View Full Version : Glow Engines
- What size of prop for my Saito 82?
- Saito 180 with 18 inch 10% nitro 10% EDL
- Tower .75 for 3D flying?
- K&B .28 piston scoring
- e thunder tiger parts
- Super Tigre .51 Should I buy it?
- Some people have claimed Marvel Mystery Oil causes rust...
- Moki 2.1 break-in procedure
- super tigre G51 ring
- ASP .65 FS Need some help..
- Cline fine
- 1/2A balloon tanks
- os 160 two stroke problem?
- Saito 180
- BAKERS AA CASTOR OIL AVAILABILITY?
- cleaning the exhust valve
- Saito question?
- Super Tigre G2300 for Ultra Hots?
- What would you do?
- Webra 160 with 12 mm MC Carb
- Magnun 75 Prop-RPM figures
- Aviastar .46 and .53 marked down at sigmfg.com
- Where to send a Saito for repair
- Tutorial - Making your own Saito gaskets!
- piston rings
- lost my muffler tip in the pond
- pressure fitting question
- Lower idle speed
- OS 120 FS
- OS FS120S-E compression
- ASP 52 is a high torque engine
- Saito heat problem
- SHOULD I BUY A DISCONTINUED NIB SAITO 120???
- Super Tigre G2300 upsidedown.
- NEW YS 140 SPORT RUNS TERRIBLE
- SS25 Enya Runs & quits
- Saito FA-115 in Pulse XT 60
- Need help on a Saito 182 twin
- Are the mounting holes the same 46FX/55AX?
- KB 48 bearing replacement
- OS 40 MAX H
- Enya Glow plug recommendation
- WANKEL
- GMS parts compatability
- Best pull start .21??
- os MAX 35AX and fs200 pumped
- os 1.20 fs problems
- magnum 160 twin questions.
- My old K&B will not run
- New O-rings for old carbs
- OS 160FX
- Irvine 46
- ASP 180 FS will not rev above 7800
- Any idea what would have caused this?
- Boost air temp?
- OS 1.20AX clicking noise
- ASP 180 FS
- OS Open rocker 60 parts and manual
- YS 110 quits when inverted
- Older engines..Which is the strongest/weakest?
- MDS .18 Muffler options
- Royal 46LS Carb (Needle Valve)
- Head screws + manual for older OS 91 Surpass
- Fueling problems
- TOWER: GMS and Tower engines now "on order"
- Saito FA-125 Prop for speed
- OS 70 Surpass Bearing
- Tuned pipe Moki 1.8 Help!!
- Revolver exhaust
- Mach racer and K&B .61 ringed PDP
- Pros & cons to using either a turbo or standard glow plug?
- Best fuel for 4-Stroke glow engines
- 3 bladed prop for an OS 91 with 30% fuel ?
- YS - OS comparison
- YS110 tuning
- MDS 2.18 Rotary Mount?????
- K& B 82 DUCT ENGINE
- Saito 180 Fuel line question?
- Need Help with new Saito 82 starting
- A little help needed
- Super tigre g3250 carb adjustment
- Ignition on Glow engines
- Starting a Moki 1.8
- Help! What does FSR stand for
- Webra 36
- Is there a listing anywhere of accurate engine weights???
- Pitts Muffler on OS 55ax
- COMO .90 parts
- Webra 4 cycle.Anyone know anything about them?
- OS MAX 60 H
- mounting dimensions
- perry carb for FOXES
- Moki 1.35 problem
- Mag .52 crash damage, what do you think?
- Front bearing Leakage
- ys-110 what am I doing wrong
- Muffler types
- OS 55AX and the new slimline pitts muffler
- Saito 170R3 Radial vs OS FT160 Twin
- Magnum XL RFS 91 Four Stroke
- Pressurized fuel system
- Prop For Saito FA 80
- Anyone know Ross engines?
- JB Weld for mufflers
- Cheap place to buy engines, planes, or parts
- K&B .48 Ultrathrust muffler
- More speed/power from O.S. 25 FX
- Idle mixture screw setting for OS 61FX?
- Super Tigre carbs
- Veco-Coy engine
- K&B .82 duct engine
- Break in for racen
- Enya ss 30
- YS 110
- SC (Magnum) 46 Glow engine
- SAITO 125-TOPFLITE OR ZINGER PROP, WHICH IS BETTER???
- Thunder Tiger F-91s - replacing cylinder head
- O.S. 46AX Glow Plugs, Can I use the long Reach Hot plugs with spacers?
- Eyna 120 four stroke
- Does anyone know about K&B engines?
- Saito 100 carb settings
- evolution 46 tuning help
- 46 engine trouble
- JIS (Japanese Industrial Standard) screwdrivers
- O.S. 30 One-way Bearing
- Need webra parts
- engine for P38
- SuperTigre head
- Tank Height
- TT Pro .61 idles but dies on throttle up
- Saito 91 VS OS 91 VS Magnum 91 VS Evo 61
- MAGNUM .52 XLS fuel tank Pressure line
- OS .46SF- Re-Ringing
- Saito 100 muffler manifold problem.
- Saito 45 Mark II
- unknown engine
- OS .56a
- YS 63 Thread Size
- Gasolene use in Glow engines
- K&B DUCT ENGINE HELP!!!
- broken crankcase on YS 91 ac GO FIGURE
- 4 stroke fuel pressure from vent?
- Webra .50 Speed questions
- Richer or Poorer,,, I mean leaner.
- Prop Sizes?
- Just bought an OPS .60, Prop size?
- Picked up some K&B's. Have questions.
- Lost recipe for mixing castor oil into Syn
- satio 100 4 stroke engines
- need M8x1.25 prop nut
- OS 120 Surpass III with pump?
- OS 4A carb
- Saito 325 R
- Hangar 9 Hellcat / Evolution motor help
- YS 91 Heli Motor on Airplane????
- FOUR STROKE: OS 91 SURPASS VS SAITO FA-125A
- OS 200 fs on Ultra Stick lite 120
- Denatured alcohol as fuel
- Quick question about FS 40S timing
- Enya recycling glow plugs
- Moki 2.10 service?
- 9-6 prop for thunder tiger 46 pro?
- magnum xl 80 rfs
- Dry Saito Camshaft
- magnum xl 80 fs
- Magnum XL-91RFS 4-Stroke Fuel Question
- Saito 100 (how do I adjust mixture w/a cowling
- j tec eng mount
- Enya 60 4C Compression
- OS .56S-a-4 stroke versus Saito .56
- Tower and GMS engines coming? Anybody know?
- 30 % nitro or 15 %
- Engine choices??
- Rossi .61 DF Engine needs a prop Help!!!!
- TTGP61 Tuning help
- Fuel pressure
- Cleaning muffler 4c engine
- saito 100 prop choice for speed
- New ring - How much running in?
- O.S. .61 SF Tuning Problem
- irvine 53 fuel question
- 4500 ST
- Fine tuning cline regulator
- Evolution 46nt Carb Question
- Saito 125 & Tru-Turn Spinner...what the???
- Try a 16x6 Scimitar on your 1.25
- OS25FX vs. Thunder Tiger 36
- PARTS FOR AN OLD SATIO 120
- "OS 160" 16mm ID bearings?
- 14x6 too much or too little for OS91surpassII?
- New OS .35AX
- Picco .21 SE
- OS 46 ax or fx?
- ST G61 W/new Bowman ring
- Piston Damage
- glow plug recomendation
- Super Tigre Advice
- West 50 V1 Nickel or Chrome plated sleeve
- Perry Pump
- Boring Engines or The Easy Way Out...
- OS 1.20FS Pumped Sagging
- Silver Swallow .40
- Two questions
- Saito 100 - Header pipe only
- glow fuel = what size gas engines?
- old enya 40 vs enya 45
- Missing Wrist Pin Pad
- Piper Cub Saito .72 or .82
- ENGINE CONDITION CLASSIFICATIONS
- Saito bearing R & R temperature
- Super Tigre breakin run Help
- O.S. .46 AX - bad rear bearing - metal shards... (replaced and running)
- problem with Thunder Tiger Pro 46
- Anyone Know the HP for Evolution 52NX
- Adrian - RCU, Motorbike Accident
- magnum 400 xl 5 cyl
- Realistic Propeller Thrust Calculator?
- YS 1.10 FZ or Saito 1.25 ??
- How do you change the bearings in OS Crankcase?
- Pacific Aero Starters: has anybody used these?
- On take of engine die...
- 1979 O.S. .61 VF rear exhaust
- Power comparison. Ys .63 vs .46ax, .90fx vs saito 100?????
- Vee-Coy
- Best Power? .19 ABC vs. .23 ringed
- Frank Bowman ring list with prices?
- 2 STROKE MOTORS INVERTED
- Motor ID
- Engine for Tower Hobby MKII ARF 40?
- OS 61 SF Carb
- OS 32 F engines
- HP of a used 46fx
- Lightest .46 engine?
- Magnum .91 Fourstroke Engine Swap
- End play on crankshaft
- Smoke systems
- Why does engine want to start backwards?
- Do your Balls make noise ???
- os48 surpass idle adjustment
- MVVS 91 carb
- Circular lines on the back cover os .50 sx
- OS 50sx question
- Buying Saito
- ys engines short lifespan
- MVVS Engine?
- K&B with pump
- 25VF and 25VF-DF Crankshaft Specs
- Fairly new OS 46AX Liner Peel..
- Two new restoration projects
- Large Saito 300's
