7c 2.4)
  248. Where is a list of online vendors? Where do you buy online?
  249. Charging a lithium polymer battery
  250. Binding my plane... Questions? Problems?
