View Full Version : Glow Engines
- GMS 47 Blues
- 1.20 fs
- Enya .35X - quick question
- Rossi owners
- OS 32SX-H low needle settings
- Old Fuel???
- YS 91 -Help?
- Dave Brown Spinner on my OS91
- What props are you using for OS.61FX??
- OS 70 and 90 surpass rpms
- Smoke System
- enya 15 upside down
- does 2 x 0.20 engines equal a 0.40 ?
- Muffler for Enya .15 III #3303 ?
- mds carbs
- Test Stand
- Saito 300 TL
- Saito 100 Non-Linear Throttle Response
- super tigre 3000
- 4 Strokes
- Just got my $30 piston ring - nervous, yes!
- Am I the only one?
- Fox Eagle .61 ABC, where can I get it?
- Saito Problems
- HB 25 Germany???
- Seven 8 ounce tanks later...
- Please Help
- Saito RPM
- Saito 65 Rear Bearing
- K&B .61 operating temperature?
- Help with my Rossi
- Help With TT 54s 4 Stroke (No Instructions :o( )
- Diesel Engine??
- O.S. 40 lost compression
- ID a Norvell
- potential TT91FS OWNER
- Least expensive .40-.46 muffler?
- perry v30 pump problem
- what effect does higher nitro content have on a 2 stroke
- Break-in advice for OS .91 surpass...
- glow plug selection
- Moki 2.10 settings ?
- Engine for Cessna?
- Prop size for breaking in a TT .91 FS
- Who Has The Best Prices On Saito Engines?
- OS 50 problem (any comments are welcome)
- How to install a pressure fitting in a backplate?
- Probably a stupid question on wood props
- Zenoah G-62 Question
- how big a tank for a saito 100?
- Nova Rossi 50
- Rossi carb?
- Webra 50 and MVVS 49's out of stock?
- Magnum engines
- Da 50?????
- Fuel tank position
- What size would be better??
- TopFlite P39 engine?
- Saito 1.50 vs. G26?
- HB .61 Muffler and/or bolts
- O.S. FS-20 help with care and feeding please
- Irvine .53 for Pattern
- What are common problems with Moki 1.35??
- Ys 63 Vs Saito 100
- Prop adapter for 28cc 'wacker' motor.
- Mecoa 46
- Fox RC engines, where to buy??
- Fuel tank for OS .70 four stroke
- Now what. Maybe hydro-lock?
- Cold weather and engines
- Saito 90T
- question for you Saito owners
- Thunder Tiger GP 42 ABC
- Megatech M16 and O.S. 10E carb
- Muffler Pressure nipple placement for higher pressure?
- mvvs engine
- Simple new engine question.
- 4s
- Anyone heard of a Rossi .45 2000 Edition?
- Rossi Vs. NovaRossi, Please Explain
- OS 108 Remote Needle
- Inverted Saito 91
- Just "found" an Enya .60X...
- OS 61 VF-H with GS A-2 reduction G/Box
- MVVS .40 GFS/R ABC engine
- ballpark settings for magnum 46 ?
- .10 Sized Engines?
- Ryobi 4 Stroke Weedeater(gasser)?
- OS Max .15?
- OS 25F abc
- Small favor. Fuel filler question, howto.
- What tuned pipe for Irvine 53
- Which type of vibration absorbing mount works with a Saito 180?
- Timming a Saito 65 four stroke
- ryan trimmer
- home built twin 4stroke
- os 50 low spped needle
- Glow powered, Supercharged V8 at Toledo Show
- Ever seen one of these before???
- Starters with a DIESEL, Good or bad?
- Looking for .61 engine reviews...
- Quiet Engine techniques?
- .21 MT/Buggy engine
- Hayes fuel tanks-- Any good?
- enya 50 ss more power
- Replacing Rossi 61RE
- Enya 50 Heli engine muffler
- MDS 1.48 Breakin ?
- Blue Bird .46
- OLDER OS FS-90 NEED MANUAL
- TT GP 42 Pro??
- Magnum 52fs/os 52fs
- Which .40-.53 glow engine works better with 0% Nitro ?.
- needle valve extentions?
- Almost bought an Enya .61....but.....
- K&B Muffler Information
- Old ST-40 eng
- of cowls and cooling - RCV 120 SP
- Pitts muffler for Magnum .46
- irvine .53!!
- Tower Hobbie Engines?
- Enya 60 X parts
- Soft Mounts for a ST3000
- V-8 enigne...
- OS 91 Surpass II best prop????
- fuel consumption on SuperTigre G-90
- Thunder Tiger GP-42 Tuning
- OS91FX set up?
- custom headers
- Gms Engines?
- Magnum same as OS?
- ASP .61 adjustments
- YS Website Hacked!
- new engines acting strange.
- Magnum XL 15 Needle setting?
- Royal .25
- G-23 120 ultra stick
- Can't Find A Bearing For an Irvine!!!!
- Cox Texaco head source?
- overpowering airplanes
- New Tach - what fun!
- Tower Hobbies .46 Ball Bearing ABC Schnuerle
- will Rossi ever redesign?
- Fuel Suction
- Long stroke vs long props??
- Magmum 4 stroke engines Question
- another SAY-TOE 72 problem
- In Cowled Engine Help?!?
- Enya 60X Carburator...one of three?
- Thunder Tiger .91FS to lean?
- Is $75 a Good Price for a NIB ST .61???
- O.S. 120 FS with pump
- Possible Cure for Front Bearing Leakage
- TT pro 61 & Bisson OS 61 muffler?
- Saito 180 future carb. problem?
- 61supertiger
- Thunder Tiger Pro-61 vs. Magnum XL 61 A, what's better?
- How can I get the most out of my 70 Surpass II?
- OPS 1.8 help
- 4-Stroke inverted engine mounting??
- Engine Choice for 1/6 Zero
- Os61fx
- Thunder Tiger Pro 46 or Tower 46?
- Megatech .16 Tmaxx Question
- What's so great about an Irvine 53?
- Tuned Pipes for Webra 40 and 50GT
- Need a new .40 two stroke engine
- Moki 2.10 Advice
- Prop balancing: Am I a complete idiot?
- O.S. 160/Pump Question????
- Thunder Tiger 120 Pro
- Irvine 53 + 15% Nitro??
- Prop size vs. Engine...Why?
- K&b .40
- rossi 60 glow plug
- YS 1.20NC Fuel Tubing Size
- H9 Freestyle Smoke SYstem
- One-way valve ?
- installation of perry pump
- Where can I buy a T.T pro 46 Carb.?
- Website for MVVS engines?
- where can modelers find torque/hp information for model engines?
- SC .60 crash suvival (?)
- Muffler Extension
- tiger shark 91
- Some NEW thoughts on Thunder Tiger Products
- super tigre 2300 carb adapter
- YS glow Plug vs. OS F
- Tower Muffler not providing enough pressure to the tank. Any ideas?
- Saito 100
- OS FS-91 Surpass II FI
- Great Service from O.S.
- FOX .50, GOOD OR OUT OF DATE?
- Saito Timing Marks
- Help with Webra 40
- Moki muffler
- Enya 155 , how are they?
- Opinion...Os LA .61 or Os Fx .61??
- what is a cline regulator?
- Glow Plug Idle Bar: Questions?
- Irvine (+ other) engines on sale @ justengines!!
- Tiger Shark .52
- Props
- SUPER TIGRE S90K
- Inverted or Side mounted Engine!
- ONboard starters
- new Saito 120 when the noise began
- what is this cline regulator???
- What prop?
- who makes small 4-strokes?
- FOX Engine Owners, Info Please.
- perry or cline
- Irvine 72
- MDS Running In Questions
- motor mount for .15
- Irvine 53
- RPM "sweet spot" for OS 70 Surpass
- Os Fs 40
- New Magnum 52 XLS?
- I know I said NO BASHING for my MDS 40, but 4 Dead Sticks Yesterday!
- OS 50sx
- Bisson Muffler for Moki 2.1
- Saito 91 GK
- Testors RC engine???
- Enya 80 x muffler
- ys60 rear exhaust
- OS 32sx vs Mag 36 vs TT 36 vs Irvine 39?
- Saito 91 muffler
- Magnum 40GP Question
- ST G-90 gas conversion from Oct 99 MAN
- Help Identifing Older OS 61
- Wasp .061 RC
- ST2000 help
- Thunder Tiger, Gp 61, Best Value( M.a.n Article)
- O.s. 46 Fx Help!!!
- YS 63 Break In
- Irvine 53
- Saito 120
- Saito 56 Problems Running W/o Muffler?
- best hover prop for Saito 100
- webra 120 prop and pitts muffler
- Alternative smoke fluid
- Moki 180 + FAI Fuel + 50% Alcohol
- Irvin 53 problem
- 4-stroke equivalent
- Glow Plugs Keep Dying???
- Which .60 2-cycle do you like?
