PDA
View Full Version : RC Gliders, Sailplanes and Slope Soaring
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26
  1. Gentle Lady wing rib patterns?
  2. Buying First Glider
  3. Rebel arf what manufature
  4. Dodgson kits
  5. Second Plane...What to choose?
  6. Soaring in France
  7. Kestrel 19 / Glassflugel 604 plans...?
  8. Hi Start Hook Location?? Crashed twice!
  9. Different classes of competition sailplanes
  10. HLG Plans
  11. WOW! Talk about fall thermals!!
  12. Airfoils: Quabeck vs. Selig
  13. Incorrect CG causing porpoising? Need Help
  14. Winter Soaring-Is It Possible?
  15. looking for a motor glider
  16. Kulbutin: Anyone flown one yet?
  17. spoilers?
  18. Spoilers
  19. F-117 Slope Soarer
  20. Spirit 100 electric conversion
  21. Spirit select arf
  22. JR servo
  23. skeeter
  24. Building
  25. Towing and Skydiving Videos!!!!!!
  26. Good slope sites in Washington State???
  27. help designing 2 meter thermal soarer
  28. Anyone Own And Flown The Xr Combatwing On The Slopes???
  29. Glider Tugs
  30. Tow plane info...
  31. recommend good aerobatic / thermal catching plane? read inside
  32. Good sailplane slope sights near Mid-Michigan???????
  33. Coyote
  34. Looking for a good electric glider
  35. Places to soar off I-5 & I-15 in CA?
  36. DAW KA6 for aerotow
  37. Sagitta 100"
  38. Any Good and Cheap Gliders out there???anyone?
  39. Olimpic 650 sailplane?
  40. Power Pod
  41. gliders in Oklahoma ???
  42. aspire small talk
  43. Offical AMA notice about the Torrey Pines Gliderport
  44. arent gliders relaxing.
  45. Airwise Altus Xl/ Omega 1.8m Sailplanes
  46. .
  47. Flying wing help...
  48. Sagitta NIB - Mods?
  49. G.P. Spirit 2m Tips?
  50. slope soaring in Western Michigan, where
  51. Who's Flying The Mapleleaf Encore???
  52. Where can I get free plans
  53. Vertical stab/rudder 2 degree slant
  54. Home Made Hi-Start?
  55. clear canopies?
  56. bomb drop
  57. A Great glider!
  58. Corrugated Plastic Glider
  59. Glider plans
  60. CLUTCH WINCH--ALIVE AND WELL!!
  61. carbon - radio problem ?
  62. Life after death the project
  63. Goldberg Electra or Great Planes Spectra?
  64. Down East Soaring - Last conest
  65. Radio range
  66. Mini Ellipse CG, Throws, etc?
  67. Gliders and 10x
  68. how do you discus launch a glider?
  69. XP3 DLG finally came in !!
  70. Motor Glider
  71. Medium Priced Molded Ships?
  72. Tow Hook location - ASW 19
  73. Converting aspire to electric
  74. Spirit of 9-11
  75. DLG discuss launch glider, ANY SUGGESTIONS???
  76. 2 meter CG? How much lead does it take?
  77. Hand Launch Glider, What Should I Buy???
  78. First Test/Trim Flight - Advice needed.
  79. Thermals, WHERE?!?!?!?!?!?
  80. where's the beef?
  81. Powering a 2m sailplane
  82. Biplane Glider
  83. H9 Aspire EP spoilers
  84. Kobuz 3 view
  85. 1st Annual Pine Island Aerotow
  86. Spirit Elite ARF
  87. Kadet Senior - Good Tug ?
  88. Yeeee Haaaaaaaw...
  89. HLG motor HELP!
  90. GP Spirit hooking left of launch big time please help!!!
  91. agr models sidewinder?
  92. Rectractable Gear - Worth the hassle and weight ?
  93. 2 meter wing
  94. scratch built glider with twin booms!
  95. Tugs
  96. Tow Hooks - with Landing Gear ?
  97. Elepsoid flaps
  98. Looking for FVK Bandit info
  99. Gps altitude,speed measurement question
  100. Aspire RTF Electric
  101. Just got a SIG RISER any pointers?
  102. Dodgson Saber questions
  103. holding the outer wing section on Airtronics Legend
  104. Tow Aircraft / DG1000
  105. Current winds via the net
  106. K-Rat by Robbe?
  107. 1:5 Scale sailplane ETA
  108. Visalia 1990 Fall Fest results,,,HELP
  109. modifying my spirit wing, Ollie and others please lend me your brains.
  110. Winch - Question/Guidance
  111. DG1000 - Tips/Advice ?
  112. i did it, FINALLY
  113. Getting Sailplanes
  114. Construction Questions for Caleb F5B
  115. Glider pilot progression?
  116. Where to purchase large scale/semi-scale sailplanes ? ?
  117. Minimoa Plans - Who sells a good one?
  118. Tuck under
  119. closed
  120. Large 110" Sailplanes - Is Bungee launch OK ?
  121. GOt a GULP
  122. standard to v conversion
  123. Craddle for piggybacking?
  124. H-9 Aspire, what do you think about it?
  125. Flying in Atlanta
  126. Mini Dragon
  127. dive test
  128. Futaba butterfly/v-tail bug
  129. v-tail vs. conventional
  130. wanderer 99inch and 72inch
  131. Minimoa
  132. TF Phasoar glider
  133. Altus XL from airtech
  134. Help with first sailplane decision
  135. Paragon with SD7084
  136. center of balance for 2m sailplane?
  137. Skids and Skegs
  138. Recordbreaker
  139. Discus Hand Launched Glider Recommendation?
  140. Rocket Glider
  141. Aspire folding prop question.
  142. Flaps-ailerons
  143. Thermal soarer recommendations
  144. Hi-start or winch ?
  145. C/F spar reinforcement
  146. Wanted Stratos SR
  147. Anyone going to Soar Utah?
  148. Piggyback Incidence Question
  149. MidWest Essence- Good or bad?
  150. Feedback On The Huron Dlg?
  151. ordered DLG, Servo choice???
  152. Are there any giant scale sailplanes out there in the $400 range?
  153. Sailplane recommendation
  154. Piggy Back Cradle Plans anyone?
  155. Hacker motor for Omega 1.8?
  156. Adriana electric power sailplane fron NESail (NEED INFO) Please
  157. thermal sniffer
  158. shrike extinct?
  159. Motor Glider Questions
  160. Best prop for Aero-Towing?
  161. Robbe silence glider
  162. fiberglass reinforcement
  163. Career Oportunity- Research and Development Technician
  164. Plane suitable for piggyback ?
  165. Landing on hard ground
  166. Sagitta XC fusalage/Bob Sealy
  167. Which DLG ??
  168. Help
  169. Sub-base Eases Winch Alignment
  170. Scale Soaring in Orlando/Tampa/Lakeland area
  171. V Tail ? Kinda new at Sail planes
  172. Tow hook
  173. gregg in ohio
  174. Radio
  175. Flying Wings Show and tell
  176. Whats best for a begnner?
  177. Glider videos
  178. Re: New Moderators??
  179. My new TUG
  180. Coyote
  181. WattAge ThermalAire
  182. elec assist 72" V-tail
  183. foam core repair
  184. AXI motor
  185. Wing Rod
  186. towing with a C-47
  187. C/F pushrods
  188. Hitech Eclipse
  189. panels?
  190. Combat models F-16 (conversion)
  191. looking for a good towable sailplane
  192. Towline help please
  193. Sailplane magazines??
  194. Dynaflite Bobcat
  195. Flying weight???? Cirrus 2-Meter ARF
  196. thermals
  197. Anyone remember the Doodler
  198. tow hook location?
  199. NovaTech Stingray?
  200. MPX Lucky: Landing setup
  201. Graupner Discus-2b
  202. American Heritage sailplane documentation - free
  203. CLUTCH WINCH READY FOR TESTING
  204. CG for zagI
  205. Figure this one out :)
  206. battery monitor
  207. Scale Glider color schemes
  208. Sailplaning in PGI
  209. PA-1 autopilot on a glider?
  210. Looking for other Gilder guys in my area
  211. Hey Ollie, got a question for you...
  212. Bee EPP flying wing
  213. Mugi ?
  214. R/C hang glider?
  215. shoe
  216. vario
  217. HLG Pushrod Question
  218. Mountain Toys "Gentle Foamy"
  219. Robbe ASW27
  220. Polecat "Hammerhead"
  221. So long handlaunch
  222. Thermal Theory
  223. Aspire wing mod question
  224. removing cross weave tape from combat gliders
  225. Hobie Hawk fixer-up project
  226. Glider Nuts - Take note! She Flies!
  227. JR 610 rx ok in gliders?
  228. Spirit 2M ARF - newbie question
  229. ? about Center of Gravity
  230. NSP Huron
  231. HI-start dimensions, HELP
  232. Peck-Polymers Genesis?
  233. 2 Meter question
  234. "speck"
  235. TOWING .. I seek advice !
  236. Pacific Aeromodel Sportsman or Oriole rewiews?
  237. Great service from MPX USA !
  238. Canadian Soaring Society
  239. Help for sailplane, launching/tossing device
  240. Tow release
  241. My First Tug
  242. One hour flight -My 2nd!
  243. incidence
  244. G-Force DHLG
  245. Swift Flying Wing
  246. Dynamic Soaring
  247. Variometer
  248. "L'il T" Kit - no instructions or plans
  249. Looking for a Bob Martin Katie II ! !
