PDA
View Full Version : Electric General Discussion
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. find small wire
  2. motor for 60 to 65 span warbirds
  3. Model on my TX question
  4. the out runner motor blues
  5. ESC using external battery question
  6. Hobbywing V4 130 A esc with BEC
  7. Cessna push pull... one Glow & one Electric
  8. 1/4 Scale Sopwith Triplane
  9. Sopwith Triplane
  10. Kadet Senior Sport ARF Power Optioins
  11. I lost control of my electrified glider
  12. .061 to .074 size to electric
  13. Beep beep beep
  14. Is this $13 Flight Controller for real?
  15. Charger electric draw from house outlets
  16. Avios C-130 Hercules with parachute drop
  17. FlyFly Beechcraft DUKE B60 twin
  18. Durafly BONANZA flying
  19. Tools to take to field??
  20. online graphing tool for motors and propellers
  21. I just bought a electric stick question...
  22. George Miller needs some help
  23. Battery Weight and Plane CG
  24. Banana Hobby Grob 120TP
  25. Top Notch Kits Rockwell Aero Commander Shrike
  26. Welcome to my "nitroplanes" nightmare
  27. New to Electric
  28. Does battery size matter?
  29. g 60 size need brake turned off
  30. Converting Aeroworks Extra 60/90 to electric
  31. Some questions on changing battery size
  32. Giant Scale Landing Gear Builder
  33. Young kid builds and flies best Magnus Effect plane
  34. Warning for new people!!
  35. Turnigy G-46 550kv-670kv ?
  36. Sale at Horizon Hobby
  37. NEW Avios Grand Tundra (unbox and flight test video)
  38. Avios Grand Tundras are coming!
  39. V2 Durafly Spitfire Mk24
  40. Can anyone identify a Twin-Motor kit which uses Motor Differential Thrust Vectoring?
  41. Solid LiDAR CE30-D for UAV
  42. Micro boards with BL built in.
  43. ELECTRIC Self,Rotating,MEGAWING!
  44. The right combination for the job....
  45. starmax 1600mm a1 skyraider parts
  46. Newbie DX7s dual elevator and dual Aileron setup
  47. Which motor and ESC for Recruit
  48. Newbie with Delta Ray question
  49. ESC or motor problem?
  50. Parkzone SE5a
  51. ESC not working... how to test?
  52. MonoModule: MonoThrust_MonoBase_DuoBase_TriBase_MonoWing
  53. FunFli 4 - 20
  54. Need help- battery for aspire ( older plane) I am new to this...
  55. Need help- battery for aspire ( older plane) I am new to this...
  56. The most powerful RC motor available?
  57. Motor / Batttery / ESC Sizing Help Needed
  58. MOSFET on/off switch
  59. Remember Hydrofoam's?!
  60. Motor/ESC beeping issue
  61. How to wire two BECs on a 2x 5S lipo setup
  62. ELECTRIC S.R.W. Self,Rotating,Rotarywing
  63. FMS power board
  64. DualskyXM6350-DA12 V3
  65. Li-Po battery ban
  66. Avios Bush Mule from Hobby King
  67. An awesome motor and no home...help!
  68. Multi engine speed controls - fixed wing or copter - how do you control them?
  69. UMX Timber leading edge slats
  70. UMX Timber!
  71. Venom Battery
  72. EDF battery telemetry
  73. electric speed control??? 38lb vehicle 2 24 volt brushed motor
  74. Gens Ace 90A esc
  75. Armstrong Whitworth AW.660 Argosy Cargo Transport. Filmed in UltraHD / 4K
  76. Hawker Tempest Mk V (awesome Benedini Sound System). Filmed in UltraHD / 4K
  77. EVADER - Motor Beeps Quick Question:
  78. Need a deuces wild
  79. What size motor
  80. Hacker 30A-10L V3 problem
  81. High Speed Electric Hangar 9 P-51 Mustang [UltraHD/4K]
  82. Hobby king j3 navy cub - assembly and review
  83. Needing help on Hitech Aurora 9 differential thrust
  84. Help me identify this ARF.
  85. Can you use a bec esc, as an opto type?
  86. Transporting a bunch of foam planes carefully.
  87. Beast 60e power setup???
  88. Electric noob....did i fry my receiver rx?
  89. Suggestion for Hyperion sniper replacement
  90. difference between a 30C lioi and a 50C lipo
  91. replacing a t28 spektrum receiver with a futaba receiver question
  92. [review] Charsoon Magic Cube charging System
  93. Extending ESC Wires ?
  94. Running BEC with Seperate RX Pack ?
  95. Lazertoyz Fenix 120
  96. Electric twin conversion of Hangar 9 .60 size Ultra Stick
  97. Looking for my 2nd plane
  98. 4010 duo reading wrong voltage now- help
  99. flyzone Inum connectors
  100. Need for speed? EFXTRA!
  101. Need info for twin electrics
  102. ESC Identify (Voltigeur 3D)
  103. Guidance for newbie
  104. General Hobby Geebee R3
  105. Our electric foam planes (photos and video)
  106. Which Brushless motor to use?
  107. Champ S+ Throttle Problem
  108. First (low cost) FPV wing...easier than I thought
  109. Props for Speed 400, Speed 600 motors
  110. Eleven Hobby T-28 Limited Yellow
  111. Lipo Charger compatibility
  112. Sterling Models B17G 39"
  113. BEC and separate rcvr battery at the same time?
  114. Battery charger advice
  115. Essential RC Electric Compilations...ALL THE BEST FOR 2017!
  116. Bat-Safe IS REAL
  117. HoHoHo Merry ChrisKwanzaUkkha!
  118. WWW.King-Dumps.cc - Shop Sell Dumps With Pin ( China / Us / Uk ) Online !!
  119. Hobby King - Degraded Customer Support
  120. Forward / Reverse Control Needed For Electric Motor
  121. fire ice charge case
  122. Looking for a Quad
  123. Bat-Safe- Real or ?
  124. Suggesting power source for the Electrifly Super Stearman bipe ?
  125. Hobby People 2814/06 Motor
  126. Please help escs going nuts
  127. Majestic Trojan Takeoff , I'm proud of this video :)
  128. Ares Crossfire Quad question
  129. RC Club Electrification Options
  130. FUTABA 8J8 Tx problem
  131. anyone ever use Tomcat motors
  132. MrRCsound
  133. Flyzone Calypso--Erratic Motor Operation
  134. BP Hobbies - E-Aero Eagle EPP Kit
  135. soldering iron question
  136. Question on nitro and electric spinners.
  137. Terremoto V2 Battery
  138. Run time
  139. Motor selection
  140. Help setting up receiver in Roc hobby Waco Biplane
  141. Comparing FPV quadcopters
  142. Need help setting up my Artizan with Aurora/Optima combo....
  143. Hobbico Flitework FLWA4110 PT17-XS Stearman Red Bull
  144. Flyzone Calypso ESC help
  145. Hobbico Skyfly replacement?
  146. Tactic TTX 850
  147. ESC problem?
  148. NEW MicroAces replica kits of historic aircraft
  149. Ant-25
  150. C of g seagull pulse 40
  151. Second thoughts on my ESC
  152. A couple of questions
  153. HobbyKing Night Walrus
  154. Ant-25
  155. New lipo the did something scary.
  156. EFlite Timber
  157. New to Site
  158. RC Airplane Electric Motor vs Prop Size
  159. Flying W Capricorn
  160. Electronics expert help needed
  161. Twin Hacker Q80 contra-rotating setups on P-51 Mustang duo
  162. Wacky 'flapping wing' RC Pterodactyl Ornithopter
  163. Double-Sided PCB Prototype low cost manufacturer huanyupcb.com
  164. Im thinking of buying a fpv drone, Should i get Syma or Cheerson?
  165. Cheerson cx-10 always rotates (Yaws) to the right a little bit
  166. Watt meter connectors
  167. Short Stirling Bomber
  168. Radio transmitter help needed.
  169. Screaming low passes...ELECTRIC GIANT SCALE P-51 MUSTANG
  170. Hanger 9 said .60 glow and eflight .46 for Electric Why?
  171. Using lipos in parallel
  172. 308 DUO or GT500 DUO?
  173. Flex Inovations QQ 300 Extra, WARNING DO NOT BUY
  174. Trouble finding prop size
  175. 1 motor on quadcopter not powering up (twitching)
  176. How Do I Remove & Replace Tires?
  177. What is a good .40 size electric sport plane?
  178. eflite 180 connector
  179. Durafly TUNDRA -ASSEMBLY Video
  180. Looking for specs: Xtra 2826/12 outrunner motor
  181. Found a cheap place to buy quadparts and quads
  182. Runcam2 the Mobius killer: Review and Onboard action
  183. Going elect
  184. Which of these 3 props to choose, when considering pitch vs thrust??
  185. Given a tactic TTX403 transmitter, what can I use it with?
  186. Hobbyking Bushmaster
  187. NEW Durafly Tundra
  188. D/r and expo setting whats the best setting for a newbe
  189. Charging at the field
  190. Crash lipo protection
  191. E-flite UMX: Which is your favourite?
  192. LED light power from aux on receiver.
  193. simulator program
  194. DHC-2 A600 trainer plane with auto-stabilisation
  195. Sense Hobby ESS-AIR Engine and Gun sound system
  196. Replace connectors
  197. Fly Zone "Air Core" being discontinued??
  198. Kv versus synchronous RPM
  199. Hanger 9 J-3 cub. HAN4000. 80" Wing.
  200. Please help me find appropriate servo, radio, and receiver,
  201. Nano Quadcopters flying away
  202. Hobby King Bushmaster wing
  203. Hobby King Bushmaster wing
  204. You big scale electric guys; kindly compare these 2 stats and pick a motor....
  205. UK Hobby Store selling Horizon products and more!
  206. Electric vs Glow props
  207. Great Planes Cherokee GP/EP setup
  208. Recommendation for a high wing plane
  209. Can blown power to Skyview FPV be repaired
  210. Need advice on electrical set up
  211. Futaba Gauge Wire ?
  212. Increasing Range on Radio Transmitter
  213. Making a 4 bladed prop?
  214. Hobbyking Bushmaster electric
  215. YEP 80 ESC - Disarmed itself
  216. APC Pusher Prop not pushing
  217. To get 12s 44.4v just add the 2 + leads together and the - 2 together
  218. Looking for good 5000 mAh battery
  219. How Many Cells Do I need?
  220. Servo control with Raspberry Pi
  221. Very happy with E-Power
  222. Quadcopter goes huge!!! Now we can ride in them!!
  223. RC paramotor/paragliding
  224. Ballistic
  225. How to: OrangeRX 3-axis stabeliser V2.1 (software update)
  226. disarming throttle with radio switch on electric plane?
  227. Quag Question
  228. Ben Buckle vintage kits
  229. tiger moth /gypsy moth engine sound systems?
  230. Plane safety/ESC Low Voltage motor power down.
  231. Tactic 650 w/ 2 receivers
  232. e-flight rv9 450. help with longer flight times
  233. Parkzone P51 Mustang Upgrade ideas???
  234. Cutting wire, tail reinforcement
  235. Walkera V450D03 Servos
  236. Help!!!! Please!!! I need lots of power on a 7 in prop
  237. Esc help
  238. Best remote?
  239. telemetry help
  240. Sukhoi 29mm trying to crash
  241. Electric prop collet wrench TIP!
  242. What do I need ?
  243. Xinlin shiye x118fpv
  244. aircore on sale july 2015
  245. Cell mismatch at high current
  246. Multiplex Rockstar Aerobatic Biplane
  247. Hobby King
  248. Microlite; a P.I.A to use and what you can expect........
  249. why do i hear a whistling/screeching sound when in the air??
  250. 4 Channel Park Flyer. Harbor Freight P51 No Good. Need Advice
