View Full Version : Glow Engines
- Any Place To Service Saitos Except Horizon ?
- raduga 7m (7cc)
- Thunder Tiger 60/120 carb on TT 46 Pro
- Magnum .46 prob
- New Engine Preparations
- problem with O.S 40
- H B engine Anyone hear of them
- Engine spits and sputters on takeoff. HELP!!
- help with 4 stroke twin
- Help!! Enya 29 model 5224 NIB need muffler and needle
- Interesting reading: tuned pipe theory explained
- O.S. 1.08 Piston
- ASP engines .91--1.08
- Cheaper Rossi 40?
- help - my OS 46 AX is running like a peice of junk.
- OS or SAITO 90
- Mate a Magnum 120 carb to an OS 120 pumper
- Evolution 1.00
- Saito .72 Need prop for more speed and pull
- DIY Saito Manifolds
- Saito 150 Dual Plug
- Thunder Tiger .91 four stroke?
- Alternative muffler /Exhaust for Saitos
- Suevia 150?
- Irvine 53
- Anyone know of a Pitts-style miffler that fits a K&B.28 Sportster?
- O.S. FS-48
- Slimline vs. Bisson mufflers
- 3 Blade prop for Sai .72
- AR 160 twin magnum
- Fuel for ASP 1.08 Redhead
- Way to enhance power for Satio 100?
- Anyone do rebuilds/rings jobs?
- inverted Tower .61 problems
- selecting good glow engine for rc model
- ST 2300 and smoke
- T-15 piston sleeve removal tips?
- Thunder Tiger Pro 61 Tune-UP
- Manual for TH .46 BB ABC???
- OS 46AX Engine damage after Crash
- Easy fix for glo motors KICKS
- success with super tiger RE .61
- .91 Magnum FS VS OS .91 FS
- Ringed engine settings...
- Tower hobbies engine problem
- Super Tiger G51 should I return it??
- os gemini I or II
- os gemini 120 big enough for 1/4 cub??
- EVOLUTION .61 NT
- hp .40 gold cup
- sealing the motor?
- Help Pls...
- TT pro .46 problems
- Super Tiger 2300 Need Airplane???
- Stupid OS .46 AX.... Arrrggg
- Pump and Regulator?
- Explain why changing to a tuned muffler ...
- OS LA-10 airbleed
- Which Engine for this project?
- 4 Stroke high speed needle setting.
- engine problem
- OS FS 70 In Cowl Muffler...
- glow plugs I D
- Installing teflon pads onto wrist pin
- Pitts muffler for Webra 61 Speed
- OS SF series vrs the FX series
- OS46FXi vs. OS46FX
- Why there is no hot or cold plugs for 4 tsrokes ?
- OS CV-A 15 prop/rpm?
- What size 3 blade prop for OS 160FX?
- OS 120 Surpass II help!
- mds 48 carb?
- Moki 135 vs YS 120
- YS vs Wich fuel
- Need parts for Rossi 61 rear exhaust
- New OS 46 LA Wont Start. Please Help!
- Y-S Four Stroke plugs
- WHAT DO YOU SAY GUYS
- Venting while filling
- Fail safe recommendations
- Webra Speed 55 GT
- Saito 56 and a 14x4?
- It's all about torque :-)
- Enya 80 X, Manual Anybody?
- fuel pump or no pump, whats the diff???
- Which fuel tank for Saito .56
- saito 100 pulsating
- Moki 1.80???
- Crank removal in older supertiger
- Need a carb for 1.0 to 1.3 size glow engine?
- Enya replacement parts
- Any ideas?
- How does OS FS.70 compare to OS FS.91?
- glow plug info?
- o.s. 1.60
- Irvine to switch production
- need to know prop drill size for saito 100 and ys110
- How to setup camshaft-timing at an OS FT-160 ?????
- Rossi 61 rear exhaust - carb question
- Am I over revving?
- TT carbs
- This ones got me!!
- I must be one of the Lucky Ones...
- Anyone ever heard of an MFA engine?
- Need buying advice, please! Webra 6.5
- Need buying advice, please! OS 48 Surpass
- Need buying advice, please! Webra 4-stroke 40,60,80
- Enya .35 Model 5224
- Are Magnum 4 stroke engines any good?
- Laser Engines V-Twins?
- SuperTigre G-2000
- Need ID and info on rear-exhaust ST 45s w/pipes
- OS AX Engines
- Vq P40 what size Y& S To use
- Irvine .46, any good?
- help with ASP 91 red head
- Magnum .61 RFS questions
- Rossi .81 DF Engine (Byron) Manual
- At what point is a prop too big?
- OS 91 fx
- Magnum 1.20XL-S Muffler/Header
- HELP!! OS .61 FX MAX thrust
- os 46 sf
- Which do you prefer Saito or OS 4 stroke
- Too much backpressure??
- sk engine any good
- Bending a Macs header
- Any Word On Saito FA-220 Zeus
- os 91 pressure line question...
- Home brew smoke on YS .63?
- Perry carb and pump
- Saito 65 Valve Adjustment
- YS 53 Please help
- Saito 100 vs. O.S. 120??
- glow plug for a s/t
- best tank for YS 120 ?
- Magnum .61XL Mufflers
- os surpass 91
- OS 91FX and MA K Series Props
- OS .50SX Fuel Bubbles
- OS 50SX Fuel Bubbles
- Cen 46 vs. 4 stroke?
- re plating cylinder liner
- YS PARTS
- ROSSI .45 Help!!!!
- OS 45 or OS 46 Parts
- Cheapy on a pipe
- prop size for supertiger 300 in j-3 cub?
- prop size for supertiger 300 inj cub?
- super tiger 3000 on a 1/4 scale cub?
- Choosing a glow engine.
- engines
- information on YS 60 2 cycle
- YS .61 2 Stroke
- OS 50SX tuning/glowplug problems..
- OS .46 AX as good as the .46 FX??
- team infinity samurai 528 5 port
- RCV Engines
- OS engine cylinder lining peeling/flaking
- Nova Rossi .12
- How many threads out on perry pump?
- 15X4 3 blade prop
- What prop for Saito 150 on goldberg Extra
- Is K&B a good engine? How good or bad it is?
- Supercharged 1.20
- Webra 61 w/strap on Muffler
- idle bar in inverted engine?
- Irvine 40 MkII Rear Intake, Anyone got one or Info one It???
- Anyone got this?
- Engine Choice Dilema
- carb leaking on YS120 SF
- Saito 270 drops cylinder at idle
- When its time for overhaul........
- Super Tigre .60 Bluehead
- Piston ring roll pin
- Which is stronger? RE with tuned pipe or side exhaust with tuned pipe?
- moki 2.10, low end mix dial??
- st 2500 inverted
- O&R 19 or 23?
- A choice: ringed or not?
- Saito with a choke....
- how a nitro glow engine works
- Help! Fuel feed for pusher set up
- How reliable is this engine
- *Saito .82*
- MOVED: Golden Skies CrossFire ARF
- antivibration engine mounts
- YS 110 seems to go lean....
- Smoke setup on small 4 stroke
- OS 1.60 ????
- Prop size?
- Saito 300 twin single carb vs dual carb
- Pitts for G75
- trouble with y.s. 110
- Tiger 75?
- Magnum .91 4S vs fuel tank position
- irvine .40 help
- Quick lesson please....???
- Anyone familiar with this Rossi?
- Exaust System
- G90 & Perf-Spec Ultra Thrust Muffler
- old ITALY ST-45 won't run correct!??
- gas converted to glow
- Thunder Tiger 91FS Tach ?'s
- Saito 100 and Coolpower 10%
- GMS .32 ABC BB -- Reliability???
- cleaning the GX-15 engine
- What is you favorite motor and why?
- need help learning
- Dangit! Perry pump help.
- Irvine engine help
- U-Can-Do 60 + Magnum 91FS ??
- Cooked Engine???
- Engine bearings... again
- exaust deflector
- Got the Perry Pump
- TT GP-10 needs home
- Tower Hobbies pro 46???
- Decal ?
- Tiger Shark 0.61 ABC
- thunder tiger VS OS
- OS .91 fs bearing replacement- Advice?
- Spinner Sizing
- tt pro 46 bearing
- What Has Happened To Just Engines?????
- OS or Saito
- is it true that...
- props for OS 1.08
- Enya 120 4C. Short Shaft?
- will they overheat
- Where is the magnum engine made?
- Super Custom Engine Help
- Saito 150 inverted?
- ASP 46 Running in
- JHM Eng. Glow light
- Valve adjusting question for 4-stroke?
- Direct Connection FA-18 Engine help
- What size Moki?
- Super Tiger 61 ringed
- Moki, Mark, DPM 2.10
- Over-the-hill Engines: Seeking Advice
- Prop Size
- SAITO 120 vs Tower Hobbies .75
- OS Exaust needed
- OS Air Bleeder
- Supertiger Muffler
- Saito 150 and YS 1.4 Dingo
- Cox Engines
- MERCO 61
- 61FX Crank Shaft
