View Full Version : Glow Engines
- os 25 fx hop ups
- os 61 sf ringed
- Super Tiger G-45 vs OS 46-LA
- 46ax or webra 50
- Moki 1.8 with Cline regulator
- How to calculate outlet area?
- Man, did these things go fast!
- SAITO 450 (3 cylinder) HELP
- different tru turn adaptors for Saito 180
- Problem with OS 120 Engine with pump
- ASP 91 muffler
- Magnum 91 Four Stroke - Where is the idle stop screw?
- Prop nut thread size for YS 63
- Moki Engines???
- YS 63 Prop Sizes
- Enya 1.20 question,,, Please help!
- OS160 FX Problems
- air in the intake fuel line..any ideas?
- Need some info on enya 4 stroke 1.20
- mvvs 91, power difference long vs short pipe
- OS 1.60, Bisson, apc 18x6w what rpm?
- Inverted 91 4c
- TH .75 or ST .75 for H9 Hell Cat?
- OS 50 SX PROBLEM STILL...
- Supertigre GS 51 break in questions
- Thunder Tiger Pro .36 break in???
- saito 56 gk hub not spinner
- ultrathrust or jettstream for ST90
- MVVS engine decompression shims.
- Prop for OS MAX46AX and Spacewalker
- Saito 220 Fuel Pump
- Saito 60T problems
- Fuel Pump for a Saito 150
- someone please explain difference between 2 and 4 strokes..
- mag 91 xls abc or ring??
- I need a new engine. Fuel consumtion quistion
- Engine cleaning: how much to take apart?
- TT PRO61 MUFFLER CLEARANCE PBLM
- Help! Spinner won't fit
- SIG Motor mounts
- os60 fsr
- neoprene vrs silicone lines
- Old glow engine
- H9 .60 Size P-47 Engine?
- st 61 pitts mufflers?
- Surpass 70 spray bar is gone
- Cleaning Engines in a crockpot w/antifreeze...
- Abitar Timing Belt
- Need help with old O.S. .91 4-stroke
- Exhaust Deflector options
- Need help coosing Saito, FA or AAC
- I searched... and searched.... and searched... Saito 180
- Super Tigre G3250 Radial Mount
- Input on engine selection
- norvel .o61
- Tuned Pipe on a G90, Anyone?
- glow plug temps, what should they be?
- Evolution Owners plz read!!!!!
- I don't know
- SC180AR Pitts Muffler Match?
- Engine selection
- Thin Walled Silicon Fuel Tubing
- question
- Tower Hobbies .61 Ball Bearing ABC engine?
- Evolution Muffler Woes
- O.S. Anniversary Inline four cylinder, 4 stroke
- Which Edge 540T 27% ?????
- collari carb swap?
- Glow engine onboard ignition wires
- Pitts Muffler for Magnum XLS 36
- o s fl 70 engine
- Saito 120 spraybar position
- Saito 130 twin info
- Evo 1.00 and .46 low end needle setting Try this :-)
- Brand New OS 91 FS II Pump
- Tuned pipe basics
- Saito 45 ?
- Prop size
- Saito 220 - Dirty Needle Valve???
- tower hobbies .46 engines
- OS 60FP... air bleed... help!!!
- OS 160 twin and Magnum/ASP 160 twin - same bearings?
- ID this FOX R/C Engine??
- How to tell if I fouled my Plug?
- help with engine problem
- OS FL-70
- Help with OS 70 Surpass piston removal!
- K&B 3.5 SS O/B Bearings
- Moki 1.8 bearing change question.
- OS 46 AX
- Good or bad a variable pitch onboard prop.
- Saito 82 fuel consumption
- What has happen to Enya (MRC)?
- macs muffler on ST90
- MOVED: OFNA Hyper 21 parts??
- Backplate Gasket Critical? (15FE)
- Lanier 1/4 Extra 300s engine choice
- Older air-bleed Enya .61 (or so)
- O>S>FT160 Gemini Detonation
- Enya piston: which way around?
- Magnum XLS 28, whats the best plug?
- Inverted Slimline Pitts + Saito 1.00 = good, bad or neither?
- YS 45 inverted help
- plug help for an OS 61 FX
- Berger 7 cly radial engine
- Ol Betsy .65 still needs help..
- Mark 2.10 Tread Size
- Rear bearing stuck in an OS 46FX, Aluminum residue in new 32SX
- Air filter in carburator air intake??
- YS 110 Prop Size
- MDS 148 piston needed
- Enya parts... finally!!
- Dyna Torque dynomometer?
- scoring on piston
- Super Tigre 3000
- Good news, Bad news
- ST G4500-running 'backward'?
- K&B .61 engine?
- Diff Btwn OS 91 Surpass and Surpass II?
- my new magnum XL61a
- Looking for a ST 90 exhaust manifold
- K&B Sportster 28 carb adjustment
- ASP 4-Stroke FS 80
- TF in cowl muffler
- Saito .82a Problem?.... Only 8700 RPM on 14x6
- Engine repair service recommendation!!
- Saito rebuild
- how many engines
- Directional Piston on OS engines
- Thunder Tiger .36 pro???
- ST 61K
- MOVED: RB TM323 pull start?
- old OS 35 CURIOSITY
- Saito 120 and 180 Throttle Arms
- Aviastar motors
- Got Parts?
- WOW what an engine!!!!!!!!!!
- K&B .18 3cc engine
- Phillips type scrwdrivers for OS engines?
- Full Throttle flight
- Irvine 120 Engine
- Enya Four Stroke Question
- Startin her up...
- glow plug?? or carb, or what
- HPI T-15
- Crankcase pressure
- JHM DGS 2 digital glow switch
- MOVED: Are there engine work benches?
- Pylon engines
- Tower Hobbies .75 Muffler Extension???
- 1.08 equivalent to .91?
- How do I get connecting rod off OS 50SX?
- OS 4-Stroke Surpass II Low Power/Compression
- OS .15FP or Magnum XL-15A BB ???
- MOVED: LRP Z .18s ?'s
- Irvine .53 and OS .46FX/AX Slimline muffler
- MOVED: os .18 tm exhaust header
- Super Tigre GS-45
- Hopping up a FS 120 Surpass III?
- Car/buggy vs. heli vs. airplane engines
- OS .60 FP
- Anyone having any luck flying with a Saito 220?
- Engine Trivia Question
- OS 40 LA stalling
- 4-stroke parts
- OS FS 70 Surpass-OS 46 AX upgrading an OS 65LA?
- Merco 61 - carbon date it?
- using exuast stack as muffler?
- Saito 65 RPM
- gemini os 1.60 fourstroke twin
- OS 40 LA
- MOVED: Needle settings?
- Saito 100 carb orientation. Reversing possible?
- Thread size for exhaust port on OS 91 Surpass
- how do i....
- OS VS SAITO 4 STORKE - What are the differences ???
- Overpressurized fuel tank?
- cline regulator
- whats this crap
- Breaking-in webra 1.20, any experience?
- ringed engine break in?
- SAITO 150 - Carburettor Position
- Chart for swapping out a 2 stroke with a 4 stroke
- Moki 2.10's - Where to buy?
- Is the idle stop screw on a Super Tigre G51 ring engine crucial
- pitts mufflers for small 2 strokes
- WEBRA 50-where to buy
- Horsepower Vs RPM
- engine power question
- Thunder tiger 120 pro pumped two stroke
- RCV 90-cd thrust
- How to remove the bearing from the crank?
- Side holes on Perry VP-30 pump
- Smallest 4 stroke
- os 1.20 four stroke
- NEW OS 50SX help...
- Saito 180 Fuel Consumption
- Engine cooling
- New and having problems
- taiwan .18 engine
- Enya 60III
- YS 61R Two-stroke
- Saito 180 vibration!!!!!!!
- SK.90 Engine. Any Experiences?
- Carb setting on old Enya 45X
- Setting High End
- Enya 120R, pressure line?
- When did Saito remove the choke from the 120?
- MOVED: t-maxx .15 way high rpm!
- Which on board glow system for saito 2.20?
- MOVED: New! How do you start this!
- ST G2300 question...
- YS 160 DZ vs 3M Mintor 170
- Tower Hobbies .75 - Better Muffler??
- .21 Fuel Consumption
- HB 2-Stroke Instructions
- OS Fs120 Surpass III w/ Pump ? Opinions ?
- Super Tigre G-34 or OS .40LA???
- Best "Oil Ratio" mix for the OS 46 FX?
- OS BGX 3500
- Where to buy part for MOKI 2.10
- O.S. Bearing question-
- evolution question
- OS 25 FX problems.
- LA 46 AX 46 bolting patterns?
- YS 120 Won't Pump Fuel
- Saito with Perry Pump -tuning problem
- G90 and mousse can test today... WOW
- O.S. 46SF, removing crankshaft and bearings?
- Help removing Saito bearings
- O.S. FS-120 Surpass II W/pump
- Best performance prop in 11-12" Dia ?
- About to buy a GMS engine, some questions though.....
- Need Gasket for 30 year old OS Max
- Full throttle delays
- Nexstar 4-stroke option?
- 3.5 K&B
- Home made silencer?
- Moki/Mark 2.10 prop - found a good one
- Saito 180 Twin Tuning
- New YS FZ110-S
- Supertigre G51 Carb
- Engine Mounting- Which way up is best?
- Help starting Jato with OS .18 engine
- MOVED: Maloney 100 Engine
- 3" spinnner
- need venturi
- larger drive hub for ys 140
- OS .35
- returning engines help.?
