PDA
View Full Version : RC Gliders, Sailplanes and Slope Soaring
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26
  1. Spoiler string
  2. Spectra Replacement Motor Help
  3. What should my next 2m glider be
  4. Composite Wing Repair
  5. airfoil template
  6. Retriever Parts/Plans?
  7. Kyosho stratus 1600
  8. Quick start pop offs
  9. Hangar Nine Aspire
  10. Tow hook location
  11. Tow hook for Zagi
  12. Almost had to rename my Sailaire "Cooked Goose"
  13. Wind Weasel...
  14. Control rod installation for Bubble Dancer
  15. Servo in tail
  16. Futba 9cap seting flaps and elevtor mix HELP!
  17. bird of time spoilers
  18. light lift handlaunch glider
  19. Have motor, need sailplane
  20. HOB 2S coming out of the box party
  21. Gentle Lady Spoilers
  22. Spoliers or flaps
  23. servo size
  24. Riser 100 fin and rudder
  25. Hinging rudder & elevator Gentle Lady
  26. Your years of experience needed here!!
  27. control throws
  28. problem
  29. Foot Pedal Release - Bungee Launching - Help
  30. Super light sloper
  31. spoilers in model sticking up?
  32. what to get
  33. Servos for 4m
  34. Where to place tow hook
  35. Help naming my Sailaire
  36. TOW PLANE AND SAIL PLANE
  37. How to make Spoilers for my Glider ?
  38. Hi-Start = Turn??
  39. Got my Jones off
  40. Glider from scratch??
  41. To "E" or not to "E" that is the question.
  42. Looking for a slope plane
  43. Bird of Time kit plans
  44. c of g help on mythus 2500 s
  45. HL Glider experience
  46. Loosing Volts, any Opinions
  47. BIRD OF TIME BY DYNAFLITE ARF dimensions
  48. FLIGHT BOX BLUES.....
  49. Favorite Magazine for Sailplane Hobbists
  50. Sky Bench Aerotech, gave em' a try
  51. Pull-pull for HLG?
  52. first aileron glider
  53. Scale slope soarer
  54. SPIRIT ELITE
  55. splicing latex
  56. egg carrying
  57. Mini Floh (AIL)....how is it?
  58. 4 1/2 meter Ventus-2cx
  59. Enuff Rudder
  60. here you go
  61. does anyone have some 2m lil bird plans in good order
  62. Need planes for Soar Birdy Sailplane
  63. Need planes for soar birdy Sailplane
  64. Winch?
  65. old windrifters
  66. Need help need to find plans Please help
  67. Hi pro soarer
  68. RA cores wing
  69. small pod and boom glider
  70. Sig Riser tip,hints etc.
  71. Good Sailplane radio? Eclipse or 6102?
  72. Recommended servo size for a GP Spectra EP glider?
  73. Replacement rubber for a high start
  74. OS powered Gentle Lady
  75. Sky Bench Info
  76. Buzzard 144
  77. adjustable tow hooks
  78. Where's the hump in N.C.?
  79. MOVED: Can gliders operate with an autopilot, out of visual range?
  80. paragon sailplane
  81. Nimbus 4D
  82. Gold Medal award program updates
  83. Aero Tow Mechanism
  84. skybench kits reputation?
  85. DG-1000S
  86. Dynamic Soaring
  87. FS ZAGI 5C
  88. X-models Blade 1.5
  89. MOVED: Help me identify a weird plane
  90. Ed Sledgers The Fazer 2-meter. . . needing building info
  91. good beginner sailplane/glider for use on beach
  92. EP climb rate
  93. wing tip ailerons
  94. building a ZAGI 3C EPP wing for slope soar
  95. Sailaire PIctures anyone have any?
  96. I had it broken in 15 minutes
  97. 1st glider
  98. Discus Launch Glider Wannabee
  99. Discus Launch Glider Wannabe
  100. Has anyone built a house of balsa 2x6 from scratch with spoilers
  101. Which Video Camera for my Glider?
  102. sky bench viking kit
  103. Retract for Fournier
  104. Surgical tubing..what to do with it??
  105. TT Windstar 2mm sail need your halp please.
  106. line strength and length
  107. Big Pig 2M V-tail need more power !
  108. Wilga ARF?
  109. filip rg
  110. XL 3200 powered glider
  111. How long does it take you to build a kit?
  112. Napa Valley
  113. Scale Kit Manufactures?
  114. Do gliders use up thrust?
  115. Aerotow Advice? Need some Input. First Time
  116. Got my first glider
  117. Kyosho Viento--Ever fly one?
  118. NSP Opus
  119. Oly II from Sky Bench
  120. Epp BD-5
  121. tips on building (general) spirit 100
  122. high starts
  123. Thinking about the SIG Ninja (or similar)
  124. Suggestions about building a Spirit 100
  125. Dynaflight Daydream opinions?
  126. Toucan flyers? Anybody out there?
  127. aeronaut aerofly
  128. Hybrid dlg
  129. Which Plane: D.A.W TG-3 or N.S.P.Defiant.?
  130. Great Planes Spectra Select Sailplane
  131. Towing a glider w another plane??????
  132. 7 cell electric glider
  133. Rocket Powered Glider
  134. Nikko Windjammer Airplane
  135. FLYING WING SERVO RECOMMENDATIONS?
  136. Pinnacle Hi-start
  137. Which sailplane? Aspire ep or Spectra RTF?
  138. joe nall question???
  139. Pensacola Scale Sailplane Aerotow Feb 6,7,8
  140. Its here now what
  141. Scale Soaring Medal program
  142. Night Operations
  143. Hi-Start
  144. Handlaunch a Thermic 36?
  145. Powered sailplane question
  146. PIGGYBACK????
  147. EPP Foam Suppliers
  148. Rookie's back....which glue?
  149. WARNING...Rookie on the board!
  150. Grand Espirt Comments?
  151. Slope sites near Seattle, WA ?
  152. Russ Thompson?? looking for info..please
  153. fibreglass fuse modifications
  154. Will it fly?
  155. Is my F-86 combat foamie too heavy?
  156. Sagitta
  157. Bungee length?
  158. I'm new to this. Which Futaba small servo's for a Gentle Lady?
  159. RTF Aileron Glider
  160. Servos in 2.5M
  161. Help im getting into th rc hobby again please help!!!
  162. Aileron set-up using Hitec Prism 7X on a full house sailplane
  163. Help me identify this plane
  164. plans for beginner sailplane?
  165. RCM Mag - Maxisailer
  166. Throw Problems
  167. Rare Soarcraft Diamant 116" Span Kit 4-Sale
  168. Designing a Sailplane
  169. Hobbico Avistar Tow Plane?
  170. Performance kits that don't break the bank?
  171. Colibri 1M Poly advice...
  172. Upgrading termal gliders
  173. Obechi Veneer
  174. Getting back into planes
  175. New to sailing, need advice
  176. HELP/INFO on BlueBird servos
  177. Cheap wind speed indicator
  178. Flash 5X Radio setup for a powered Glider
  179. Senorita into a electric Tow plane
  180. Comp 2M Sailplane
  181. 1984 MAN IssueSchweizer TG-2 CONSTRUCTION ARTICLE
  182. Drela Bubble dancer?
  183. Jurassic Pteranodo RC Glider??
  184. Sailplane terms - Help me understand
  185. Thermal Sniffer
  186. d tube repair
  187. P51 Kit conversion to PSS
  188. Foamie flying question.
  189. Need Theory and Practice
  190. Dynaflite Bobcat
  191. glider for beginner
  192. Winch-Retriever????
  193. Lanier Hawk
  194. Information on the Irvine X-it
  195. Re: Anyone flown the Albatross 100 from FLAIR models?
  196. Coroplast Glider?
  197. Need a little advice
  198. V tail Incidence measurement HELP!
  199. Best for thermalling..HF 3.2 DG600 or HF 3.0 ASW28?
  200. Foamie sailplane repairs
  201. Aerotowing Bird of time
  202. Spirit 2m Building / Modification Question.
  203. Do you have working spoilers on your GP Spirit?
  204. RG 14 and RG 15 airfoils
  205. West Central Iowa Clubs, Flying Sites ?
  206. where to buy
  207. Soarcraft Diamant
  208. Polar plots for MH30 foil
  209. address wanted
  210. To the N. Richland Hills/Watauga TX Sailplane flyers...
  211. ArtHobby Thermic Res
  212. Electric Glider Help - Terry Graupner replacement
  213. Electric Sailplane Suggestions-Filip 600
  214. Wing area questions?
  215. Legend
  216. which airfoil to choose from?
  217. Is there a special slope soaring forum?
  218. Northeast Sailplane XL 3200 or Elegant 2
  219. WTB - DAW Schweizer 1-26 HLG
  220. Best 2.5 - 3.0m scale ARF?
  221. Ready to learn
  222. Question.....
  223. where do I look
  224. Simpro Solution XL sailplane
  225. Ariane 5
  226. Art Hobby Sierra Dihedral
  227. High Performance
  228. all wing foam glider
  229. Sterling SCHWEIZER 1-34 - Help w/ Wing
  230. Osiris by ICARE
  231. Powering a Ninja
  232. aeajr bungee aileron
  233. newbie questions
  234. Building questions.
  235. Jointer tubes?
  236. Wing Design -- Where to begin?
  237. Trying some HLG
  238. hobie hawk glider
  239. efficient hinge gaps?
  240. Orlik glider
  241. Air Ventillation of Spectra Glider ?
  242. bungee launching
  243. nice pictures of gliders
  244. Power Pod Plans
  245. Gewalt-Grossegler kit - Help needed!
  246. dartar 2m
  247. Help! I need to identify this sailplane
  248. Olympic II
  249. designing slope soarer?
  250. Looking for a DJ Aerotech monarch
