PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Batteries with different connectors?
  2. Charging two packs in series?
  3. Which heli for almost newbie (to heli's)
  4. Catastrophic failure mid-flight caused by Castle Creations ICE 160HV
  5. aluminum spinners
  6. Folding Pusher Props : Any Sources
  7. Hyperion Super Duo - Where Is It?!
  8. Venom ProCharger charging question.
  9. Question on Program Card
  10. Striker F27C - What 2.4 gig JR/Spectrum receiver are you using?
  11. Foam RC Plans
  12. ESC Prob.
  13. E-flite Power Meter....is it accurate??
  14. Sterling Conversion
  15. EDF Vulcan
  16. Please suggest a plane for this motor
  17. AVG Flying Tigers P-40 Nitpick
  18. Advice needed
  19. EPO Minimoa glider set-up
  20. Just need to know if this battery will work?
  21. 1/4 scale warbird/electric
  22. Motor/Plane selection help please
  23. Looking for decent foam airframes
  24. BEC and Receiver Battery in Parallel
  25. Power
  26. Newbie Needs Help: Can't Bind Reciever to Transmitter RDS8000
  27. new electric plane
  28. Golf Cart Flying
  29. WHITMAN FLYERS ELECTRIC FLY-IN 8/14/2010 BETHPAGE NY
  30. not sure what i am doing wrong, but the plane will barely fly!
  31. splicing a 10 gage wire down to a 12 gage
  32. Please critique Electric Flyer Magazine
  33. TGY AerodriveXp SK Series - regluing the magnets?
  34. $85 parkflyer jump jet!
  35. Is right thrust needed on electric motors?
  36. need help picking out prop adapter!
  37. dynam 70 amp esc
  38. Castle ice lite 75 fried
  39. need help with torque roll....
  40. Advice on this charger
  41. ELECTRIC JAMBOREE - Whittier Narrows, CA - Aug 14-15, 2010
  42. Himax motor identification
  43. stock easystar on c cells? what prop?
  44. Zagi Landing gear
  45. eflight vs parkzone
  46. Event: Volts over Victorvalley
  47. Eliminate BEC?
  48. E-Flite Power 32 Repair
  49. my skyfun, funjet RTF review.
  50. Convert Douglas DC3 to electric engine
  51. Futaba t6exhp, with KDS Flymentor
  52. Free Flight Timer (Fly Electric "Taser")
  53. Higher Capacity Batterys for PZ Planes?
  54. Help setting up Dx6i Delta Wing
  55. Hyperion Motor Box rebuild?
  56. Does ANYONE know how to program a Squall ECU ?
  57. Does this interest anybody?
  58. I want to buy your damaged old planes
  59. Props.. Speed vs Lift pretaining to Props???
  60. West Coast Big Jolt
  61. Question regarding BL motor
  62. Jamara ARF's
  63. Need idea for a plane to take with me to afghanistan
  64. can my esc be to big
  65. question on ESC and BEC
  66. Please allow me to introduce myself...
  67. Anyone own an Aerobird 3?
  68. Best way to blow up a lipo?
  69. rhino transmitter lipo
  70. spindle removal from motor
  71. Brushless speed controller question
  72. Invitation for All Electric Pilots!! WHITMAN FLYERS ELECTRIC FLY-IN 8/14/2010 BETHPAGE NY
  73. Problem with spinner HELP
  74. Insulation Foam Electric plans (p-38 look alike)
  75. E-flite Aluminum spinner?
  76. tabs for aa batteries
  77. How To Build A Power Pod
  78. need info on parkflyer RC
  79. Programmable Brushless ESCs, do they have to be programmed?
  80. EC5 Electrical Connector Question
  81. gws esc ics 300li issues please help
  82. Outrunner/ESC Combo on Ebay
  83. Help need SERVO that holds position when unpowered
  84. Lipo Battery Charger
  85. Where are they made?
  86. Great Planes ElectroStik screeching noise. update!
  87. Were can you find this plane
  88. Dedicated Auction site
  89. ParkZone Spitfire Mk IIB (RTF)
  90. considering a Skyartec FUNJET for next plane
  91. BNF with an RTF radio
  92. hobby king planes
  93. Is this a stall??
  94. Motor and ESC???
  95. Granddaughters first EP
  96. GP Eagle 580 EP motor, esc, battery cooling?
  97. How many types of servo connectors?
  98. Super Stick 40 Conversion
  99. Servo Chatter help
  100. Eagle Cap 580 XLS 50"
  101. Turnigy ESC 40 AMP
  102. eflite rv9 propellor size
  103. Li-Ion/Li-Poly Chargers...which one for Rx packs?
  104. Hobbyzone Super Cub LP BNF, does receiver have aeleron channel?
  105. servo measurements ??????
  106. Airfield 2.4Ghz radio range problem
  107. Motor brake question
  108. Need help with Battery and Superfly
  109. video with the Funtana
  110. Setting up a 40 Cub
  111. HeliMax issue with plugging in orange eboard wire
  112. Super Cub Engine Problem
  113. E-flite 450 motor help needed
  114. two 30 amp esc's battery upgrade?
  115. brushless outrunner 480 prop size
  116. Mini Funtana video
  117. Specktrum DX-7 acting weird
  118. Mini Funtana
  119. New Contest from E-flite
  120. What Prop
  121. Xport hacks / mods?
  122. Help finding Li-po charger
  123. Static vs Flight Current Draw
  124. Need fix for brushless motor!!!
  125. twin motors/esc
  126. Typhoon 2 3d to what?
  127. melted the motor mount!
  128. Does anyone know about the Sky Charger B6AC?
  129. Electric Funtana 125
  130. Monster power 46
  131. Micro plane and heli motor question
  132. Converted HZ Super Cub to DX6i - Tips for Dual Stick Control?
  133. New Review Site for Testing Electric Planes
  134. Luvin it!
  135. help with set up
  136. What support battery do you use?
  137. soldering question
  138. Messerscmitt BF 109
  139. Computer fans
  140. Best companies to buy RC electrics
  141. Reverse Shaft on Exceed Monster Power 46
  142. Nitro Planes EDF Flying Competition
  143. PZ micro Mustang's Tx work with other planes?
  144. Epp Foam Planes.
  145. Epp Foam Planes.
  146. Defective 70MM F-4 ESC
  147. ready to upgrade
  148. E Sky Battery Tester
  149. Need new motor for Fledgling!
  150. turnigy plush 60 amp esc
  151. Charging Lipos inside the airplane. Who does?
  152. linking camera servo to aileron on DX7
  153. Good first plane?
  154. Electric Questions
  155. Totally lost.
  156. Dynam Hawk Sky couple of pics and vid
  157. What did I goof??
  158. Having trouble finding replacement axle for my great planes reactor 3D EP ARF 41.5"
  159. converting rubber 2 rc
  160. Need conversion info
  161. balance issues
  162. Power Supply for Battery Charger
  163. GWS BN2 on 11.1 volts + spd 300's
  164. Drive Calculator v3.4, Win/Mac/Linux
  165. ESC & JR9303 Not Working Together
  166. Does anyone collect the Aristo craft toy motors?
  167. Moths
  168. Electric Plane Recommandations
  169. AR6100e vs. AR6200 RX in Mini Pulse XT???
  170. Does my ESC have a built-in BEC?
  171. Help trying to get back into RC planes - Parkzone any good?
  172. How dumb can people be!!!!
  173. Covering materials
  174. SPECTRUM AR6110E RECEIVER
  175. Another battery question from a newb
  176. Lots of qeustions...
  177. foam insulation glow plane
  178. Going Eletric!
  179. Is this enough?
  180. GuanLi A-10 Motor Start Problem
  181. My Reactor 3D EP glides like a rock! Any suggestions?
  182. LiPo's?
  183. New To LiPo
  184. 2010 MWE Spring Fling San Diego May 14-16
  185. eflite alpha 450 on floats
  186. GP Chapman 50" EP 580 warning
  187. charging amp
  188. How many planes do you own?
  189. Need a good online battery pack supplier.
  190. LiPo usage
  191. Problem with MicroDan 2510 3d
  192. Advice for LiPo charger
  193. Strange New ParkZone Battery?????
  194. loud nylon gears
  195. Does this throttle curve make any sense?
  196. tinybritelights
  197. Battery?????
  198. Hyperion 0720i NET3 Chargers
  199. recommendation for my "first " (had some toys before but nothing series) electric airplane.
  200. Mountain Models Cessna 180
  201. Help needed!
  202. Spektrum - No Throttle
  203. Futaba GWS Slow Stick Setup
  204. Whats the best first electic thats complete ready to fly?
  205. micro p51 battery leads
  206. Problems with 11.1 volt 1820 mah battery.
  207. brushless motor and nimh batteis
  208. Help on ESC
  209. servo size?
  210. charger Question LiPos which one??
  211. Mini Ultra Stick in wind
  212. Any charger show voltage w/o actually charging/discharging?
  213. What is this plane??
  214. Hyperion LiPo's. Are they good?
  215. super cub motor upgrade.
  216. TP Pro Lite V2 question
  217. "Low Voltage" lipos. What now?
  218. watch the wind!!!
  219. Elec. Props????
  220. *** RCU Coverage of SEFF 2010 ***
  221. Girl hit by RC aircraft
  222. I need a genius for my Taylorcraft 450
  223. GWS Rx problem?
  224. next post
  225. Guan Li RX same as Futaba?
  226. carbon fiber recycled- How?
  227. Airplane giveaway
  228. battery balancing
  229. Charger never turns off?
  230. 12' Telemaster
  231. Help Please! Replacing motor shaft
  232. can i use this radio
  233. Strongest glue for Parkzone foam?
  234. help with flying eflite rv9
  235. What paints are safe on foam?
  236. Turnigy ESC difference
  237. Charging larger TX and RX nihm packs
  238. super cub cuts off at half throttle
  239. Painting a foamie
  240. Thunder Power 1010C NIMH problems!!
  241. Hobbyking.com!!!
  242. Setting up Elevons
  243. my dynam RTF review(update)
  244. E-Flite Stick Mount to Park 450 Motor Question
  245. futaba 7c 2.4
  246. Need Help - Balancing World Models Unijet Ducted Fan (How To)
  247. Question about Lipo disposal "safes" at your flying field .
  248. Battery Help
  249. LiPo voltage question.
  250. Richardson (TX) All Electric Fun Fly 4/11/10
