- Saito FA 80 T
- Saito 56 has me beat...
- Gas Prices! WOW!!
- saito 450
- Rossi 61 or 65
- Whats equivelant or better?
- Pitts-style mufflers and larger engines
- help with TT Pro 46
- ST G-2300/pump/regulator......
- Enya .29 #5224 - no clue
- MP-Jet .061 oddity
- OS91FX inverted in U-Can-Do???
- Fuel Dot installation help needed
- Priming engine with a Cline Regulator?
- Super Tigre 90
- Major problems with Saito 180
- Saito 100 break-in
- TT pro.46
- YS 50 ST or OS 50 Hyper
- Magnum 46 XLS lowest price yet
- Need help timing Saito 300tl twin
- MVVS Engines..
- Gator Soft-N-Safe mount
- beware OS LA users
- Most powerful
- Inverted Pitts for TT .46?
- How to tap O.S. 1.60FX for Perry Pump??
- Moki 1.8 Rear Bearing Removal
- Plane crash victim
- What's the "best" speed prop for a saito 91?
- epoxy fiberglass fuel tank
- Enya 1.20 R versus non-R
- Differences of the Saito Golden Knight
- Fuel pumps
- Saito 180 - Higher Compression?
- Prop for .91 two stroke
- Fuel Consumption
- OS .91 FX with a .61 MACC Muffled Pipe. Is this OK?
- Magnum Idel bar question
- ASP 91 & Magnum 91 XLS
- OS 120, what should I expect?
- FA-80 Saito
- fuel eater
- glow plugs and heat range
- Saito 100 twin!
- saito 56 vs OS 46Fx?
- OS 50 SX and prop question
- moki tuned pipe
- Saito from the US
- MVVS77 floppy throttle arm
- Pitts muffler on my Saito 91 ???
- MDS 1.48
- idleing on tarmack
- adapter for automobile compression gauge?
- magnum 4stoke rules :)
- magnum 61 abc grrrrrr
- Please Help - Anyone Who Has Saito170 3-Cylinder Radial
- .91 4 stroke surging
- mvvs .91 sucking air
- Evolution siezed? maybe to the naked eye
- Saito 91s rebuild question
- Saito80 Alternative Mufflers
- K&B Aero 1.00 Problem
- Moki 2.1 with 18x8 Prop
- Supertiger g 90 maximum prop size?
- Cheapest online store to purchase an OS 160FX
- Fuel Consumption of Saito Engines
- Webra 160 AAR
- Magnum 160 twin
- Super Tiger 90K- quitting on me
- TT pro 46 prop.
- GMS 1.20 Stories?
- SuperTiger G51 vs Magnum 52?
- Super Tiger 40-Ringed
- oil leak from front bearing OS40scx 4 stroke
- Saito 100 FA-AAC vs YS 1.10 FZ
- Saito 100
- YS 63 with APC 14x4. Has anyone tried it.
- best prop for YS 91 AC 4cycle
- SAITO 150: APC 18x6 or 16x8???
- Tuned Pipes??
- Lite Machines Heatsink Head
- Do I have a problem? OS FS 120
- Saito 80 carb on Enya 80.....
- Prop for gms .47
- How did YOU break in your ST G51?
- OS 46AX baffle
- Inverted engine problems
- chip in piston
- What engine for plane
- YS 120 SF smoke.......
- Experience with these engines
- OS 46 La Idle Air Screw (Inverted) DO THIS IT WORKS!!!
- PERRY PUMP VP-30 ON O.S BGX 3500
- Need help on inverted ST 3000 setup
- removing baffle on OS 40la
- Evolution/Pitts Muffler Problem
- RCV 120 SP questions & experiences
- Saito 82 vs Ys 63??? fuel econ. and power stats
- Moki 1.80 or OS 160FX.
- OS .25 NIB
- K&B 48-4800
- Saito 100
- Saito Exhaust - Tuning & Power
- SAITO FA-56 VS FA-56F
- 3-d prop os fs 70ll
- Saito 80 with Inverted Pitts muffler???
- 4 Cycle fuel.
- Basic engine question...
- engine help
- Moki 1.35 midrange question
- Miller Starter
- Header and Muffler for OS1.20 FS four stroke
- Help With Saito
- OS 40 FS problems. prop flies off
- Revolution 46 shaft end play
- Carb on Super Tigre G90
- O.S 46 ax
- Magnum XL120RFS poor transition!
- Cox Prop Hubs
- SAITO 120 THAT EATS CONNECTING RODS
- OS LA .40 Muffler Replacement
- New Saito 82 bearing play
- Break in questions for Saito 1.00 4 Str.
- Saito 1.00 4Str. Help! Beginner
- Evolution engines
- MOVED: repairing planes
- Evolution remote needle valve...can it be moved?
- fuel for 2 stroke ringed engine
- Help For O.S. 70-FS Ultimate
- Saito FA-30 w/exposed rockers???
- OPS .60 Parts
- saito & inverted flight
- Webra Speed 25GT
- Tower Hobbies .75 Poor Running
- Pitts-style muffler for Evolution 100
- Can't get more than 1/2 Throttle from my SK .80
- LEAK OUT OF GLOW PLUG
- What Is AAC/ABC on Nelson Engine?
- I'm at my wits' end here, please help!
- BESIDES OS, what engines out there perform?
- Old glow engine--What do I have?
- pressure niple on a tuned pipe
- new moki 2.10 help needed
- 4 deadstix in last 4 flights...saito .82
- sick os 120
- Saito 100 flat twin fueling system
- MCPs
- tiger shark engine? yes? no?
- OS 1.60 FX - Breakin with Bisson Muffler
- .46FX Problems
- Another Break-in Question-FP-40
- O.S. 320 QUAD FOR A 1/3 SCALE J-3?
- Fuel Draw problem on inverted tower .75
- Saito 300 Twin vs. Saito 2.2 Single
- is my 46fx going to die????
- rpm range for saito 91?
- norvel engine
- Saito 180 crankcase noise...
- Hi Johnson's J-R/C (Dynamic Models) Engine
- O.S. Prop Selection
- Pressure regulator
- What do you think? ST G51 issues...
- Timing on Saito's
- Engine Cleaner
- Leo Engine
- Magnum .61 What Prop
- Iron Bay fuel regulator
- Anybody with a Thunder Tiger .46 Pro?
- SAITO 220
- saito 100 or 120
- Info on OS Max 61V ABC
- Cutting down (Resizing) Props any comments good or bad
- ENGINE BALANCING ACT
- too tight piston
- Breaking in a TT GP 25
- can't find an engine section in here so..i'm looking for any and all info i can get on the os Wankel
- THUNDER TIGER PRO 120-RP
- Prather .21 K& B
- GMS.47 needs a lot of help
- EVOLUTION 1.00 NX
- Rossi 45 erratic operation
- SuperTigre .40 Pipe....who makes them besides Mac?
- Tower 46 air leak
- Muffler for Eyna 46 4 stroke question?
- DeadStick Magnum 1.20 2C
- Saito 100 High and Low needles settings
- Fuel for Saito 100
- Leaking O.S. FS 52S
- os 160 and World models zen-120
- os 70 ultimate
- Lost carb. screws
- Picking an Engine
- Thunder Tiger Pro 46 - lost needle valve
- MVVS 40 -Question: Pipe rattle
- Magum GP .25 parts?
- missing needle adjuster
- YS 1.10 won't stop?!
- BGX- Break in time
- SAITO 65 SET UP????????????????????????????
- MDS .25 ABC engine Good or BAD ?
- Disadvantages of 30% Heli??
- nelson qm 40 engines
- Anybody have a Saito 220 yet?
- OS50sx Vs 46ax
- glo plug element goes silver on saito 120
- how do you start a dual plug twin saito 130
- Four stroke valves
- Moki 180 Prop sleeve
- Fuel Draw!
- OS FS91/Funtana 40 What Prop
- OS 7L carburetor on Webra 91 engine problem
- 46fx Pumped???
- Saito 100--what fuel & prop/ 6.3 pound plane
- ASP 120AR four sroke
- Saito .82 w/ tank on CG - Do I need a regulator?
- Wanted pics of plug coil failures and reasons
- Saito 100 Exhaust?
- Neoprene fuel line
- comments Fox engines
- 2 blade to 3 blade change
- O.S. 7D carb on ST3250
- Saito 150 prop shaft extension
- ASP 91 Four Stroker
- Garage Sale Mcoy?
- Confused with the saito 80 throttle
- Magnum 52
- OS Max FSR 50 Piston Ring
- Phenomenal or what OS .40 LA
- Setting up mixtures on Saito 182
- Glow Plug Voltage
- OPS Maxi 30cc Engine
- OS 91 FX muffler
- WEBRA 4 STROKE STARTING PROBLEM
- MVVS
- Need glow plug size
- FUEL TANK SIZE FOR SAITO 150
- Need Help How to Plumb an OS Pumper
- What engine to buy?
- BEST PROP TO 3D WITH THE 91 FX
- Magnum 91 back from repair...worse then ever!
- bearings and performances
- K&B .61 With Perry Carb and Pump Question
- YS63FZ and Funtana ??
- saito 182t glow plug insert
- 2 stroke smoke
- RC Engine Bearings
- Macs Tuned Pipe Assembly
- Little confuse on the Saito 80 throttle
- When is a glow engine worn out?
