View Full Version : Glow Engines
- Oh... the 'G' stands for Gas now(?)
- OS 50 RC. 1963. strip down
- Anyway To put electric start on a .61
- CMB 45 or 67 wanted
- Wanted: CMB 67 or 45 engine
- Glow plug for dynamite .28
- Como 51 muffler
- Arden .19 glow plug engine!
- Soundproofing
- compression ratio for FAI fuel
- Saito fa100 engine failure
- Help with MDS 40
- Help with specs for Webra speed 28
- Help mach 26 28 427 parts
- OS 120 surpass II
- K&B with Perry carb. too rich
- Saito FA-120 manual
- OS wankel apex seal springs
- Saito Gas conversion experience
- TRX 3.3 bad performance all the sudden
- Removing the cam cover Magnum XL 52
- os four stroke
- NovaRossi won't get rich enough
- After run oil
- Evolution .46 or 0.S. .46?
- clunk level vs carb with pressure
- Enya 80 fs
- Starting an OSFX 46
- ys 185 non cdi
- Main Needle Valve Ratchet Spring
- Super Tiger G90
- Wanted carburetor for ASP FS 400
- Broken Ring on O.S FS-75 (open rocker)
- Webra 6.5ccm engine?
- Looking for Magnum 61 XL cranckshaft
- ASP .52 Muffler - What Screws Should I Use?
- or ..Cannot get glow plugs on a twin lit.
- Can I use a Rexel CDI with mechanical advance?
- Revolution r 50
- Steppin Up O.S.
- OS Max 25 sf engine wont run
- glow engines are fading away
- Saito 270T right cylinder hard to light
- New engine for T-Maxx
- Discontinued Saito Manuals
- David Andersen Drabant engine
- Help with several engines
- Tank plumbing for OS 120 4-Stroker with pump
- Remote needle valve assembly to Carburetor, Evolution 52NX
- OS .61fx or Super Tigre G90 for twin project?
- Fs-40 o.s. & o.s. 20fp
- OS 55AX Connecting Rod Broken
- Saito FA130T
- Super Tiger G21 trivia question...?
- YS 140 sport or FZ?
- OS .65AX over priming?????
- changing to new email
- Magnum Engines Parts and Service
- ? 2 stroke Magnum 91XL vs 91XLS
- Super Tiger S75 muffler or manifold needed
- OS 35 max problem
- Leaking Super Tigre G90
- What are your thoughts when smelling glow fuel?
- Saito Boxer, pusher modification?
- Bearing fix
- One way bearing fixs
- YS regulator adjustment?
- O.S. Max 65AX
- What is this YS?
- YS FZ80S Back in Stock
- OS 52 Carb slop
- The carb
- YS 63 Regulator confusion
- Can't Seem To Get OS 55 AX To Tune Properly...
- Saito 200TI and tank position
- Irvine 72 annoying problem
- Bad front bearing
- Trying to find manual for OS max 40 FP
- Webra 10ccm (.61) cylinder wall lip
- where can I get small glow engines
- Wanted Parts for a Super Tiger 56
- LASER Engines Club
- OS 110 FS Alpha
- Magnum GB 40 or O
- Carbon on Exhaust Valve
- Sig Astro Hog
- YS 110FZ supercharged?
- OS 61FX Rich Mid Range Problem
- Byron DF K&B Engine
- Starting out with an older gifted engine. help?
- Hot up a TT46 glow
- OS 7D disassembly
- HP Gold Cup .40 Header and Pipe
- Determining Static Thrust ?
- .61 engine Stalls at High Throttle
- Seized fox 35 engine
- Counter-Rotating Saito Engines Fact Vs Myth
- getting frustrated
- OS 1.60 FX to plane weight?
- SC .75 glow
- the unnorm, looking for something different, what's out there ???
- Super Tigre 40 parts?
- Saito Parts
- Timing gear? Help Please.
- Dualtrax wont start
- O.S. 120 carb leaking
- 4St exhaust question
- Nitro methane oxide
- throttle servo linkage
- Irvine 36 redhead
- YS Start Up After Sitting for 2 yrs
- MAGNUM XL 28 parts
- Engine mount
- So, Made my own high speed "o" Ring
- Saito 180 fuel tank?
- CW or CCW?
- what is the difference?
- Need a little help...
- OS .46AX with 11x6 only turning 10500 rpm, what ththe heck
- YS 120 SF engine repair
- Looking for O.S. 120 II Gemini advice
- GMS Engine
- Another gummed up bearing thread
- Question on carb o ring sizes on Magnum FS 120 AR
- glow engine smoker..is it a feasable thing?
- 4-stroke smaller than .40
- Stallion .35 R/C
- Saito FA-120 ABC with Brass Tube muffler
- Tuned Pie
- Fuel Tubing ID size vs Remote Needle Settings
- Saito radial cooling baffles
- OS .46 FX - What's missing?
- Saito 100 turns 7500 Max
- How high can a YS four stroke pump fuel?
- Magnum Engine Parts - XL-80
- Saito .65
- Saito FA 182 TD Inverted
- Super Tiger?
- Any news on the fellow who purchased Frank Bowmans replacement piston ring business?
- Y S F-120 4 Stroke Engine Question
- K&B .61 head gasket
- JBA .56 tuning from scratch (may apply to other engines as well)
- Need Help Finding Saito Manual
- Mousse can logic?
- O&R .60 parts
- Saito 125, stuck valves?
- Magnum 91XL Four Stroke Carb Parts
- Need an empty Saito box for 72 four stroke.
- Sport Jett .50 vs. OS 55AX
- Frank Bowmans piston ring co has been sold to a new owner
- Fuel regulator and pump
- Removing paint from engine
- don harris on board charging system Anyone familiar with these sytems
- Tower Hobbies .46 Prop/Fuel/Plane question
- DiD I ruin my MDS 48?
- Need a ring for a Rossi 60 blackhead
- O.S. LA25 modifications
- When good engines go bad...
- Exhaust
- Wanted, head for Enya 90-4C
- OS FS 70 without crankcase breather?
- shiny case fox .15x slant
- unknown glow engine
- Magnum .30Fs
- HP 61 - need a a ring for the engine
- How to get bearing out of OS 46 FX?
- Magnum engines
- What is this engine?
- Turbo Head vs Standard head
- Loose Wrist Pin repair. Webra 25
- Very nasty OS 46AX
- Nitro fuel storage and longevity
- Help! Muffler screws are frozen.
- ROLLING Chicken Stick
- Super Tigre
- Evolution 91NX
- Enya 80 4C hard to prime
- Os 1.20
- Engines with vs without cylinder liners
- OS FS-95V four-stroke. Why so cheap?
- Leo 46 glow engine anybody have experience with these?
- Laser Engines UK
- Are Macs pipes gone forever ?
- The most beautiful O.S engines ever made
- After run oil or Rust?
- Skyward 60
- Are ASP .15A and SC .15A exactly the same engines ? And are they any good ?
- JBA 120 or JBA motors any good?
- Engine starting help!!!
- Lambert's RC
- OS Engine interchanging parts question
- loose needle valve on Magnum 91 4st
- Satio 100T (twin) idol question.
- Super Tigre 3250 gas glow plug
- Magnum 160 Twin--mid-range transition advice
- OS .46 AXII settings
- OS 91FX Macs tuned pipe header length need some help
- I need a header for an older OS MAX .91FSR......
- OS 46AX low speed throttle question
- Mecoa .46 idle. Adjustment
- i have an engine question please
- Engines quit at high rpm's
- O.S. fs-120 Surpass 2 mixture control settings
- Perry carb with Thunder Tiger Pro-46?
- Needle valve thread pitch
- glow fuel proof polyurethane finishes
- OS Max 1.20 2 stroke runnig problem
- OS MAX 60 FP and FS CARBS
- Clear plastic fuel tank for nitro fuel
- O.S. 120 FS Surpass (1) ?, Pump....... converting from pump to non pump....
- O.S 21VZ-B-V-Spec Engine breakin help required
- Securing muffler to 4-stroke engine
- Saito 30 engines
- WEBRA 55 CARB interchangeable with an OS????????
- os max .91fx
- OS Gemini spitting, leaking carb
- When The High Speed Needle is fully closed...DOES IT DO THIS? WEBRA 55
- 4-stroke setup problem
- ASP/MAGNUM 91FS ball bearings
- Saito 30 engine
- Rare Chinese engine
- Identify this motor please.
- YS140 Limited
- I have a dull Prop Reamer.....
- K&B .40 rear exhaust
- Prop Reamer
- Anyone have a Hayes tank they are willing to part with?
- help me identify this motor
- High temps during break-in
- PatRoVa rotary valve model engine
- OS 91 Surpass Piston removal
- ASP .36 Carb Mod
- Spinner for big Super Tigre?
- Thunder Tiger Pro 40/46 Carburetor
- Converting glow to gas sizes
- Irvine .46 Mk II (later model). Question about crankshaft.
- Linseed Oil as a cleaner
- Issue with OS .55ax
- Saito 300 glow fuel
- Starting a Saito 300
- I need a Regulator, suggestions please
- I have an old Irvine .46 with some stripped head screws...
- Bill, I wish to go faster,, but I have a question
- sceptreflight
- Crankcase pressure tap causing poor idle?
- SAITO 1.80 CARB Tuning (Low & High) Speed
- Will an ASP FS61 Connecting Rod work in an O.S. FS61 Engine?
- Super morton m5 engine manufacturer vernal engineering up and running!
- Os max h 29r & os maxiii
