PDA
View Full Version : Electric General Discussion
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Radios for sale
  2. s9650 servo not centering right!
  3. Sloper looking to get a F4U Corsair
  4. F3P information/ Help
  5. ESC question!!!
  6. what is this worth?
  7. bind plugs
  8. matching components
  9. matching components
  10. How to hook up AR7000 Rx to Mini Ultra Stick
  11. need voltage regulator?
  12. Suggestions for Yak 54
  13. noob Please help
  14. Burned up watt meter
  15. How to wireup flaperons
  16. New to electrics, Crash Survivability
  17. where to buy...
  18. Burned Up Motor - Post Mortem help needed
  19. Other Retailers
  20. can i bind this to that?
  21. what is a good chargers
  22. Graupner Folding Prop Bldes
  23. Strange buzzing of servos when starting up
  24. External Battery source for ESC Question??
  25. e-flight mini pulse motor question
  26. EFlite P38
  27. Lipo help
  28. mentor wing breaks off during flight
  29. 2.4 interference
  30. RC 2.4GHz Radio's
  31. Any good R/C plane shops in Chicago?
  32. wanting a 4ch plane
  33. Upgrading F27 Stryker, need help, noobie
  34. Problems with Easytiger Models
  35. Help sorting this Park Flyer concept out
  36. You never know what you might find on the Internet ....
  37. Connectors
  38. JR 9303, Programming Elevons
  39. c310
  40. Banana Hobby not making refunds
  41. parkzone p51 ultra micro question
  42. electric motor
  43. Fried the ESC in my Hawk Sky
  44. Is the iC5 and/or iC6 charger any good?
  45. need help w/ power system selection
  46. bec vs ubec question
  47. Turnigy Motor Bearings
  48. Tx and Rx compatability for a newbie
  49. 2 meter Sailplane cox to Electric Conv.
  50. Large 4 engine project!
  51. New to electric flight
  52. Aerobird Swift Questions
  53. Weight vs. thrust question
  54. how to change LG on my vapor?
  55. Motor Knocks
  56. New Canadian hs selling starmax edf jets....
  57. help choosing electric motor
  58. To all who looking for cheap lipo batteries
  59. Need Prop for a Turnigy 36-40-09 Inrunner
  60. Please help newbie dad factory settings freedom flyer
  61. help me with a history search
  62. great planes reactor f/s
  63. GWS BN2
  64. New to electrics and lipos
  65. NiMh/Cd charging help.
  66. AXI 2826/12 still in production?
  67. Sorry..Wrong forum
  68. Kill Switch Between ESC and Rx- Need Help!
  69. Doubt about the given CG on Seagull Edge 540 EP
  70. Questions about motor sizes and escs
  71. First LiPo charge taking long time
  72. Seen this yet?
  73. Teamspeak
  74. New RTF models?
  75. Problems with radios.. great :(
  76. Buyer beware Hobby Lobby and customer service
  77. Cant find any ten pound electric planes.
  78. Trainer
  79. New Lipo battery problem
  80. Comparable Motor System
  81. Turnigy outrunner equivalent for a E-Flite park 480?
  82. Wire Size/Type from ESC to Batteries
  83. Why 2S2P 7.4 V lith ion or lipo ?
  84. hello!
  85. MP Jet 25 motor bench test
  86. Plans
  87. P? JK AEROTECH T-52 TRAINER
  88. thanks to Tower Hobbies
  89. Radio
  90. 8FG Futaba radio
  91. Thunder Power 610C Questions...
  92. MULTIPLEX MENTOR OR MINI MAG LOW WING CONVERSION
  93. LIPO chargers-which one???
  94. Thunder Tiger DGA series EP Warbirds
  95. College student ineed of help selecting planes!
  96. pc-21 pilatus
  97. Duralite 4300 Problem
  98. When good times go bad, and stupid.
  99. waterproofing with hot glue
  100. Servos jitter when using CC bec
  101. J-3 Piper Cub bush plane
  102. want to know if their are any open rc field in fresno california for rc airplanes
  103. up gread motor for a piper j-3 cub
  104. Triton2 eq and Super tigre lipo. COMPATIBLE???
  105. Zekek's Park Scale Models - a review
  106. Best 4ch Beginner Plane
  107. Motor fried up
  108. A123 set up
  109. what do you think of the piper j-3 cub
  110. ESC question
  111. Motor Twitches Forward and reverse
  112. Ebay Electric Planes
  113. 1 blade prop?
  114. 80A ESC w/BEC - Can't find them!
  115. Turnigy Acucell Chargers
  116. Is there a accurate 3 blade prop calculator on the web ?
  117. accucell 8150 manual - charger
  118. Sabart angel 50e
  119. It flies afterall
  120. Beechcraft stagger wing 72" wing
  121. Going Electric
  122. Electrifly Peak 400 charger
  123. Using IC props on electric motors
  124. Using a 25C Battery on A 893KV motor
  125. Grinding a flat spot on your motors drive shaft ?
  126. Motor kv Rating
  127. Indoor flyin tonight 15 Jan Bentleyville, PA
  128. Covering foamies
  129. Electric retracts
  130. Check out my new mini Funtana x
  131. Richmodel Quickie 380
  132. Please advise on a 3d out door electric
  133. ESC as a Nav Light Switch
  134. Flip MinoHD Hat Cam
  135. Swaping the prop shaft
  136. 2nd Electric Aircraft
  137. From Glo to electric
  138. the drone
  139. Great Planes ElectroStik motor problem
  140. Using 3S Lipo on Nimh setup?
  141. When to stop flying on LiPos ?
  142. Pusher Propellers
  143. What is the best light weight covering >>>
  144. Foamy Servo Torque?
  145. Motor/ESC Extensions
  146. Light on DX7 Receiver
  147. Ratings again - Kv to current rating?
  148. Battery and receiver
  149. F-22 Raptor to electric
  150. Nitroplanes Canadair Twin
  151. NiMh 6.0 1200Ma battey charge
  152. No Instructor Necessary
  153. Blade MCXRTF
  154. New plane for Xmas!!!!!
  155. RC passion
  156. watt meter
  157. Electric Setup
  158. Stick tips
  159. Flight Duration Question
  160. Virginia's Pre Spring Fling
  161. Yak 54 Foamy Maiden
  162. Wanting to fly, maybe...
  163. Question on programming TX
  164. Tangerine Electric Festival
  165. New aircraft advice
  166. great planes VFO
  167. Problem with eletric setup..Please help
  168. Converting a largeish airplane to electric
  169. Futaba Tx with ParkZone BNF Plane?
  170. Beginner Question re wires from motor?
  171. What size props
  172. INFO ON ALIGN P-51D MUSTANG
  173. BNF & RTF compatibility
  174. Good service
  175. electric props
  176. 2 brushless motor wiring?
  177. twin engine choices
  178. sig wonder brushless
  179. Comparing 2cell to 3cell lipos
  180. Getting prop tight on a Power HD motor
  181. Best Pitts Plane
  182. Basic Electric Question
  183. reusing my easy glider pro power pack
  184. SJT Connectors
  185. Great Planes Edge 540T vs 3D Hobby Shop SHP 47
  186. Is ths safe? battery storage/transport
  187. SLC / Lehi info needed
  188. What are your other hobbies?
  189. Electric motor power question
  190. TX & RX
  191. Multiplex Mentor
  192. Micro LED's for micro Mustang
  193. F3P Indoor
  194. refinishing a fiberglass floatplane fuse
  195. E-flite power 46- 5lb sukhoi 50
  196. DUALSKY MOTORS
  197. what size motor and battery
  198. New to E-Power
  199. Royal Beech Baron Twin Conversion
  200. Hacker motor shaft too short?
  201. US Distributor for Pulso Motors
  202. Using connection module for parallelying ESCs?
  203. Parkzone Sukhoi
  204. SPEKTRUM DX5e question
  205. Futaba Tx with ParkZone Plane???
  206. AR 6110 DSM2
  207. 12s A123 integrated balancing chargers
  208. motors and rpm's
  209. Megatech Ambassador Giveaway
  210. why won't me batt turn the motor?!
  211. The E-Flite P40 Warbird ARF kit! Review& Flight Demonstration!
  212. Esky Belt CP brushless motor work in plane?
  213. Building first foamie! Need a little help
  214. ST model cessna 182 (or hobbico flyzone cessna 182 as they are same plane) upgrades
  215. Watt Meter - Which one to buy ?
  216. Multiplex Twinstar II
  217. Watt's up problem
  218. multiplex twinstar II
  219. Parkzone Corsair battery replacement
  220. Electric Trainer
  221. Custom Parkzone F4U Corsair
  222. Spektrum Recievers....
  223. Poor service with Hobby Lobby/Alfa Models
  224. Lipos (mah) question
  225. 3S or 4S on a Twin??
  226. Blinky Balancer adaptor
  227. Matching JR 9303 to E-Flite 10 AMP Brushless ESC?
  228. Where can i get these props?!
  229. Parkzone Corsair wing attatching
  230. Max Battery
  231. covering ideas
  232. Parkzone Micro 210 Centurion
  233. C rate
  234. turning off led circuit with servo signal
  235. servo mixing
  236. RimFire .46 or .55 ?
  237. Banana Hobby Back on my DO NOT RECOMMEND List
  238. Single Power Supply OK for 2 Chargers ?
  239. PC power supply?
  240. Himax Motor Gear install
  241. Can't Decide for plane
  242. Jeti ESC
  243. 3 Blade electric prop
  244. Unlabelled ESC
  245. new quad
  246. Phoenix Tucano EP ?
  247. Equipping 34in. G.P. Spad Parkflyer
  248. EDF Fan Balancing
  249. servo compatibility
  250. satellite for AR7000
