- Did I damage my motor?
- asp
- TT 91FS Carb Question
- old engine?
- Can anybody I.D. this
- K&B Ducted Fan engine #9101
- ENYA .60III TV parts needed..Please help if you can
- OS 46 AX Question
- what engine
- CFM of a .40 or .46 Glow engine
- prop for ST 4500
- Cleaning castor off color anodized parts?
- OS 91FX any good ?
- Hottest .32 ~.36 R/C Aero motor ..???
- Where to locate a Magnum .91 XLS???
- Saito 72
- Higher % nitro affects needles how?
- Saito 115 Bent Crank ??
- HobbyKing.com ASP .91 4stroke engines
- Weird OS 10FSR muffler's nipple....***
- Magnum XL FS52AR
- What fuel for Saito .91
- need a car tune pipe
- Saito 90TS twin or 100 twin
- Fox 120 piston
- Thunder Tiger F-75s
- 91fx?
- Need Help Reassembling
- Enya .45 (6001)
- O.S. 91fx Break in
- Ever Run A Jett Muffler on a SuperTiger GS-45
- Moki Fuel Issues
- YS-110 won't idle when the engine cold
- Master Airscrew props
- Thunder Tiger 4 Bangers
- OS 91FS needle settings
- O.S. .40 four stroke issues
- Older TH .46 engine
- Counter rotating engines??
- Magnum XL blue
- Rebuild an old FA-50 Saito?
- Magnum .61 flooding
- A different type of Glow engine
- Engine rebuild?
- Saito .91 on a 300cc fuel tank.
- WHACK
- Enya debuts some new .32CX's
- G2300 flooding W/Perry pump
- Statistic project - please help.
- Troubles are back TT .28
- Low idle RPM on an Evolution .46 NT ?
- Pitts muffler performance question
- oil on wing same color as fuel
- webra silver 61 carb? no barrel
- Stupid problem - need help.
- K&B 3.5 engines
- Troubleshooting O.S. 46 problem
- Looking for Vintage Super Tigre G20, G21 Catalog
- BRUSHES FOR TOWER 12 VOLT STARTER
- Glow Engine Exhaust Temperature
- Wristpin plastic ends
- OS 120AX OS160FX
- Enya 53-4C exhaust manifold thread size?
- OS 1.60 Muffler
- Thunder Tiger .61 break in prop???
- G90 and pusher prop
- STUKA - Enya 60 replacement - Saito 82a?
- OS 46AX Needle Mount Bracket
- AP .15 Q's
- Saito 56 transition
- Saito 82a Tuning HELP
- Saito, Date of Manufacture
- O.S. 1.20 surpass II pump question
- RCV-58cd
- Saito 325 radial running problem
- Saito 100
- OS .60FP
- OS 120 SP Supercharged Repair?
- Black neoprene and glow fuel ? ? ?
- OS45FSR Ringed to ABN conversion conundrum...
- A couple small questions about an engine
- moki 180
- No more magnum .91?
- Anybody with a thunder tiger 45? Need help here
- Something is wrong with my OS 91 FX
- Removal of rust stains in crankcase?
- YS 120 problems crap
- YS 110 fuel line hook up question
- Enya 4stroke parts
- Bearings
- Stunning price shock
- BCM and bisson muffler same ?
- synth and castor mix in fox engines
- JBA engines, good or bad.
- O.S. 40 FS Four-Stroke Settings
- os 2a carb settings which screw where 0s25fp
- FA-80 goes through 5 glow plugs in a row
- Stick travel vs. throttle response
- Been away from the sport for a ehile, what happened to the Magnum .40's, and .91 2 strokes?
- Hot exhaust on a wooden prop
- Will Saito ever produce an engine similar to the OS IL 300 inline fourstroke?
- os max .20
- OS FS 110-a
- Saito 115 - Impressions?
- OS 46ax rear engine bearing
- 3D prop for OS 55AX on a profile?
- OS Max-H 60 muffler question
- thread information on OS 91 surpass
- OS SF ?
- Thunder Tiger Pro .46 - Stock Low Speed Idle Default
- Seidel ST710 break-in
- O.S. 120 AX Bearing Upgrade?
- Price of glo plugs
- 30%nitro in Mag52FS??
- Help, ASP FS 61 AR muffler problem
- Rossi .45 VP numbers
- Need help with Enya 40SS
- New O.S. 60FP makes buzzing sound at low RPM
- K&B 61 In need of help!
- NIB Con Rod Slop?
- Pulling a sleeve
- Engine stumbles at 3/4 throttle..what is happening?
- MOVED: Converting big glow to gas?
- OS .75 AX
- PARTS FOR DISCONTINUED SAITO ENGINES
- New OS 25AX
- What NEW IN BOX Means To Paypal (Be Nice!)
- SAITO 170 R3 Bearings
- OS 55ax tuning?
- gasket?
- H B engines?
- os 200 4 stroke
- Thunder Tiger FS75 problem in Reactor 46
- Moki 215 Radial-Lots of questions
- K&B .28 Sportster
- OS Max 90 2 stroke help
- What Does NEW IN BOX Mean To YOU?
- OS 1.60 with smoke anyone tried it?
- Sources for Woodruff Keys!
- saito 220 ?
- Thunder Tiger 120 Pro Pumped - Performance Issue
- TT .28 questions
- Tower 46 vs OS 46AX performance
- OS 120 replacement
- Thunder Tiger 130 Four Stroke
- Moki 210 idle issues
- OS .91 4-stroke question
- Motor Mounting
- Saito 180 Motor Mount
- Saito .80 bearing replacement
- High speed needle issue
- plastic Irvine carb
- ASP 61FS glow plug?
- Magnum XL .52
- Magnum XL .52
- silicone instant gasket
- s c 70 rocker arm
- S.C. FS-70 engine very low compression
- O.S. 60FP Vibration Question
- sc 52fs default settings?????
- Twin engineded aircraft, any tips tec?
- O.S. 55AX with Macs Pre-Tuned 1943 System
- HP61BLACKHEAD2-CYCLE
- Saito 72 ??
- OS 25 LA inverted "tricks & tips"
- Saito 90 Flat Twin needs muffler parts numbers
- saito 100 15x4w and p-51 spinner TRUTURN
- O.S. .75 Exhaust question
- Mr. Supertigre flew away
- O'Donnel oil content
- SAITO needle settings?...help, I wanna fly tomorrow...
- OS FSR/SF parts source
- Testor engine
- McCoy 29
- Flex pipe and 90 deg header?
- after run?
- Evolution 46 rear needle mount screw??
- Prop noise rpm limit
- TT pro 120
- SAITO FA 120 GK
- Saito 82 power
- Hot ST's for old timer's
- Saito 220 Fuel Supply
- JB Weld
- Needle settings for Evolution 46nx
- In Cowl exhaust header for O.S./Mag 52
- What do you think of Aviastar
- Which Webra do I have?
- OS .45 FSR Carb question
- YS FZ 110 New... Very low compression
- MDS 1.48 2-STROKE
- How do I remove con-rod from crank shaft on my Saito 125??
- Saito 180 . What is the best prop ?
- Saito 450 problem
- Is using os 70 4 stroke crankcase breather nipple for smoke pressure ok?
- Super Tigre GS-51 With Leaking Head
- Saito 91 air bubbles at HS needle
- Saito 62 w/Turbo Header
- Saito Engine Question
- Replacement muffler body for OS FS-120 Surpass I
- Saito 450
- SC46A Deadstick!!
- Saito FA-100T Twin Help.
- .46 Evolution
- OS 55AX and Tower exhaust
- Magnum GP65
- OS Max SF 61 Heli Engine
- ASP Mufflers
- First OS 4-Stroke
- Manual for TT GP 61????
- OS60FP First start-up in 3yrs
- Fox used parts
- Engine tuning question
- Saito 56 hunting?
- low speed adjustment on OS7D carb
- Saito 82
- Who will over haul a Fox Twin ?
- Whats the deal with glo fuel and concrete floors?
- Smoke System Saito
- Magnum 70 4st.
- O.S. FS20 Crank Play
- Saito 125, keeping a muffler on?
- Saito FA-100T
- OS carb for supertigre
- OS 4 cycle crankcase oil recycle system
- Black exhaust/os46ax
- How to revive unused engine?
- What prop to use on a S.T. G90 ?
- OS 1.10 4 stroke
- ff-320 onboard glow driver
- TT FS75 Header Pipe Extension
- ASP 1.20 4 Stroke Valve Settings
- rossi .40 game over?
- YS engine question
- mac smoke system on os 70 4 stroke update - pictures uploaded
- Does anyone have this book?
- Round can muffler
- Tartan Single prop nut
- Enya R120-4C muffler
- HB.40 with a B-Y&O 11-3 prop
- Cox .020 frozen
- SUPER TIGRE 4500 OWNERS HELP!!
- ASP 70 4 stroke no compression help!
- Royal Engines info needed
- Saito 120 valve guide
- OPS .15 reassembly.. holy crap on a crumpet #$%^$#!!
- cline regulator question
- os 70 engine Stops when smoke system is turned on
